Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Wizard dispalay problem
Wizard dispalay problem [message #452370] Fri, 18 March 2005 13:14 Go to next message
Michael Pellaton is currently offline Michael PellatonFriend
I am writing a wizard to change the password of a user. Everyting works
quite good, but I have a problem using the method serErrorMessage(). As
soon as I replace the Message with an error Message, a part of the back-
ground of the title area turns gray instead of white. When I reset the
error messge to null, everything looks fine again.
The code where I set the error message:
if (usernameText.getText().equals("")) {
setMessage(null);
setErrorMessage("A username must be specified");
return;
A screen shot of the wizard can be seen on:
http://www.pellaton.li/setErrorMessage.jpg
Am I doing something wrong or is this behaviour normal (I don't think so
because the "new project wizard" of Eclipse does not have the problem)?
Thanks in advance
Michael
Re: Wizard dispalay problem [message #452373 is a reply to message #452370] Fri, 18 March 2005 14:03 Go to previous message
Tiberiu Caprita is currently offline Tiberiu CapritaFriend
Member
That's a feature of jface TitleDialogArea (I think since 3.0); you can
take a look there for seErrorMesage() code.
Also New Project Wizard has same behaviour (enter an existing Project Name
to see that...).
If you dislike it, take a look of
public void setMessage(String newMessage, int newType)
JavaDoc.
Tiberiu
Michael Pellaton wrote:
> Hi
> setMessage(null);
> return;
> Thanks in advance
> Michael
Previous Topic:Editable combo box
Next Topic:Problem with adding more than two pages to a Wizard
Current Time: Sun Dec 15 15:34:52 GMT 2019
Powered by FUDForum. Page generated in 0.01452 seconds
