Home » Eclipse Projects » Rich Client Platform (RCP) » I'm lost with this error!!!
I'm lost with this error!!! [message #448567] Wed, 26 April 2006 21:42 Go to next message
Originally posted by: sebsymbol.hotmail.com
This is the log, anyone knows the problem?
!ENTRY org.eclipse.osgi 2006-04-26 23:38:20.447
!MESSAGE Bundle initial@reference:file:../Documents and Settings/Sebastián
Ávila/Mis documentos/Workspace/Jprim/ [20] was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2006-04-26 23:38:20.447
!MESSAGE Missing required bundle org.eclipse.ui.forms_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jface.text_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.workbench.texteditor_0.0.0.
!ENTRY org.eclipse.osgi 2006-04-26 23:38:20.462
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "Jprim.Application" could not be
found in the registry. The applications available are: <NONE>.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:216)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.osgi 2006-04-26 23:38:20.478
!SUBENTRY 1 org.eclipse.osgi 2006-04-26 23:38:20.478
Re: I'm lost with this error!!! [message #448568 is a reply to message #448567] Wed, 26 April 2006 22:11 Go to previous messageGo to next message
Neil Bartlett is currently offline Neil BartlettFriend
Member
Sebastian,
Three plugins are missing:
- org.eclipse.ui.forms
- org.eclipse.jface.text
- org.eclipse.ui.workbench.texteditor
Those plugins are required by your Jprim plugin, which contains the
Jprim.Application. Therefore the application couldn't start.
- Neil
> !STACK 1
> at
> at
> at
Re: I'm lost with this error!!! [message #448569 is a reply to message #448568] Wed, 26 April 2006 23:03 Go to previous messageGo to next message
Yes I know, this dependencies are included in the plugin dependencies with
others. It's strange because for example org.eclipse.ui doesn't generate
error but org.eclipse.ui.forms yes! what about the error about the path?
Re: I'm lost with this error!!! [message #448593 is a reply to message #448569] Thu, 27 April 2006 12:57 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
> with others. It's strange because for example org.eclipse.ui doesn't
> generate error but org.eclipse.ui.forms yes! what about the error about
> the path?
How are you launching this app? The most common cause is creating an
RCP app and launching it. Then adding some more dependencies and
extenstions and trying to launch it again. If this is the case, you
would have to update the launch config with the new plugins.
Later,
PW
Re: I'm lost with this error!!! [message #448714 is a reply to message #448593] Fri, 28 April 2006 20:35 Go to previous messageGo to next message
Marcus is currently offline MarcusFriend
Second what pw said. Have a look at the plugin tab on you launch config menu & make sure the three "missing" plugins are checked.
Re: I'm lost with this error!!! [message #448722 is a reply to message #448714] Sun, 30 April 2006 07:26 Go to previous messageGo to next message
Paul Woodward is currently offline Paul WoodwardFriend
Newer versions of eclipse have the 'Add required' button which is a bit of a lifesaver!
Re: I'm lost with this error!!! [message #448728 is a reply to message #448567] Sun, 30 April 2006 19:59 Go to previous messageGo to next message
Problem with this is, is that it adds loads of plugins that aren't required. Then if you hit the 'Validate Plugin Set' button, it promptly shows you all the plugins its just added as being in error...
Re: I'm lost with this error!!! [message #448731 is a reply to message #448728] Sun, 30 April 2006 23:25 Go to previous message
Member
I've never seen it do that. You should open a bug in BugZilla against the
PDE component.
- Neil
the >plugins its just added as being in error...
Previous Topic:Why help system was shown in external browser?
Next Topic:Providing a SelectionProvider from within a FormPage that is part of a FormEditor
Current Time: Fri Dec 06 10:02:27 GMT 2024
Powered by FUDForum. Page generated in 0.06129 seconds
