Macintosh New and Newbie Problem [message #450893] |
Sun, 20 February 2005 02:31 |
J. Michael Dean, M.D. Messages: 218 Registered: July 2009 |
I actually had things working but I have encountered major problems
executing SWT programs and must be doing something nuts.
First, I added the swt.jar and swt-pi.jar to my /Library/Java/Extensions
folder. This has worked.
Second, I am playing with Jigloo as an editor. This DID work. I add
jigloo.jar to my project as an external JAR.
Third, I set up the library arguments with
-Djava.library.path=${system:ECLIPSE_HOME}/plugins/org.eclip se.swt.${system:
WS}_3.0.1/os/${system:OS}/${system:ARCH}
Which DID work but now does not work.
When I run a trivial application generated by Jigloo (SWT Main Application),
which DID work before poltergeist entered my house, I now consistently get
the dreaded and probably common:
Exception in thread "main" java.lang.UnsatisfiedLinkError: no
swt-pi-carbon-3063 in java.library.path
at
java.lang.ClassLoader.loadLibrary(ClassLoader.java:1517)
at
java.lang.Runtime.loadLibrary0(Runtime.java:788)
at
java.lang.System.loadLibrary(System.java:834)
at
org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at
org.eclipse.swt.internal.carbon.OS.<clinit>(OS.java:22)
at
org.eclipse.swt.widgets.Display.<clinit>(Display.java:311)
at
HelloWorld.main(HelloWorld.java:22)
The ONLY things I have done since this worked was added the Oxygen plugin,
which is an XML editor, and Subclipse, which is a Subversion plugin.
Neither has a graphic aspect that I know of.
Any assistance is most welcome. Thank you in advance.
- Mike Dean
Re: Macintosh New and Newbie Problem [message #450894 is a reply to message #450893] |
Sun, 20 February 2005 02:35 |
Sorry, I forgot to mention that inside the library folder, the actual names
of the native libraries are named libswt-pi-carbon-3063.jnilib, etc. The
message complains of not finding the file without the prefix 'lib' but I do
not think I ever changed anything. Thanks.
On 2/19/05 7:31 PM, in article BE3D44A4.4206%mdean77@comcast.net, "J Michael
> at
> at
> at
> at
> at
> at
> at
> - Mike Dean
Re: Macintosh New and Newbie Problem [message #450895 is a reply to message #450894] |
Sun, 20 February 2005 02:37 |
Sorry again. Also added the log4j material to Eclipse. Doubt that is issue.
On 2/19/05 7:35 PM, in article BE3D4576.420D%mdean77@comcast.net, "J Michael
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> - Mike Dean
FUDForum. Page generated in 0.01945 seconds
