Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT HTML browser component
SWT HTML browser component [message #449137] Tue, 18 January 2005 18:52 Go to next message
Originally posted by: sylcheung.gmail.com
In SWT, there is a HTML browser component. Can someone please tell me
if I can walk thru the dom in my Java application which uses that HTML
browser component?
Thank you.
Sam
Re: SWT HTML browser component [message #449141 is a reply to message #449137] Tue, 18 January 2005 18:55 Go to previous messageGo to next message
Henning Rogge is currently offline Henning RoggeFriend
> browser component?
Look at
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/dev.html#snippets
The "browser" snipplets might be usefull for you.
Henning.
Re: SWT HTML browser component [message #449155 is a reply to message #449141] Tue, 18 January 2005 22:02 Go to previous messageGo to next message
Thanks.
But I am looking for a way to walk thru the dom in my JavaApplication
not just using JavaScript.
Let's say I want my JavaApplication to display all the Forms name in the
html page I load using SWT html browser. How can I achieve that?
Thank you.
>> browser component?
> Look at
> Henning.
Re: SWT HTML browser component [message #449177 is a reply to message #449155] Tue, 18 January 2005 23:55 Go to previous messageGo to next message
Hugo A. Garcia is currently offline Hugo A. GarciaFriend
You could use JDOM. For more information go to http://www.jdon.org
-H
> Thanks.
> Thank you.
>>> me if I can walk thru the dom in my Java application which uses that
>>> HTML browser component?
>> Look at
>> Henning.
Re: SWT HTML browser component [message #449179 is a reply to message #449177] Wed, 19 January 2005 00:05 Go to previous messageGo to next message
http://www.jdom.org sorry for the typo.
> -H
>> Thanks.
>> the html page I load using SWT html browser. How can I achieve that?
>> Thank you.
>>> Look at
>>> Henning.
Re: SWT HTML browser component [message #449194 is a reply to message #449155] Wed, 19 January 2005 03:42 Go to previous messageGo to next message
Bernhard Fastenrath is currently offline Bernhard FastenrathFriend
> Thanks.
http://jrex.mozdev.org/ can do that but it's not an SWT widget
and it seemed unstable last time I tried it.
You could wrap a minimal JavaScript implementation into your own
Java set/query API. Finding forms and collecting their names could
still be quite efficient while exporting the whole DOM tree this
way might be a bit slow.
> Thank you.
>> Look at
>> Henning.
Re: SWT HTML browser component [message #449195 is a reply to message #449177] Wed, 19 January 2005 03:49 Go to previous messageGo to next message
> -H
That's an XML parsing API which wouldn't even be usable as a
preprocessor for most HTML pages in case you were trying to
suggest to parse the page before feeding it to the browser.
Accessing the DOM tree of the browser is, for example,
possible through
http://www.alphaworks.ibm.com/aw.nsf/html/weblets or
Re: SWT HTML browser component [message #449196 is a reply to message #449195] Wed, 19 January 2005 05:06 Go to previous messageGo to next message
>> -H
> possible through
Weblets seem to be obsolete.
Re: SWT HTML browser component [message #449199 is a reply to message #449195] Wed, 19 January 2005 10:45 Go to previous messageGo to next message
yes it is an XML, XHTML procesor that gives you a better document model
than DOM or if you really have to use DOM then you can easily manipute
it using JDOM. In addition, only really misbehaved HTML like that
produced by Word is a problem. You can easily apply JTidy or NekoHTML or
TagSoup to clean up the HTML before creating a DOM.
Actually... this is what I have to do in my app. Haven't implement using
the Browser widget but I still have to go through the above step
before display the documents I deal with since I have to manipulate the
document before dsiplaying. Still building the rest of the GUI so when I
get to integrating the Browser widget I can let you know.
-H
>> -H
> possible through
Re: SWT HTML browser component [message #449214 is a reply to message #449155] Wed, 19 January 2005 15:38 Go to previous message
Christophe Cornu is currently offline Christophe CornuFriend
For an example on how to get Form names through a javascript query see
below - it is adapted from snippet 160 (query DOM node value).
Chris
import org.eclipse.swt.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.browser.*;
public class PRBrowser {
public static void main(String [] args) {
final String html = "<html><body><form name='my form 1'><input
type='button' value='push me'></form><form name='my form 2'><input
type='button' value='push me 2'></form><h1 id='myid'>HTML
Document</h1></body></html>";
Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
final Browser browser = new Browser(shell, SWT.NONE);
browser.addStatusTextListener(new StatusTextListener() {
public void changed(StatusTextEvent event) {
browser.setData("query", event.text);
browser.addProgressListener(new ProgressListener() {
public void changed(ProgressEvent event) {
public void completed(ProgressEvent event) {
* Use JavaScript to query the list of Form name attributes in the
document that was loaded.
* Assign result to the window property status to pass the result to the
StatusTextListener
* This trick is required since <code>execute</code> does not return the
<code>String</code>
* directly.
boolean result =
browser.execute("window.status=document.forms.length;");
if (!result) {
/* Script may fail or may not be supported on certain platforms. */
System.out.println("Script was not executed.");
return;
String value = (String)browser.getData("query");
int length = Integer.parseInt(value);
String[] forms = new String[length];
for (int i = 0; i < forms.length; i++) {
browser.execute("window.status=document.forms["+i+"].name; ");
forms[i] = (String)browser.getData("query");
System.out.println("Form name: <"+forms[i]+">");
/* results in forms array */
/* Load an HTML document */
browser.setText(html);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Previous Topic:Traversing out of a Text widget.
Next Topic:How do you use FormLayout on a Composite with a Vertical Scrollbar?
Current Time: Mon Jul 13 06:31:58 GMT 2020
Powered by FUDForum. Page generated in 0.01766 seconds
