Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Select text by position
Select text by position [message #452382] Fri, 18 March 2005 19:59 Go to next message
Originally posted by: doug-list.threepenny.net
Is there any way to set the caret in a text widget based on a position
(x,y coordinate)?
The setSelection(Point) method seems to treat the Point as (start, end)
so no use there.
I'm looking for something to match the Windows:
EM_CHARFROMPOS message.
Doug
Re: Select text by position [message #452495 is a reply to message #452382] Mon, 21 March 2005 15:12 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
Hi Doug,
Text does not do what you want, but you could use a StyledText instead,
which has:
- getOffsetAtLocation(Point)
- setCaretOffset(int)
Grant
"Doug Pearson" <doug-list@threepenny.net> wrote in message
news:d1fbtb$p4f$1@www.eclipse.org...
> (x,y coordinate)?
> so no use there.
> Doug
Re: Select text by position [message #452604 is a reply to message #452495] Wed, 23 March 2005 04:49 Go to previous message
That's excellent Grant -- just what I needed.
Many thanks (I'd been rolling my own by adding EM_CHARFROMPOS
messages...not exactly cross platform :)
Many thanks,
Doug
Grant Gayed wrote:
> Hi Doug,
> which has:
> Grant
>>(x,y coordinate)?
>>so no use there.
>>Thanks,
>>Doug
Previous Topic:Table Resize when parent resize
Next Topic:UI layout help
Current Time: Tue Sep 22 06:10:28 GMT 2020
Powered by FUDForum. Page generated in 0.01788 seconds
