Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Browser - Catching Get / Put
SWT Browser - Catching Get / Put [message #449715] Fri, 28 January 2005 01:22 Go to next message
kent gibson is currently offline kent gibsonFriend
Hi-ya
Does anyone know if it is possible to catch the get or post from the
browser?
When someone fills out a form on a web page and presses send I would like
to catch exactly what was sent.
I betcha you could do it with get, by converting the new url into
parameters but what about a post command?
If it won't work with the swt browser, short of creating a proxy server
and sniffing out every thing that gets sent are there any other ways?
thanks a million
kent
Re: SWT Browser - Catching Get / Put [message #449761 is a reply to message #449715] Fri, 28 January 2005 21:34 Go to previous messageGo to next message
Christophe Cornu is currently offline Christophe CornuFriend
What do you intend to use that info for? This might give us ideas to help
you.
Chris
Re: SWT Browser - Catching Get / Put [message #449808 is a reply to message #449761] Sun, 30 January 2005 19:07 Go to previous messageGo to next message
> you.
> Chris
thanks in your interest.
I would would like a user to be presented with a web page with n forms on
it, then they insert a pre defined string in a form field and perhaps
choose some options and then press send. Then I would like to capture the
get or post message including all of the arguments, which was sent as per
the form fields action property.
This way I can deduce exactly which form on a page is the search form. I
had a look at the Internet Explorer activeX interface and I didn't see
anything useful, unless I missed something, below is it's api.
I suppose I could replace all the action parameters of every form field to
point to some server process of my own and then catch the message but that
seems like overkill. Then I also reckon I could set up some sort of local
proxy server and sniff out every http packet but also that seems like
overkill. Do any clever people have any ideas? - thanks
Functions for Shell.Explorer :
METHOD (id = 500) :
Signature : int Navigate2([in] Variant * URL, [optional, in] Variant *
Flags, [optional, in] Variant * TargetFrameName, [optional, in] Variant *
PostData, [optional, in] Variant * Headers)
Description : Navigates to a URL or file or pidl.
Help File : null
METHOD (id = 501) :
Signature : int QueryStatusWB([in] UserDefined cmdID, [out, retval]
UserDefined * pcmdf)
Description : IOleCommandTarget::QueryStatus
Help File : null
METHOD (id = 502) :
Signature : int ExecWB([in] UserDefined cmdID, [in] UserDefined
cmdexecopt, [optional, in] Variant * pvaIn, [optional, in, out] Variant *
pvaOut)
Description : IOleCommandTarget::Exec
Help File : null
METHOD (id = 503) :
Signature : int ShowBrowserBar([in] Variant * pvaClsid, [optional, in]
Variant * pvarShow, [optional, in] Variant * pvarSize)
Description : Set BrowserBar to Clsid
Help File : null
PROPERTY GET (id = -525) :
Signature : int ReadyState([out, retval] UserDefined * plReadyState)
Description : null
Help File : null
PROPERTY GET (id = 550) :
Signature : int Offline([out, retval] boolean * pbOffline)
Description : Controls if the frame is offline (read from cache)
Help File : null
PROPERTY PUT (id = 550) :
Signature : int Offline([in] boolean pbOffline)
Help File : null
PROPERTY GET (id = 551) :
Signature : int Silent([out, retval] boolean * pbSilent)
Description : Controls if any dialog boxes can be shown
Help File : null
PROPERTY PUT (id = 551) :
Signature : int Silent([in] boolean pbSilent)
Help File : null
PROPERTY GET (id = 552) :
Signature : int RegisterAsBrowser([out, retval] boolean * pbRegister)
Description : Registers OC as a top-level browser (for target name
resolution)
Help File : null
PROPERTY PUT (id = 552) :
Signature : int RegisterAsBrowser([in] boolean pbRegister)
resolution)
Help File : null
PROPERTY GET (id = 553) :
Signature : int RegisterAsDropTarget([out, retval] boolean * pbRegister)
Description : Registers OC as a drop target for navigation
Help File : null
PROPERTY PUT (id = 553) :
Signature : int RegisterAsDropTarget([in] boolean pbRegister)
Help File : null
PROPERTY GET (id = 554) :
Signature : int TheaterMode([out, retval] boolean * pbRegister)
Description : Controls if the browser is in theater mode
Help File : null
PROPERTY PUT (id = 554) :
Signature : int TheaterMode([in] boolean pbRegister)
Help File : null
PROPERTY GET (id = 555) :
Signature : int AddressBar([out, retval] boolean * Value)
Description : Controls whether address bar is shown
Help File : null
PROPERTY PUT (id = 555) :
Signature : int AddressBar([in] boolean Value)
Help File : null
PROPERTY GET (id = 556) :
Signature : int Resizable([out, retval] boolean * Value)
Description : Controls whether the window is resizable
Help File : null
PROPERTY PUT (id = 556) :
Signature : int Resizable([in] boolean Value)
Help File : null
Re: SWT Browser - Catching Get / Put [message #452408 is a reply to message #449808] Sun, 20 March 2005 12:21 Go to previous messageGo to next message
Thomas Derflinger is currently offline Thomas DerflingerFriend
Hi Kent, did you find a solution to your GET / SET issue?
