Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Changing the children in SashForm and/or TableViewer
Changing the children in SashForm and/or TableViewer [message #449804] Sun, 30 January 2005 13:27
Hugo A. Garcia is currently offline Hugo A. GarciaFriend
I have a vertical sash form. The left side is a TreeViewer that behaves
normally. The right side is a TableView whose data changes depending on
the selection of the TreeViewer. I wonder if is possible it is better to
change the children in the SashForm or is it better to change the
TableView. The tables shown in the table view have different dimension
size. If you have some example code then I would appreciate it.
thank you
-H
Previous Topic:SWT As JSR?
Next Topic:[ANN] v1.02 - SWT Calendar Widgets with DatePicker
Current Time: Mon Dec 09 16:40:44 GMT 2019
Powered by FUDForum. Page generated in 0.03954 seconds
