Home » Eclipse Projects » Standard Widget Toolkit (SWT) » error when using eclipse with Suse 9.2
error when using eclipse with Suse 9.2 [message #449359] |
Mon, 24 January 2005 16:03 |
Originally posted by: emerson.tre-sc.gov.br
I was having a lot of crashs using suse 9.2 on kde and eclipse 3.1 m4,
regardless the jdk version I used. It gave me an error related to qt
libraries, but I knew that eclipse used GTK, so i changed to GTK and the
error stopped occuring.
Emerson
Re: error when using eclipse with Suse 9.2 [message #449591 is a reply to message #449365] |
Wed, 26 January 2005 19:43 |
Here goes the log error :
Window that opens when eclipse crashs:
JVM terminated. Exit code=255
/home/emerson/j2sdk1.4.2_04/bin/java
-cp /home/emerson/eclipse/./startup.jar org.eclipse.core.launcher.Main
-os linux
-ws gtk
-arch x86
-showsplash /home/emerson/eclipse/./eclipse -showsplash 600
-exitdata /home/emerson/eclipse/./eclipse -exitdata 53d0015
-vm /home/emerson/j2sdk1.4.2_04/bin/java
-vmargs
Error that appear at console (i starte throught console):
QApplication: There should be max one application object
# HotSpot Virtual Machine Error, Internal Error
# Please report this error at
# http://java.sun.com/cgi-bin/bugreport.cgi
# Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode)
# Error ID: 43113F32554E54494D45110E4350500308
# Problematic Thread: prio=1 tid=0x5112a090 nid=0x1bb7 runnable
Heap at VM Abort:
Heap
def new generation total 3392K, used 3391K [0x44760000, 0x44b00000,
0x44c40000)
eden space 3072K, 99% used [0x44760000, 0x44a5fcb8, 0x44a60000)
from space 320K, 100% used [0x44a60000, 0x44ab0000, 0x44ab0000)
to space 320K, 0% used [0x44ab0000, 0x44ab0000, 0x44b00000)
tenured generation total 43444K, used 26260K [0x44c40000, 0x476ad000,
0x48760000)
the space 43444K, 60% used [0x44c40000, 0x465e53c0, 0x465e5400,
0x476ad000)
compacting perm gen total 32256K, used 32113K [0x48760000, 0x4a6e0000,
0x4c760000)
the space 32256K, 99% used [0x48760000, 0x4a6bc760, 0x4a6bc800,
0x4a6e0000)
[error occured during error reporting]
I had a a hs_err_pic* file from a a eclipse error:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4D995172
Function=XSetTile+0x12
Library=/usr/X11R6/lib/libX11.so.6
Current Java thread:
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:46 33)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:907)
at org.eclipse.swt.internal.gtk.OS._gtk_adjustment_value_change d(Native
Method)
at
org.eclipse.swt.internal.gtk.OS.gtk_adjustment_value_changed (OS.java:3157)
at org.eclipse.swt.widgets.ScrollBar.setValues(ScrollBar.java:6 53)
at org.eclipse.swt.custom.StyledText.setScrollBars(StyledText.j ava:7061)
at org.eclipse.swt.custom.StyledText.handleResize(StyledText.ja va:5138)
at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.j ava:4757)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:996)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1020)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1001)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:552)
at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:9 31)
at org.eclipse.swt.widgets.Canvas.setBounds(Canvas.java:240)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:466)
at org.eclipse.swt.custom.SashFormLayout.layout(SashFormLayout. java:188)
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.jav a:1097)
at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:9 34)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:438)
at org.eclipse.ui.part.PageBook$PageBookLayout.layout(PageBook. java:59)