I have the same problem, I need to get the text that the user edited in
a <textarea> form. I tried with Document.documentElement.innerHTML but
that only retrieves the HTML without the user input.
-Thomas
>> help you.
>> Chris
> on it, then they insert a pre defined string in a form field and perhaps
> the get or post message including all of the arguments, which was sent
> as per the form fields action property.
> to point to some server process of my own and then catch the message but
> that seems like overkill. Then I also reckon I could set up some sort of
> local proxy server and sniff out every http packet but also that seems
> like overkill. Do any clever people have any ideas? - thanks
> METHOD (id = 500) : Signature : int Navigate2([in] Variant * URL,
> [optional, in] Variant * Flags, [optional, in] Variant *
> TargetFrameName, [optional, in] Variant * PostData, [optional, in]
> Variant * Headers)
> Help File : null
> METHOD (id = 501) : Signature : int QueryStatusWB([in] UserDefined
> cmdID, [out, retval] UserDefined * pcmdf)
> Help File : null
> METHOD (id = 502) : Signature : int ExecWB([in] UserDefined cmdID,
> [in] UserDefined cmdexecopt, [optional, in] Variant * pvaIn, [optional,
> in, out] Variant * pvaOut)
> Help File : null
> METHOD (id = 503) : Signature : int ShowBrowserBar([in] Variant *
> pvaClsid, [optional, in] Variant * pvarShow, [optional, in] Variant *
> pvarSize)
> Help File : null
> PROPERTY GET (id = -525) : Signature : int ReadyState([out,
> Description : null
> Help File : null
> PROPERTY GET (id = 550) : Signature : int Offline([out, retval]
> Help File : null
> PROPERTY PUT (id = 550) : Signature : int Offline([in] boolean
> pbOffline)
> Help File : null
> PROPERTY GET (id = 551) : Signature : int Silent([out, retval]
> boolean * pbSilent)
> Help File : null
> PROPERTY PUT (id = 551) : Signature : int Silent([in] boolean
> pbSilent)
> Help File : null
> PROPERTY GET (id = 552) : Signature : int RegisterAsBrowser([out,
> resolution)
> Help File : null
> PROPERTY PUT (id = 552) : Signature : int RegisterAsBrowser([in]
> boolean pbRegister)
> resolution)
> Help File : null
> PROPERTY GET (id = 553) : Signature : int
> Help File : null
> PROPERTY PUT (id = 553) : Signature : int
> Help File : null
> PROPERTY GET (id = 554) : Signature : int TheaterMode([out,
> Help File : null
> PROPERTY PUT (id = 554) : Signature : int TheaterMode([in] boolean
> pbRegister)
> Help File : null
> PROPERTY GET (id = 555) : Signature : int AddressBar([out, retval]
> boolean * Value)
> Help File : null
> PROPERTY PUT (id = 555) : Signature : int AddressBar([in] boolean
> Value)
> Help File : null
> PROPERTY GET (id = 556) : Signature : int Resizable([out, retval]
> boolean * Value)
> Help File : null
> PROPERTY PUT (id = 556) : Signature : int Resizable([in] boolean
> Value)
> Help File : null
Re: SWT Browser - Catching Get / Put [message #452482 is a reply to message #452408] Mon, 21 March 2005 10:56 Go to previous message
Originally posted by: kent.generatescape.com
The only way I can figure it out, is that you send the contents to a server
and then send the results back to yourself! Sounds convulated but should
work.
Please contact me if you have a better way, cuz this echo servlet
implemenation does not please me at all.
"Tommy" <tderflinger@gmx.net> wrote in message
news:d1juf3$681$1@news.eclipse.org...
> I have the same problem, I need to get the text that the user edited in a
> <textarea> form. I tried with Document.documentElement.innerHTML but that
> -Thomas
>>> help you.
>>> Chris
>> [optional, in] Variant * Flags, [optional, in] Variant * TargetFrameName,
>> [optional, in] Variant * PostData, [optional, in] Variant * Headers)
>> Help File : null
>> Help File : null
>> Help File : null
>> pvarSize)
>> Help File : null
>> PROPERTY GET (id = -525) : Signature : int ReadyState([out, retval]
>> Description : null
>> Help File : null
>> Help File : null
>> pbOffline)
>> Help File : null
>> boolean * pbSilent)
>> Help File : null
>> pbSilent)
>> Help File : null
>> resolution)
>> Help File : null
>> boolean pbRegister)
>> resolution)
>> Help File : null
>> Help File : null
>> PROPERTY PUT (id = 553) : Signature : int RegisterAsDropTarget([in]
>> boolean pbRegister)
>> Help File : null
>> PROPERTY GET (id = 554) : Signature : int TheaterMode([out, retval]
>> Help File : null
>> pbRegister)
>> Help File : null
>> boolean * Value)
>> Help File : null
>> Value)
>> Help File : null
>> boolean * Value)
>> Help File : null
>> Value)
>> Help File : null
Previous Topic:Checking & Greying tree items
Next Topic:How to display popup menu on LMouseButtonUP ?
Current Time: Fri Sep 25 04:48:18 GMT 2020
Powered by FUDForum. Page generated in 0.02117 seconds
