I'm lost with this error!!! [message #448567] |
Wed, 26 April 2006 21:42 |
Originally posted by: sebsymbol.hotmail.com
This is the log, anyone knows the problem?
!ENTRY org.eclipse.osgi 2006-04-26 23:38:20.447
!MESSAGE Bundle initial@reference:file:../Documents and Settings/Sebastián
Ávila/Mis documentos/Workspace/Jprim/ [20] was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2006-04-26 23:38:20.447
!MESSAGE Missing required bundle org.eclipse.ui.forms_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jface.text_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.workbench.texteditor_0.0.0.
!ENTRY org.eclipse.osgi 2006-04-26 23:38:20.462
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "Jprim.Application" could not be
found in the registry. The applications available are: <NONE>.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:216)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.osgi 2006-04-26 23:38:20.478
!SUBENTRY 1 org.eclipse.osgi 2006-04-26 23:38:20.478
Re: I'm lost with this error!!! [message #448569 is a reply to message #448568] |
Wed, 26 April 2006 23:03 |
Yes I know, this dependencies are included in the plugin dependencies with
others. It's strange because for example org.eclipse.ui doesn't generate
error but org.eclipse.ui.forms yes! what about the error about the path?
FUDForum. Page generated in 0.05419 seconds