at org.eclipse.swt.layout.FillLayout.layout(FillLayout.java:159 )
at org.eclipse.ui.internal.LayoutPart.setBounds(LayoutPart.java :319)
at
org.eclipse.ui.internal.presentations.PresentablePart.setBou nds(PresentablePart.java:118)
at
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.layoutContent(PresentablePartFolder.java:131)
at
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.layout(PresentablePartFolder.java:401)
at
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.setBounds(PresentablePartFolder.java:256)
at
org.eclipse.ui.internal.presentations.newapi.TabbedStackPres entation.setBounds(TabbedStackPresentation.java:203)
at org.eclipse.ui.internal.PartStack.setBounds(PartStack.java:9 94)
at org.eclipse.ui.internal.LayoutTree.doSetBounds(LayoutTree.ja va:543)
at org.eclipse.ui.internal.LayoutTree.setBounds(LayoutTree.java :534)
at
org.eclipse.ui.internal.LayoutTreeNode.doSetBounds(LayoutTre eNode.java:520)
at
org.eclipse.ui.internal.LayoutTreeNode.doSetBounds(LayoutTre eNode.java:519)
at
org.eclipse.ui.internal.LayoutPartSash.widgetSelected(Layout PartSash.java:263)
at
org.eclipse.ui.internal.LayoutPartSash.access$1(LayoutPartSa sh.java:246)
at
org.eclipse.ui.internal.LayoutPartSash$1.widgetSelected(Layo utPartSash.java:60)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1005)
at org.eclipse.swt.widgets.Sash.gtk_motion_notify_event(Sash.ja va:358)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1338)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3241 )
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive
Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1095)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2395)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1569)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1540)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
Dynamic libraries:
08048000-08056000 r-xp 00000000 03:03 215895
/home/emerson/j2sdk1.4.2_05/bin/java
08056000-08059000 rwxp 0000d000 03:03 215895
40000000-40016000 r-xp 00000000 03:03 8018 /lib/ld-2.3.3.so
40016000-40018000 rwxp 00015000 03:03 8018 /lib/ld-2.3.3.so
40035000-40043000 r-xp 00000000 03:03 8045 /lib/tls/libpthread.so.0
40043000-40045000 rwxp 0000d000 03:03 8045 /lib/tls/libpthread.so.0
40047000-40049000 r-xp 00000000 03:03 8027 /lib/libdl.so.2
40049000-4004b000 rwxp 00001000 03:03 8027 /lib/libdl.so.2
4004b000-4015a000 r-xp 00000000 03:03 8043 /lib/tls/libc.so.6
4015a000-4015b000 ---p 0010f000 03:03 8043 /lib/tls/libc.so.6
4015b000-4015c000 r-xp 0010f000 03:03 8043 /lib/tls/libc.so.6
4015c000-4015f000 rwxp 00110000 03:03 8043 /lib/tls/libc.so.6
40162000-4055e000 r-xp 00000000 03:03 194025
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so
4055e000-40579000 rwxp 003fb000 03:03 194025
4058b000-40593000 r-xp 00000000 03:03 194019
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/native_threads/libh pi.so
40593000-40594000 rwxp 00007000 03:03 194019
405a7000-405b9000 r-xp 00000000 03:03 8030 /lib/libnsl.so.1
405b9000-405bb000 rwxp 00011000 03:03 8030 /lib/libnsl.so.1
405bd000-405de000 r-xp 00000000 03:03 8044 /lib/tls/libm.so.6
405de000-405e0000 rwxp 00020000 03:03 8044 /lib/tls/libm.so.6
405e0000-40615000 r-xs 00000000 03:03 47281 /var/run/nscd/passwd
40615000-40619000 rwxs 00000000 03:03 313973
/tmp/hsperfdata_emerson/27403
40619000-40629000 r-xp 00000000 03:03 194030
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libverify.so
40629000-4062b000 rwxp 0000f000 03:03 194030
