Home » Eclipse Projects » Standard Widget Toolkit (SWT) » path to images?
path to images? [message #448952] Sun, 16 January 2005 17:02 Go to next message
David Black is currently offline David BlackFriend
Can anyone tell me what the path (for loading etc.) to any image files I
have in my plugin?
e.g. if I have a directory icons in my plugin project, what is the path to
icons/mypic.gif
?? I cannot get anything other than a hardcoded full path to work.
cheers
David
Re: path to images? [message #448953 is a reply to message #448952] Sun, 16 January 2005 20:31 Go to previous messageGo to next message
Bo Majewski is currently offline Bo MajewskiFriend
> have in my plugin?
While the following solution is not the simplest, I prefer it to other
options. Create the following plug-in
public class MyPlugin extends AbstractUIPlugin {
private static MyPlugin instance;
public MyPlugin() {
MyPlugin.instance = this;
public static MyPlugin getDefault() {
return MyPlugin.instance;
public String getPluginId() {
return (this.getBundle().getSymbolicName());
public Image getImage(String path) {
Image img = this.getImageRegistry().get(path);
if (img == null) {
img = getImageDescriptor(path).createImage();
this.getImageRegistry().put(path, img);
return (img);
public ImageDescriptor getImageDescriptor(String path) {
ImageDescriptor desc =
AbstractUIPlugin.imageDescriptorFromPlugin(this.getPluginId( ), path);
return (desc == null? ImageDescriptor.getMissingImageDescriptor() : desc);
Now, in your code, you load images using the following code:
Image img = MyPlugin.getDefault().getImage("path/to/my/image.gif");
Images must be stored in your plug-in folder or in sub-folder. The added
benefit of this solution is that your plug-in manages loaded images and
you do not need to dispose() them. It also makes easy to load image
descriptors.
Re: path to images? [message #449021 is a reply to message #448953] Mon, 17 January 2005 21:34 Go to previous message
>>have in my plugin?
> public MyPlugin() {
> if (img == null) {
> return (img);
> descriptors.
cheers, that works great
thanks
Previous Topic:SWT Stylesheets
Next Topic:View refresh problem
Current Time: Sun Sep 20 01:20:00 GMT 2020
Powered by FUDForum. Page generated in 0.02201 seconds
