Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Tooltips
Tooltips [message #449467] Tue, 25 January 2005 04:39 Go to next message
Chris Fong is currently offline Chris FongFriend
Hi All,
Is it possible to change the font for tooltip text? How about other
tooltip properties like the delay time for a tooltip to popup?
Chris
Re: Tooltips [message #449485 is a reply to message #449467] Tue, 25 January 2005 13:33 Go to previous message
Grant Gayed is currently offline Grant GayedFriend
Hi Chris,
There is not support for customizing tooltip attributes like these, though
I've found at least one request for something similar (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=73228 ). If you think that
these are important features to have then you can log a Feature Request(s)
with Platform - SWT.
That being said, you _can_ achieve any of these affects on your own if you
implement fake tooltips, as demonstrated in
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet125.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup .
Grant
"Chris F" <bogleg_20@yahoo.com> wrote in message
news:ct4iio$eld$1@www.eclipse.org...
> Hi All,
> Chris
Previous Topic:text field to edit date type
Next Topic:SWT Font and AWT Font shows different size
Current Time: Fri Sep 18 21:12:07 GMT 2020
Powered by FUDForum. Page generated in 0.02174 seconds
