Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to change selection color
Re: How to change selection color [message #449081 is a reply to message #449023] |
Tue, 18 January 2005 02:20 |
Kelly Muñiz Messages: 7 Registered: July 2009 |
Junior Member |
Thank you Veronika, I was afraid of that. This presents a problem for
companies that desire to brand their apps by using their own theme (which
may not match at all the OS theme).
However, I understand the point you make. Thanks for responding so
quickly.
Veronika Irvine wrote:
> You can not change the selection colour of the Tree or Table. It is
> controlled by the theme used by the operating system. In general, it is not
> a good idea to change the colours that users associate with a specific
> meaning. For example, selection has the same colour in trees, tables, text
> widgets, lists. The selection colour is an indicator of a state. If you
> change this colour for your one application it will be confusing to the
> user.
> "Kelly "Muñiz"" <kmuniz@cisco.com> wrote in message
> news:csh5cq$5qh$1@www.eclipse.org...
>> I also would like to change the selection color on tables and trees but
>> have not figured out a way. I hope someone can help you with your
>> question.
>> I tried adding a selection listener and changing the background color on
>> the selected item but this doesn't work too well (at least for the tree
>> widget).
>> Kelly
>> Evgeni wrote:
>>> Hi all.
>>> When the table is not focused, the selected row is displayed with a light
>>> grey background. I need to change this color. Is there any simple way how
>>> to do it?
>>> I use Win2K, but I need a tip for something, what will work on any other
>>> eclipse - compatible platform too.
>>> Thanks.
>>> Evgeni.
Re: How to change selection color [message #449156 is a reply to message #449081] |
Tue, 18 January 2005 22:06 |
Bill Ewing Messages: 49 Registered: July 2009 |
Member |
> quickly.
not
>> user.
>>> Hi,
>>> question.
>>> widget).
>>> Kelly
>>> Evgeni wrote:
>>>> Hi all.
>>>> to do it?
>>>> Thanks.
>>>> Evgeni.
Re: How to change selection color [message #449157 is a reply to message #449081] |
Tue, 18 January 2005 22:10 |
Member |
We have a similar problem. We found that you can change the background
color on any row programmatically- see this website:
http://wiki.schubart.net/wiki/wiki.phtml?title=How_to_Color_ Rows_in_a_TableViewer&printable=yes
> quickly.
not
>> user.
>>> Hi,
>>> question.
>>> widget).
>>> Kelly
>>> Evgeni wrote:
>>>> Hi all.
>>>> to do it?
>>>> Thanks.
>>>> Evgeni.
Re: How to change selection color [message #449158 is a reply to message #449081] |
Member |
> quickly.
not
>> user.
>>> Hi,
>>> question.
>>> widget).
>>> Kelly
>>> Evgeni wrote:
>>>> Hi all.
>>>> to do it?
>>>> Thanks.
>>>> Evgeni.
Current Time: Sat Apr 20 05:52:40 GMT 2024
Powered by FUDForum. Page generated in 0.03038 seconds
