Re: scientific plots in SWT [message #451764 is a reply to message #451757] |
Tue, 08 March 2005 17:07 |
Originally posted by: kent.generatescape.com
have you checked out GEF? It may not be specific enough for your needs.
http://www.eclipse.org/articles/index.html
Graphical Editing Framework (GEF) has been designed to allow editing of user
data, generally referred to as the model, using graphical rather than
textual format.
"Stuart" <caunt@ill.fr> wrote in message
news:d0kim5$ing$1@www.eclipse.org...
> I'm developing an application in SWT that will run on both Linux and Mac
> that needs to incorporate scientific plots (1d, 2d and possibly 3d in the
> future).
> I've seen certain libraries using Swing such as JFreeChart
> (http://www.jfree.org/jfreechart) and SGT
> (http://www.epic.noaa.gov/java/sgt) which provide the type of
> functionality I need but the problem is running Swing in an SWT
> application on Mac (bug 67384).
> Could you tell me if:
> 1) There are any native SWT libraries which provide similar functionality.
> 2) Whether there are any work-arounds for the mac-swt-swing problem or if
> there are any developments in this area.
> Many thanks,
> Stuart
Re: scientific plots in SWT [message #451779 is a reply to message #451764] |
Wed, 09 March 2005 00:30 |
Rohit Colaco Messages: 36 Registered: July 2009 |
Member |
Hi Kent/Stuart,
You may want to review the chart library/UI being built in the BIRT
project.
Check it out at:
http://www.eclipse.org/birt/
Source available (under /source) at:
http://dev.eclipse.org/viewcvs/index.cgi/?cvsroot=BIRT_Proje ct
Post your chart specific questions at:
http://www.eclipse.org/newsportal/thread.php?group=eclipse.b irt
Features:
Device-independent chart output (SWT, SWING, Image file formats, etc)
Extensible (add your own chart types)
... and much more
Rohit Colaço
ECE Project Lead
> textual format.
>> Hi,
>> future).
>> Many thanks,
>> Stuart
FUDForum. Page generated in 0.03344 seconds
