How to make SWT application appear in task bar on Windows XP [message #449331] |
Fri, 21 January 2005 21:15 |
Originally posted by: daya.sharma.gmail.com
Hi All
I have developed a SWT application. When I run it I donot see it in the
Windows Task Bar, the only way I can see the application is using ALT-TAB
keys or if code specifically for a system tray item.
final Tray tray = Display.getDefault().getSystemTray();
trayItem = new TrayItem(tray, SWT.Show);
But using system tray item as the primary indicator for a running
application is just not feasible.
Can anyone please help me?
thanks
-daya
Re: How to make SWT application appear in task bar on Windows XP [message #449442 is a reply to message #449362] |
Mon, 24 January 2005 17:25 |
Hi Steve
My main class extends org.eclipse.jface.window.ApplicationWindow which
accepts a shell parameter in its constructor and doesn't give me much
control in terms of taskbar. Here is the code snippet...
public class BaseJFace extends ApplicationWindow {
final Display display = Display.getDefault();
shell = new Shell(display);
// I can add the TrayItem code here....
BaseJFace baseJFace = new BaseJFace(shell);
baseJFace.setBlockOnOpen(true);
baseJFace.open();
display.dispose();
public BaseJFace(Shell shell) {
super(shell);
However if I do something like this
Display display = new Display();
Image large = new Image(display, 32, 32);
gc = new GC(large);
gc.setBackground(display.getSystemColor(SWT.COLOR_RED));
gc.fillArc(0, 0, 32, 32, 45, 270);
gc.dispose();
Shell shell = new Shell(display);
shell.setText("Large icons");
shell.setImages(new Image[] {large});
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
I can see the shell in taskbar, the key difference here is shell.open().
So my understanding is that the ApplicationWindow creates a new instance
of shell somewhere and since the parent shell was never opened, it doesn't
show up in the taskbar.
Lemme know yor thoughts...
-daya
Steve Northover wrote:
> Don't use the system tray. Do you have a small stand alone snippet that
> shows the problem?
> "Day" <daya.sharma@gmail.com> wrote in message
> news:csrrdp$3uj$1@www.eclipse.org...
>> Hi All
>> thanks
>> -daya
Re: How to make SWT application appear in task bar on Windows XP [message #449508 is a reply to message #449442] |
Tue, 25 January 2005 15:10 |
Steve Northover Messages: 1636 Registered: July 2009 |
The problem is that the shell in the first example is a dialog shell (a
shell whose parent is another shell). Dialog shells don't appear in the
task list.
"Daya Sharma" <daya.sharma@gmail.com> wrote in message
news:ct3b2h$77c$1@www.eclipse.org...
> Hi Steve
> public static void main(String[] args) {
> baseJFace.open();
> display.dispose();
> super(shell);
> gc = new GC(large);
> gc.dispose();
> shell.open();
> display.sleep();
> -daya
> > shows the problem?
> >> Hi All
ALT-TAB
> >> thanks
> >> -daya
Re: How to make SWT application appear in task bar on Windows XP [message #449516 is a reply to message #449508] |
Tue, 25 January 2005 16:14 |
Thanks Steve
You are right, also I figured out that all I had to do was pass a null to
ApplicationWindow constructor, it would internally create a top level
shell for me if one is not already there.
this was a classic case of RTFM, sorry to bother you and thanks for all
your help.
-daya
> task list.
>> Hi Steve
>> baseJFace.open();
>> display.dispose();
>> super(shell);
>> gc = new GC(large);
>> gc.dispose();
>> shell.open();
>> display.sleep();
>> -daya
>> > shows the problem?
>> >> Hi All
> ALT-TAB
>> >> thanks
>> >> -daya
FUDForum. Page generated in 0.03691 seconds