4062b000-4064b000 r-xp 00000000 03:03 194031
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libjava.so
4064b000-4064d000 rwxp 0001f000 03:03 194031
4064d000-40661000 r-xp 00000000 03:03 194033
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libzip.so
40661000-40664000 rwxp 00013000 03:03 194033
40664000-42008000 r-xs 00000000 03:03 215888
/home/emerson/j2sdk1.4.2_05/jre/lib/rt.jar
42052000-42068000 r-xs 00000000 03:03 194060
/home/emerson/j2sdk1.4.2_05/jre/lib/sunrsasign.jar
42068000-42145000 r-xs 00000000 03:03 215482
/home/emerson/j2sdk1.4.2_05/jre/lib/jsse.jar
42145000-42156000 r-xs 00000000 03:03 194061
/home/emerson/j2sdk1.4.2_05/jre/lib/jce.jar
42156000-426af000 r-xs 00000000 03:03 215596
/home/emerson/j2sdk1.4.2_05/jre/lib/charsets.jar
44757000-4475c000 r-xs 00000000 03:03 288272
/home/emerson/eclipse/startup.jar
4475c000-4475e000 r-xp 00000000 03:03 25149
/opt/gnome/lib/pango/1.4.0/modules/pango-basic-fc.so
4475e000-4475f000 rwxp 00001000 03:03 25149
4c963000-4c996000 r-xp 00000000 03:03 12095
/usr/lib/locale/en_US.utf8/LC_CTYPE
4c996000-4c99c000 r-xs 00000000 03:03 8589
/usr/lib/gconv/gconv-modules.cache
4cba0000-4cba3000 r-xs 00000000 03:03 194057
/home/emerson/j2sdk1.4.2_05/jre/lib/ext/dnsns.jar
4cba3000-4cbbf000 r-xs 00000000 03:03 194056
/home/emerson/j2sdk1.4.2_05/jre/lib/ext/sunjce_provider.jar
4cbbf000-4cbcc000 r-xs 00000000 03:03 194059
/home/emerson/j2sdk1.4.2_05/jre/lib/ext/ldapsec.jar
4cbcc000-4cc88000 r-xs 00000000 03:03 215597
/home/emerson/j2sdk1.4.2_05/jre/lib/ext/localedata.jar
4cd09000-4cd41000 r-xs 00000000 03:03 193741
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/core.ja r
4cd41000-4cd49000 r-xs 00000000 03:03 193742
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/console .jar
4cd49000-4cd55000 r-xs 00000000 03:03 193744
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/osgi.ja r
4cd55000-4cd6b000 r-xs 00000000 03:03 193743
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/resolve r.jar
4cd6b000-4cd81000 r-xs 00000000 03:03 193746
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/default Adaptor.jar
4cd81000-4cda0000 r-xs 00000000 03:03 193745
/home/emerson/eclipse/plugins/org.eclipse.osgi_3.1.0/eclipse Adaptor.jar
4cea2000-4cf03000 r-xs 00000000 03:03 205397
/home/emerson/eclipse/plugins/org.eclipse.core.runtime_3.1.0 /runtime.jar
4cf03000-4cf13000 r-xp 00000000 03:03 194036
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libnet.so
4cf13000-4cf14000 rwxp 0000f000 03:03 194036
4cf14000-4cf1a000 r-xp 00000000 03:03 194037
/home/emerson/j2sdk1.4.2_05/jre/lib/i386/libnio.so
4cf1a000-4cf1b000 rwxp 00005000 03:03 194037
4cf1b000-4cf30000 r-xs 00000000 03:03 288009
/home/emerson/eclipse/plugins/org.eclipse.core.runtime.compa tibility_3.0.0/compatibility.jar
4cf30000-4cf46000 r-xs 00000000 03:03 205414
/home/emerson/eclipse/plugins/org.eclipse.update.configurato r_3.0.0/configurator.jar
4cfc7000-4d047000 r-xs 00000000 03:03 313976 /tmp/jar_cache62790.tmp
(deleted)
4d047000-4d1a1000 r-xs 00000000 03:03 204909
/home/emerson/eclipse/plugins/org.eclipse.ui.ide_3.1.0/ide.j ar
4d1a1000-4d1a2000 r-xs 00000000 03:03 288016
/home/emerson/eclipse/plugins/org.eclipse.ui.workbench.compa tibility_3.1.0/compatibility.jar
4d1a2000-4d414000 r-xs 00000000 03:03 196462
/home/emerson/eclipse/plugins/org.eclipse.ui.workbench_3.1.0 /workbench.jar
4d414000-4d498000 r-xs 00000000 03:03 203317
/home/emerson/eclipse/plugins/org.eclipse.jface_3.1.0/jface. jar
4d498000-4d4a5000 r-xs 00000000 03:03 287828
