Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Stylesheets
SWT Stylesheets [message #448929] Fri, 14 January 2005 21:37 Go to next message
Avneesh Jain is currently offline Avneesh JainFriend
Is there any framework out there which brings the concept of stylesheets for
SWT. Currently my SWT code has a lot of setFont(), setBackGround(),
setForeGround() kind of calls. Is there a framework which lets one keep the
style elements sepearte from code.
Also, is there a framework which lets user create SWT views using XML. I
come from a web development background and I am looking for a Servlet:JSP ::
SWT:???? analogy. I have heard that Apache's JellySWT or XUL might be a
solution. Has anyone ever used it or knows how flexible and configurable it
is. Are these frameworks are documented well enough so that someone new can
start coding in a relatively short period of time?
Avneesh
Re: SWT Stylesheets [message #448938 is a reply to message #448929] Sat, 15 January 2005 12:06 Go to previous messageGo to next message
Stefan Zeiger is currently offline Stefan ZeigerFriend
Have a look at my Novocode Application Framework
(http://www.novocode.com/swt). It allows you to specify SWT GUIs in XML,
with the possible addition of XSLT style sheets which could be used to
separate all style elements from the GUI structure.
I've also thought about adding CSS (easier to use and more readable than
XSLT) but CSS does not separate the CSS file structure and datatypes
from the styles that can be set and from the layout model (Please
correct me if I'm wrong; I didn't find any separation in the CSS specs
which allows me to use the first layer but not the second one). I'll
probably have to create a CSS-like style language on my own.
Stefan Zeiger http://www.szeiger.de http://www.novocode.com
My SWT controls: http://www.novocode.com/swt
Re: SWT Stylesheets [message #448997 is a reply to message #448929] Mon, 17 January 2005 15:36 Go to previous messageGo to next message
Dave Orme is currently offline Dave OrmeFriend
XSWT (xswt.sourceforge.net) lets you define your GUIs in XML. It
doesn't have style sheet support yet, but there is a proposal for how to
do it and an active developer community.
Dave Orme
Visual Editor Project leader
db4objects Senior Engineer (www.db4o.com)
Essential Data Project maintainer (essentialdata.sf.net)
Re: SWT Stylesheets [message #449014 is a reply to message #448929] Mon, 17 January 2005 18:37 Go to previous messageGo to next message
Thank you Stefan and David for pointing in the right direction. I will have
a look at the two frameworks you have mentioned
Avneesh
"Avneesh Jain" <avneesh.jain@epiphany.com> wrote in message
news:cs9e1b$ji3$1@www.eclipse.org...
for
the
it
can
> Thanks
> Avneesh
Re: SWT Stylesheets [message #449016 is a reply to message #448929] Mon, 17 January 2005 19:22 Go to previous messageGo to next message
Mark Phippard is currently offline Mark PhippardFriend
> XML. I come from a web development background and I am looking for a
> Servlet:JSP :: SWT:???? analogy. I have heard that Apache's JellySWT
> or XUL might be a solution. Has anyone ever used it or knows how
> flexible and configurable it is. Are these frameworks are documented
> well enough so that someone new can start coding in a relatively
You might want to check this out:
http://www.alphaworks.ibm.com/tech/rib
Mark
Re: SWT Stylesheets [message #449017 is a reply to message #448929] Mon, 17 January 2005 19:28 Go to previous message
Originally posted by: l.mimoun.chello.fr
I personnaly developp for my project (an event driven web browser) something
that allow you to display an xml page with "html like" tag.
The aim is to obtain the same lookfield that the lookfield of a browser.
If you want, i can give you the source but you will have to work to adapt
with your projet.
"Avneesh Jain" <avneesh.jain@epiphany.com> a
Previous Topic:setLocation() problem
Next Topic:path to images?
Current Time: Fri Aug 07 10:44:07 GMT 2020
Powered by FUDForum. Page generated in 0.01600 seconds
