Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Checkbox rendered in Table Cells
Re: Checkbox rendered in Table Cells [message #451384 is a reply to message #451367] |
Mon, 28 February 2005 19:56 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
If you just change the image 1) you will not have the platform image, 2) you
will not be accessible by screen readers or keyboard access 3) you will have
to write code to detect the mouse down (up?) in the image.
You could create a Button with style SWT.CHECK make it an editor in the
TableEditor:
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
Table table = new Table(shell, SWT.BORDER);
table.setHeaderVisible(true);
table.setLinesVisible(true);
TableColumn column0 = new TableColumn(table, SWT.NONE);
TableColumn column1 = new TableColumn(table, SWT.NONE);
TableColumn column2 = new TableColumn(table, SWT.NONE);
int minWidth = 0;
for (int i = 0; i < 100; i++) {
TableItem item = new TableItem(table, SWT.NONE);
item.setText(new String[] {"item "+i, "asdadasd", "sada d
asd asd a dasd"});
if (i %3 == 0 || i % 5 == 0) {
Button b = new Button(table, SWT.CHECK);
b.pack();
TableEditor editor = new TableEditor(table);
Point size = b.computeSize(SWT.DEFAULT,
SWT.DEFAULT);
editor.minimumWidth = size.x;
minWidth = Math.max(size.x, minWidth);
editor.minimumHeight = size.y;
editor.horizontalAlignment = SWT.RIGHT;
editor.verticalAlignment = SWT.CENTER;
if (i % 3 == 0) {
editor.setEditor(b, item , 1);
} else {
editor.setEditor(b, item , 2);
column0.pack();
column1.pack();
column1.setWidth(column1.getWidth() + minWidth);
column2.pack();
column2.setWidth(column2.getWidth() + minWidth);
shell.setSize(300, 300);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> wrote in message
news:BrUWoyVHFHA.704@fairy.ao.nlmk...
> Jason Shannon:
>> Hello,
>> Can anyone tell me if it is possible using SWT/JFace to display a
>> checkbox in a table cell in a TableViewer? So far I have managed to
>> display a single checkbox at the beginning of each table row, but have
>> not been able to put checkboxes within multiple table cells in the row.
>> I'm wanting my table to have several columns with boolean data types that
>> each display as checkboxes. Any help would be greatly appreciated.
> You could use image and change it on click.
> SY, Konstantin.
> Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: Checkbox rendered in Table Cells [message #451385 is a reply to message #451384] |
Mon, 28 February 2005 19:58 |
If you are using a JFace TableViewer, you could use a CheckboxCellEditor.
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:cvvt34$p85$1@www.eclipse.org...
> you will not be accessible by screen readers or keyboard access 3) you
> will have to write code to detect the mouse down (up?) in the image.
> TableEditor:
> int minWidth = 0;
> asd asd a dasd"});
> b.pack();
> SWT.DEFAULT);
> if (i % 3 == 0) {
> } else {
> column0.pack();
> column1.pack();
> column2.pack();
> shell.open ();
> display.dispose ();
>> Jason Shannon:
>>> Hello,
>>> that each display as checkboxes. Any help would be greatly appreciated.
>> SY, Konstantin.
Re: Checkbox rendered in Table Cells [message #451396 is a reply to message #451384] |
Tue, 01 March 2005 05:52 |
Konstantin Scheglov Messages: 555 Registered: July 2009 |
Veronika Irvine:
BTW, when I try in this example scroll table using keyboard
checkboxes don't move and become out of synch with their items. If I use
scrollbar I don't have such problem.
I use 3.1 M5 (M4 has same problem).
> TableEditor:
> int minWidth = 0;
> asd asd a dasd"});
> b.pack();
> SWT.DEFAULT);
> if (i % 3 == 0) {
> } else {
> column0.pack();
> column1.pack();
> column2.pack();
> shell.open ();
> display.dispose ();
>>Jason Shannon:
>>>Hello,
>>SY, Konstantin.
SY, Konstantin.
Konstantin Scheglov,
Google, Inc.
Re: Checkbox rendered in Table Cells [message #451666 is a reply to message #451385] |
Fri, 04 March 2005 17:35 |
J. Shanonn Messages: 12 Registered: July 2009 |
Junior Member |
Hi Veronika,
Thanks for the advice. I like your suggestion and have implemented it
successfully. I'm now looking into using a checkBoxCellEditor, but cannot
find any good examples. Do you have any?
Jason
>> TableEditor:
>> int minWidth = 0;
>> asd asd a dasd"});
>> b.pack();
>> SWT.DEFAULT);
>> if (i % 3 == 0) {
>> } else {
>> column0.pack();
>> column1.pack();
>> column2.pack();
>> shell.open ();
>> display.dispose ();
>>> Jason Shannon:
>>>> Hello,
>>> SY, Konstantin.
Re: Checkbox rendered in Table Cells [message #451667 is a reply to message #451666] |
Fri, 04 March 2005 19:48 |
See:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ui.test s/Eclipse%20JFace%20Tests/org/eclipse/jface/tests/viewers/Ch eckboxTableViewerTest.java?rev=HEAD&content-type=text/vn d.viewcvs-markup
Also, ask about the CheckboxCellEditor on the eclipse.platform newsgroup.
It is a part of JFace and the owners of JFace primarily read that news
group:
news://news.eclipse.org/eclipse.platform
"Jason Shannon" <jshannon@securac.net> wrote in message
news:d0a68u$pfo$1@www.eclipse.org...
> Hi Veronika,
> Thanks
> Jason
>>> TableEditor:
>>> int minWidth = 0;
>>> asd asd a dasd"});
>>> b.pack();
>>> SWT.DEFAULT);
>>> if (i % 3 == 0) {
>>> } else {
>>> column0.pack();
>>> column1.pack();
>>> column2.pack();
>>> shell.open ();
>>> display.dispose ();
>>>> Jason Shannon:
>>>>> Hello,
>>>>> row. I'm wanting my table to have several columns with boolean data
>>>>> types that each display as checkboxes. Any help would be greatly
>>>>> appreciated.
>>>> SY, Konstantin.
Current Time: Fri Apr 19 15:49:17 GMT 2024
Powered by FUDForum. Page generated in 0.03291 seconds