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/ws/g tk/swt-mozilla.jar
4d4a5000-4d4c0000 r-xs 00000000 03:03 287827
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/ws/g tk/swt-pi.jar
4d4c0000-4d5af000 r-xs 00000000 03:03 287829
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/ws/g tk/swt.jar
4d5af000-4d5b1000 r-xs 00000000 03:03 193436
/home/emerson/eclipse/plugins/org.eclipse.ui_3.1.0/ui.jar
4d5b1000-4d5f1000 r-xp 00000000 03:03 287836
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/os/l inux/x86/libswt-pi-gtk-3116.so
4d5f1000-4d5f3000 rwxp 00040000 03:03 287836
4d5f3000-4d5f4000 r-xp 00000000 03:03 9295
/usr/lib/locale/en_US.utf8/LC_IDENTIFICATION
4d5f4000-4d5f5000 r-xp 00000000 03:03 11862
/usr/lib/locale/en_US.utf8/LC_MEASUREMENT
4d5f5000-4d5f6000 r-xp 00000000 03:03 9298
/usr/lib/locale/en_US.utf8/LC_TELEPHONE
4d5f6000-4d5f7000 r-xp 00000000 03:03 9294
/usr/lib/locale/en_US.utf8/LC_ADDRESS
4d5f7000-4d5f8000 r-xp 00000000 03:03 9297
/usr/lib/locale/en_US.utf8/LC_NAME
4d5f8000-4d5f9000 r-xp 00000000 03:03 11898
/usr/lib/locale/en_US.utf8/LC_PAPER
4d5f9000-4d5fa000 r-xp 00000000 03:03 12060
/usr/lib/locale/en_US.utf8/LC_MESSAGES/SYS_LC_MESSAGES
4d5fa000-4d5fb000 r-xp 00000000 03:03 9296
/usr/lib/locale/en_US.utf8/LC_MONETARY
4d5fb000-4d5fd000 r-xp 00000000 03:03 174285
/home/emerson/eclipse/plugins/org.eclipse.core.resources.lin ux_3.0.0/os/linux/x86/libcore_3_1_0.so
4d5fd000-4d5fe000 rwxp 00001000 03:03 174285
4d5fe000-4d60d000 r-xs 00000000 03:03 287855
/home/emerson/eclipse/plugins/org.eclipse.help_3.0.0/help.ja r
4d60f000-4d8c9000 r-xp 00000000 03:03 42377
/opt/gnome/lib/libgtk-x11-2.0.so.0.400.9
4d8c9000-4d8d2000 rwxp 002ba000 03:03 42377
4d8d5000-4d8d8000 r-xp 00000000 03:03 8309
/opt/gnome/lib/libgthread-2.0.so.0.400.6
4d8d8000-4d8d9000 rwxp 00003000 03:03 8309
4d8d9000-4d8de000 r-xp 00000000 03:03 16431
/usr/X11R6/lib/libXtst.so.6.1
4d8de000-4d8df000 rwxp 00004000 03:03 16431
4d8df000-4d8f3000 r-xp 00000000 03:03 42373
/opt/gnome/lib/libgdk_pixbuf-2.0.so.0.400.9
4d8f3000-4d8f4000 rwxp 00013000 03:03 42373
4d8f4000-4d95e000 r-xp 00000000 03:03 42371
/opt/gnome/lib/libgdk-x11-2.0.so.0.400.9
4d95e000-4d963000 rwxp 00069000 03:03 42371
4d963000-4da5b000 r-xp 00000000 03:03 16387
/usr/X11R6/lib/libX11.so.6.2
4da5b000-4da5f000 rwxp 000f7000 03:03 16387
4da5f000-4da63000 r-xp 00000000 03:03 22378
/opt/gnome/lib/libpangoxft-1.0.so.0.400.1
4da63000-4da64000 rwxp 00003000 03:03 22378
4da64000-4da6e000 r-xp 00000000 03:03 22376
/opt/gnome/lib/libpangox-1.0.so.0.400.1
4da6e000-4da6f000 rwxp 0000a000 03:03 22376
4da6f000-4da9e000 r-xp 00000000 03:03 22372
/opt/gnome/lib/libpango-1.0.so.0.400.1
4da9e000-4daa3000 rwxp 0002e000 03:03 22372
4daa3000-4dabc000 r-xp 00000000 03:03 12424
/opt/gnome/lib/libatk-1.0.so.0.600.0
4dabc000-4dabe000 rwxp 00018000 03:03 12424
4dabe000-4daf6000 r-xp 00000000 03:03 8307
/opt/gnome/lib/libgobject-2.0.so.0.400.6
4daf6000-4daf8000 rwxp 00037000 03:03 8307
4daf8000-4dafb000 r-xp 00000000 03:03 8305
/opt/gnome/lib/libgmodule-2.0.so.0.400.6
4dafb000-4dafc000 rwxp 00002000 03:03 8305
4dafc000-4db7a000 r-xp 00000000 03:03 8303
/opt/gnome/lib/libglib-2.0.so.0.400.6
4db7a000-4db7b000 rwxp 0007e000 03:03 8303
4db7b000-4db88000 r-xp 00000000 03:03 16403
/usr/X11R6/lib/libXext.so.6.4
4db88000-4db89000 rwxp 0000d000 03:03 16403
4db89000-4db8c000 r-xp 00000000 03:03 16424
/usr/X11R6/lib/libXrandr.so.2.0
4db8c000-4db8d000 rwxp 00002000 03:03 16424
4db8d000-4db94000 r-xp 00000000 03:03 16412
/usr/X11R6/lib/libXi.so.6.0
