NoClassDefFoundError In SWT Display Event Loop [message #448535] |
Tue, 11 January 2005 18:27 |
Dan Florian Messages: 8 Registered: July 2009 |
I believe the error below is coming from a call to a native method.
Possibly an event returning this type of object. I'm using JACOB, the Java
COM bridge as the communication between my plugin and another windows
application. I have a JACOB plugin that is exporting the jacob.jar. My
plugin has added this JACOB plugin as a dependency. I've added the JACOB
dll to the system PATH variable.
Should I also add the jacob.jar to the System CLASSPATH or added to the
bootstrapclasspath somehow so that the Display loop can construct this
class?
Thanks.
java.lang.NoClassDefFoundError: com/jacob/com/Variant
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:14 73)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2429)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
FUDForum. Page generated in 0.03556 seconds
