Re: compilation error in "RTSC Module Primer" Lesson2 [message #4152 is a reply to message #3958] |
Tue, 16 June 2009 16:56   |
Originally posted by: bob.biosbob.biz
it looks like you are using a "pre-release" of xdctools 3.15, which you
may have received in some beta of CCS4
i would recommend downloading the "latest" xdctools 3.15 referenced via
the link in lesson 0....
the examples -- which *are* prebuilt -- were built with 3.15.00.33...
you should use this (or a later!!) version of the tools....
i'll update lesson 0 itself to state this dependency....
my recommendation is that you update to 3.15.00.50, which is the "real"
3.15 release from what i understand; it should be compatible with the
pre-built examples....
olivier Paviot wrote:
> Hello,
> I'm running the "RTSC Module Primer" tutorial.
> Lesson0 and Lesson1 are OK.
> When compiling Lesson2 (and Lesson3) with "gmake all", I get the
> following message:
> C:\userData\rtsc\examples\lesson2>gmake clean
> C:/CCStudio_v4.0/xdctools_3_15_00_13/bin/rm -rf cfgsite *.obj *.out
> C:\userData\rtsc\examples\lesson2>gmake all
> C:/CCStudio_v4.0/xdctools_3_15_00_13/xs xdc.tools.configuro -c
> C:/CCStudio_v4.0/CCSv4/tools/compiler/c6000_6_1_6 -t ti.targets.C64P -p
> ti.platforms.sim64Pxx -o
> cfgsite prog.cfg
> making package.mak (because of package.bld) ...
> generating interfaces for package cfgsite (because
> package/package.xdc.inc is older than package.xdc) ...
> configuring prog.x64P from package/cfg/prog_x64P.cfg ...
> cl64P package/cfg/prog_x64P.c ...
> "package/cfg/prog_x64P.c", line 527: error:
> "acme_utils_Bench_Module_State" has already been declared in the current
> scope
> "package/cfg/prog_x64P.c", line 534: error: declaration is incompatible
> with "struct acme_utils_Bench_Module_State__
> acme_utils_Bench_Module__state__V" (declared at line 280 of
> "C:/userData/rtsc/examples/acme/utils/Bench.h")>> Compilation failure
> 2 errors detected in the compilation of "package/cfg/prog_x64P.c".
> gmake.exe: *** [package/cfg/prog_x64P.o64P] Error 1
> js: " C:/CCStudio_v4.0/xdctools_3_15_00_13/packages/xdc/tools/Cmdr .xs ",
> line 40:
> Error: xdc.tools.configuro: configuration failed due to earlier errors
> (status = 2); 'linker.cmd' deleted.
> gmake: *** [cfgsite/compiler.opt] Error 1
> Any idea what could be the problem?
> Thanks in advance for your help,
> have a good day.
> Br,
> Olivier
FUDForum. Page generated in 0.02701 seconds