4db94000-4db95000 rwxp 00006000 03:03 16412
4db95000-4dba7000 r-xp 00000000 03:03 16410
/usr/X11R6/lib/libXft.so.2.1.2
4dba7000-4dba8000 rwxp 00011000 03:03 16410
4dba8000-4dc10000 r-xp 00000000 03:03 11509
/usr/lib/libfreetype.so.6.3.7
4dc10000-4dc17000 rwxp 00068000 03:03 11509
4dc17000-4dc3c000 r-xp 00000000 03:03 12409
/usr/lib/libfontconfig.so.1.0.4
4dc3c000-4dc40000 rwxp 00025000 03:03 12409
4dc41000-4dc49000 r-xp 00000000 03:03 16399
/usr/X11R6/lib/libXcursor.so.1.0.2
4dc49000-4dc4a000 rwxp 00007000 03:03 16399
4dc4a000-4dc51000 r-xp 00000000 03:03 16426
/usr/X11R6/lib/libXrender.so.1.2.2
4dc51000-4dc52000 rwxp 00006000 03:03 16426
4dc52000-4dc76000 r-xp 00000000 03:03 22374
/opt/gnome/lib/libpangoft2-1.0.so.0.400.1
4dc76000-4dc77000 rwxp 00024000 03:03 22374
4dc77000-4dc94000 r-xp 00000000 03:03 8082 /usr/lib/libexpat.so.0.5.0
4dc94000-4dc96000 rwxp 0001d000 03:03 8082 /usr/lib/libexpat.so.0.5.0
4dc96000-4dd6e000 r-xp 00000000 03:03 12096
/usr/lib/locale/en_US.utf8/LC_COLLATE
4dd6e000-4dd6f000 r-xp 00000000 03:03 9300
/usr/lib/locale/en_US.utf8/LC_TIME
4dd6f000-4dd70000 r-xp 00000000 03:03 12072
/usr/lib/locale/en_US.utf8/LC_NUMERIC
4dd70000-4dd71000 r-xp 00000000 03:03 13165
/usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
4dd71000-4dd72000 rwxp 00000000 03:03 13165
4dd72000-4dd73000 r-xp 00000000 03:03 8534
/usr/lib/gconv/ISO8859-1.so
4dd73000-4dd75000 rwxp 00000000 03:03 8534
4dd75000-4dd9b000 r-xp 00000000 03:03 287834
/home/emerson/eclipse/plugins/org.eclipse.swt.gtk_3.1.0/os/l inux/x86/libswt-gtk-3116.so
4dd9b000-4dd9d000 rwxp 00025000 03:03 287834
4dd9e000-4ddb8000 r-xp 00000000 03:03 14507
/opt/gnome/lib/gtk-2.0/2.4.0/engines/libqtengine.so
4ddb8000-4ddb9000 rwxp 0001a000 03:03 14507
4ddb9000-4e473000 r-xp 00000000 03:03 41752
/usr/lib/qt3/lib/libqt-mt.so.3.3.3
4e473000-4e4b4000 rwxp 006ba000 03:03 41752
4e4b7000-4e4bc000 r-xs 00000000 03:03 213430
/home/emerson/jakarta-tomcat-5.0.28/server/lib/catalina-ant. jar
4e4c5000-4e4d3000 r-xs 00000000 03:03 288111
/home/emerson/eclipse/plugins/org.eclipse.ui.views_3.1.0/vie ws.jar
4e4d3000-4e500000 r-xp 00000000 03:03 12629 /usr/lib/libpng.so.3.1.2.6
4e500000-4e501000 rwxp 0002d000 03:03 12629 /usr/lib/libpng.so.3.1.2.6
4e501000-4e511000 r-xp 00000000 03:03 12363 /lib/libz.so.1.2.1
4e511000-4e512000 rwxp 0000f000 03:03 12363 /lib/libz.so.1.2.1
4e512000-4e519000 r-xp 00000000 03:03 16384
/usr/X11R6/lib/libSM.so.6.0
4e519000-4e51a000 rwxp 00007000 03:03 16384
4e51a000-4e52f000 r-xp 00000000 03:03 16382
/usr/X11R6/lib/libICE.so.6.3
4e52f000-4e530000 rwxp 00014000 03:03 16382
4e532000-4e5e5000 r-xp 00000000 03:03 12641
/usr/lib/libstdc++.so.5.0.7
4e5e5000-4e5ea000 rwxp 000b3000 03:03 12641
4e5ef000-4e5f6000 r-xp 00000000 03:03 9054 /lib/libgcc_s.so.1
4e5f6000-4e5f7000 rwxp 00006000 03:03 9054 /lib/libgcc_s.so.1
4e5f7000-4e661000 r-xp 00000000 03:03 45255
/usr/lib/qt3/plugins/styles/thinkeramik.so
4e661000-4e664000 rwxp 00069000 03:03 45255
4e664000-4e672000 r-xp 00000000 03:03 52153
/usr/X11R6/lib/X11/fonts/truetype/SUSESans-Roman.ttf
4e672000-4e6a2000 rwxs 00000000 00:06 241139734 /SYSV00000000 (deleted)
4e6a2000-4e74a000 r-xs 00000000 03:03 287914
/home/emerson/eclipse/plugins/org.eclipse.core.resources_3.1 .0/resources.jar
4e74a000-4e7b9000 r-xs 00000000 03:03 290994
/home/emerson/eclipse/plugins/org.eclipse.wst.xml.ui_1.0.0/x mleditor.jar
4e7b9000-4e857000 r-xs 00000000 03:03 174301
/home/emerson/eclipse/plugins/org.eclipse.jface.text_3.1.0/j facetext.jar
4e857000-4e8b4000 r-xs 00000000 03:03 203322
