Home » Eclipse Projects » Standard Widget Toolkit (SWT) » detecting the taskbar's length
detecting the taskbar's length [message #451005] Mon, 21 February 2005 08:14 Go to next message
Originally posted by: e3oginosX.hotmail.com
is there a way of getting the OS's taskbar's length?
i need to make a popup appear as from behind the taskbar (something like
msn messenger) , but in order to do that i need to know the OS's taskbar's
width.
thanks
Re: detecting the taskbar's length [message #451015 is a reply to message #451005] Mon, 21 February 2005 14:44 Go to previous messageGo to next message
Originally posted by: v.j.b
"Kiriakou Andonis" <e3oginosX@hotmail.com> wrote in message
news:cvc595$nbo$1@www.eclipse.org...
isn't the width of the taskbar the same as the screenwidth?
Re: detecting the taskbar's length [message #451023 is a reply to message #451005] Mon, 21 February 2005 17:07 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
You could probably figure this out by comparing Monitor.getClientArea() and
Monitor.getBounds().
> width.
> thanks
Re: detecting the taskbar's length [message #451026 is a reply to message #451023] Mon, 21 February 2005 18:23 Go to previous messageGo to next message
thanks
>> width.
>> thanks
Re: detecting the taskbar's length [message #451079 is a reply to message #451023] Tue, 22 February 2005 23:23 Go to previous messageGo to next message
Stef van Dijk is currently offline Stef van DijkFriend
Member
Is this supposed to work on Gtk (or am I misunderstanding the original
question)? I'm trying to determine the amount of available screen space
which depends on the height of the panel along the bottom (which may or may
not autohide). But when I tried using Monitor, the result was the same for
both bounds and clientArea regardless of whether the panel was visible or
not.
Note that maximize does the right thing so I'm hoping there is a simple way
to get the available space.
Stef
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:cvd4ha$s8l$1@www.eclipse.org...
and
taskbar's
> > width.
> > thanks
Re: detecting the taskbar's length [message #451109 is a reply to message #451079] Wed, 23 February 2005 13:49 Go to previous message
It is intended to work. Enter a bug report. It may not be possible to get
this information (although Window managers somehow do it).
"Stef van Dijk" <not-me@not-here.com> wrote in message
news:cvgep3$6lq$1@www.eclipse.org...
may
> not.
way
> Stef
> and
like
> taskbar's
> > > width.
> > > thanks
Previous Topic:custom imagery handlers
Next Topic:change size of a component at runtime
Current Time: Thu Oct 29 03:21:57 GMT 2020
Powered by FUDForum. Page generated in 0.02341 seconds