/home/emerson/eclipse/plugins/org.eclipse.ui.editors_3.1.0/e ditors.jar
4e8b4000-4e8e0000 r-xs 00000000 03:03 193736
/home/emerson/eclipse/plugins/org.eclipse.text_3.1.0/text.ja r
4e8e0000-4e980000 r-xs 00000000 03:03 291968
/home/emerson/eclipse/plugins/org.eclipse.wst.sse.ui_1.0.0/e ditor.jar
4e980000-4e9e2000 r-xs 00000000 03:03 220314
/home/emerson/eclipse/plugins/org.eclipse.ui.workbench.texte ditor_3.1.0/texteditor.jar
4e9e2000-4ea2d000 r-xs 00000000 03:03 293201
/home/emerson/eclipse/plugins/org.eclipse.wst.sse.core_1.0.0 /model.jar
4ea2d000-4ea3f000 r-xs 00000000 03:03 193937
/home/emerson/eclipse/plugins/org.eclipse.core.filebuffers_3 .1.0/filebuffers.jar
4ea3f000-4ea65000 r-xs 00000000 03:03 291870
/home/emerson/eclipse/plugins/org.eclipse.wst.common.content model_1.0.0/contentmodel.jar
4ea65000-4ea7c000 r-xs 00000000 03:03 291843
/home/emerson/eclipse/plugins/org.eclipse.wst.common.ui_1.0. 0/ui.jar
4ea7c000-4eab0000 r-xs 00000000 03:03 205420
/home/emerson/eclipse/plugins/org.eclipse.team.core_3.1.0/te am.jar
4eab0000-4eaba000 r-xs 00000000 03:03 193756
/home/emerson/eclipse/plugins/org.eclipse.ant.core_3.1.0/ant support.jar
4eaba000-4eb09000 r-xs 00000000 03:03 293299
/home/emerson/eclipse/plugins/org.eclipse.wst.xml.core_1.0.0 /xmlmodel.jar
4eb09000-4eb19000 r-xs 00000000 03:03 291239
/home/emerson/eclipse/plugins/org.eclipse.wst.common.encodin g_1.0.0/encodingresource.jar
4eb19000-4ebdf000 r-xs 00000000 03:03 196494
/home/emerson/eclipse/plugins/org.eclipse.ant.ui_3.1.0/antui .jar
4ebdf000-4ebe6000 r-xs 00000000 03:03 293367
/home/emerson/eclipse/plugins/org.eclipse.wst.xml.uriresolve r_1.0.0/xmlcatalog.jar
4ec67000-4ec76000 r-xp 00000000 03:03 52152
/usr/X11R6/lib/X11/fonts/truetype/SUSESans-Oblique.ttf
4ec76000-4ec7c000 r-xs 00000000 03:03 288105
/home/emerson/eclipse/plugins/org.eclipse.core.variables_3.1 .0/variables.jar
4ec85000-4ecbc000 r-xs 00000000 03:03 291070
/home/emerson/eclipse/plugins/org.eclipse.wst.sse.snippets_1 .0.0/snippets.jar
4ecbc000-4eccb000 r-xs 00000000 03:03 291879
/home/emerson/eclipse/plugins/org.eclipse.wst.dtd.ui_1.0.0/d tdeditor.jar
4eccb000-4ece3000 r-xp 00000000 03:03 50214
/usr/share/ghostscript/fonts/n022003l.pfb
4ecee000-4ecfb000 r-xs 00000000 03:03 220658
/home/emerson/eclipse/plugins/org.eclipse.jdt.debug_3.1.0/jd i.jar
4ecfb000-4ed09000 r-xp 00000000 03:03 51883
/usr/X11R6/lib/X11/fonts/truetype/SUSESans-Bold.ttf
4ed09000-4ed23000 r-xs 00000000 03:03 204089
/home/emerson/eclipse/plugins/org.eclipse.ui.externaltools_3 .1.0/externaltools.jar
4ed25000-4ed34000 r-xp 00000000 03:03 51922
/usr/X11R6/lib/X11/fonts/truetype/SUSESans-BoldOblique.ttf
4ed34000-4ed40000 r-xs 00000000 03:03 291867
/home/emerson/eclipse/plugins/org.eclipse.wst.dtd.parser_1.0 .0/dtdparser.jar
4ed41000-4ee51000 r-xs 00000000 03:03 205032
/home/emerson/eclipse/plugins/org.eclipse.debug.ui_3.1.0/dtu i.jar
4ee51000-4ee89000 r-xs 00000000 03:03 203311
/home/emerson/eclipse/plugins/org.eclipse.debug.core_3.1.0/d tcore.jar
4ee89000-4ef5e000 r-xs 00000000 03:03 290806
/home/emerson/eclipse/plugins/org.eclipse.gef_3.1.0/gef.jar
4ef5e000-4efb5000 r-xs 00000000 03:03 287959
/home/emerson/eclipse/plugins/org.eclipse.search_3.1.0/searc h.jar
4f0b7000-4f0d6000 r-xs 00000000 03:03 290442
/home/emerson/eclipse/plugins/org.eclipse.emf.common_2.1.0/r untime/common.jar
4f0d6000-4f1cb000 r-xs 00000000 03:03 47334
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant.j ar
4f1cb000-4f1cd000 r-xs 00000000 03:03 47169
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a ntlr.jar
4f1cd000-4f1d0000 r-xs 00000000 03:03 47168
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-bcel.jar
4f1d0000-4f1d4000 r-xs 00000000 03:03 47155
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-bsf.jar
4f1d4000-4f1d5000 r-xs 00000000 03:03 47166
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-log4j.jar
4f1d5000-4f1e1000 r-xs 00000000 03:03 47158
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-oro.jar
4f1e1000-4f1e2000 r-xs 00000000 03:03 47152
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-regexp.jar
4f1e2000-4f1e3000 r-xs 00000000 03:03 47172
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-a pache-resolver.jar
4f1e3000-4f1e4000 r-xs 00000000 03:03 47162
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-c ommons-logging.jar
4f1e4000-4f1ed000 r-xs 00000000 03:03 47157
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-c ommons-net.jar
4f1ed000-4f1f0000 r-xs 00000000 03:03 47153
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-i contract.jar
4f1f0000-4f1f6000 r-xs 00000000 03:03 47160
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j ai.jar
4f1f6000-4f1f8000 r-xs 00000000 03:03 47193
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j avamail.jar
4f1f8000-4f1fa000 r-xs 00000000 03:03 47165
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j depend.jar
4f1fa000-4f1fc000 r-xs 00000000 03:03 47161
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j mf.jar
4f1fc000-4f202000 r-xs 00000000 03:03 47156
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j sch.jar
4f202000-4f214000 r-xs 00000000 03:03 47173
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-j unit.jar
4f214000-4f217000 r-xs 00000000 03:03 47185
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-l auncher.jar
4f217000-4f21a000 r-xs 00000000 03:03 47167
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-n etrexx.jar
4f21a000-4f27e000 r-xs 00000000 03:03 47159
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-n odeps.jar
4f27e000-4f287000 r-xs 00000000 03:03 47154
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-s tarteam.jar
4f287000-4f288000 r-xs 00000000 03:03 47164
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-s tylebook.jar
4f288000-4f28a000 r-xs 00000000 03:03 47186
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-s wing.jar
4f28a000-4f29b000 r-xs 00000000 03:03 47170
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-t rax.jar
4f29b000-4f2a7000 r-xs 00000000 03:03 47230
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-v aj.jar
4f2a7000-4f2ab000 r-xs 00000000 03:03 47180
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-w eblogic.jar
4f2ab000-4f2ad000 r-xs 00000000 03:03 47224
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-x alan1.jar
4f2ad000-4f2ae000 r-xs 00000000 03:03 47171
/home/emerson/eclipse/plugins/org.apache.ant_1.6.2/lib/ant-x slp.jar
4f2ae000-4f2b9000 r-xp 00000000 03:03 52159
/usr/X11R6/lib/X11/fonts/truetype/SUSESansMono-Roman.ttf
4f2cc000-4f379000 r-xs 00000000 03:03 220659
/home/emerson/eclipse/plugins/org.eclipse.jdt.debug_3.1.0/jd imodel.jar
4f379000-4f6a2000 r-xs 00000000 03:03 196334
/home/emerson/eclipse/plugins/org.eclipse.jdt.core_3.1.0/jdt core.jar
4f723000-4fcbe000 r-xs 00000000 03:03 203413
/home/emerson/eclipse/plugins/org.eclipse.jdt.ui_3.1.0/jdt.j ar
4fcbe000-4fcd7000 r-xs 00000000 03:03 287954
/home/emerson/eclipse/plugins/org.eclipse.ltk.core.refactori ng_3.1.0/refcore.jar
4fd58000-50234000 r-xs 00000000 03:03 217054
/home/emerson/j2sdk1.4.2_05/lib/tools.jar
50234000-50236000 r-xs 00000000 03:03 212344
/home/emerson/eclipse/plugins/org.eclipse.pde.ui_3.1.0/pdeui ant.jar
50236000-5023b000 r-xs 00000000 03:03 287868
/home/emerson/eclipse/plugins/org.eclipse.pde.build_3.1.0/li b/pdebuild-ant.jar
5023b000-5023d000 r-xs 00000000 03:03 204862
/home/emerson/eclipse/plugins/org.eclipse.pde_3.1.0/ant_task s/pde-ant.jar
5023d000-5023f000 r-xs 00000000 03:03 287916
/home/emerson/eclipse/plugins/org.eclipse.core.resources_3.1 .0/ant_tasks/resources-ant.jar
5023f000-50242000 r-xs 00000000 03:03 196335
/home/emerson/eclipse/plugins/org.eclipse.jdt.core_3.1.0/jdt CompilerAdapter.jar
50242000-50246000 r-xs 00000000 03:03 196493
/home/emerson/eclipse/plugins/org.eclipse.ant.ui_3.1.0/lib/a ntrunner.jar
50246000-50251000 r-xs 00000000 03:03 196492
/home/emerson/eclipse/plugins/org.eclipse.ant.ui_3.1.0/lib/r emoteAnt.jar
50251000-50259000 r-xs 00000000 03:03 193755
/home/emerson/eclipse/plugins/org.eclipse.ant.core_3.1.0/lib /antsupportlib.jar
503dc000-503f8000 r-xp 00000000 03:03 50222
/usr/share/ghostscript/fonts/n022024l.pfb
503f8000-50400000 r-xp 00000000 03:03 8033 /lib/libnss_files.so.2
50400000-50402000 rwxp 00007000 03:03 8033 /lib/libnss_files.so.2
50402000-5041f000 r-xs 00000000 03:03 196341
/home/emerson/eclipse/plugins/org.eclipse.ui.console_3.1.0/c onsole.jar
5041f000-5042c000 r-xs 00000000 03:03 193762
/home/emerson/eclipse/plugins/org.eclipse.core.expressions_3 .1.0/expressions.jar
5042c000-5048c000 rwxs 00000000 00:06 248021012 /SYSV00000000 (deleted)
5060f000-50615000 r-xs 00000000 03:03 291965
/home/emerson/eclipse/plugins/org.eclipse.wst.dtd.contentmod el_1.0.0/cmdtd.jar
50615000-5061b000 r-xs 00000000 03:03 193883
/home/emerson/eclipse/plugins/org.eclipse.update.scheduler_3 .0.0/scheduler.jar
5061b000-506ab000 r-xs 00000000 03:03 290435
/home/emerson/eclipse/plugins/org.eclipse.emf.ecore_2.1.0/ru ntime/ecore.jar
506ab000-506b0000 r-xs 00000000 03:03 293371
/home/emerson/eclipse/plugins/org.eclipse.wst.internet.proxy _1.0.0/runtime/ipproxy.jar
506b0000-506dc000 r-xs 00000000 03:03 291620
/home/emerson/eclipse/plugins/org.eclipse.wst.dtd_1.0.0/dtdm odel.jar
506f8000-506fc000 r-xp 00000000 03:03 8032 /lib/libnss_dns.so.2
506fc000-506fe000 rwxp 00003000 03:03 8032 /lib/libnss_dns.so.2
50800000-5080f000 r-xp 00000000 03:03 8039 /lib/libresolv.so.2
5080f000-50811000 rwxp 0000e000 03:03 8039 /lib/libresolv.so.2
Heap at VM Abort:
Heap
def new generation total 1152K, used 765K [0x44760000, 0x448a0000,
0x44c40000)
eden space 1024K, 66% used [0x44760000, 0x44809668, 0x44860000)
from space 128K, 68% used [0x44860000, 0x44875e80, 0x44880000)
to space 128K, 0% used [0x44880000, 0x44880000, 0x448a0000)
tenured generation total 14528K, used 8715K [0x44c40000, 0x45a70000,
0x48760000)
the space 14528K, 59% used [0x44c40000, 0x454c2db0, 0x454c2e00,
0x45a70000)
compacting perm gen total 21248K, used 21003K [0x48760000, 0x49c20000,
0x4c760000)
the space 21248K, 98% used [0x48760000, 0x49be2f80, 0x49be3000,
0x49c20000)
Local Time = Tue Jan 18 15:22:25 2005
Elapsed Time = 40
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_05-b04 mixed mode)
Steve Northover wrote:
> Can you tell us the nature of the crashes? Was it in and around the
> org.eclipse.swt.program.Program class?
> "emerson" <emerson@tre-sc.gov.br> wrote in message
> news:ct3695$du0$1@www.eclipse.org...
>> Thanks
>> Emerson
Current Time: Thu Apr 25 16:14:07 GMT 2024
Powered by FUDForum. Page generated in 0.03596 seconds
