SWT dll info [message #448470] |
Mon, 10 January 2005 18:47 |
Originally posted by: jmaken.hotmail.com
Didn't find any info in the FAQ's and I'm trying to determine which SWT
dll's are important to provide along with my app.
I'm using a Win2K dev system with Eclipse 3.0.1. Under the ...\os\win32\x86
directory, I have the following four files:
swt-awt-win32-3062.dll
swt-awt-win32-3063.dll
swt-win32-3062.dll
swt-win32-3063.dll
I suspect the 3063's are newer versions and I should include both latest
swt-win32-* and swt-awt-win32-* dll's with my app. I'd appreciate more info
on the versioning as well as the functionality differences between the
swt-win32 and the swt-awt-win32 dll's.
Re: SWT dll info [message #448479 is a reply to message #448471] |
Mon, 10 January 2005 23:25 |
Originally posted by: skrap.post.gmail.com
Bill Ewing wrote:
> We are interested in learning if there is one single person who has ever
> deployed a standalone SWT/JFace app on anything but an eclipse platform.
> The problem with everything being a plug in is, no one seems to be
> reponsible for answering questions like this.
All you need (for SWT) is the swt.jar file in the classpath and the dir
where the dll is in the library path (add -Djava.library.path=<directory
where dll is> if you run from the command line for example). Don't know
about JFace (yet).
/Johan
Re: SWT dll info [message #448537 is a reply to message #448479] |
Tue, 11 January 2005 18:39 |
This is the recommended solution if you have the swt.jar and dll's already
installed on your system.
However, as I'm interested in distributing my app as a jar that uses the SWT
java classes and JNI classes, I want to know precisely what dll's need to be
included with the distribution. As the Win32 solution has (4) dll's that
appear to be two different versions, I suspect I should use the 3063's but
was hoping someone knew the details. In addition, for a Win32 system, is
the swt-awt-win32-*.dll file required for an app that only uses SWT.
"Johan Karlsson" <skrap.post@gmail.com> wrote in message
news:crv2t5$ic6$1@www.eclipse.org...
> about JFace (yet).
> /Johan
Re: SWT dll info [message #448624 is a reply to message #448543] |
Wed, 12 January 2005 14:32 |
Makes sense...thanks Veronika
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:cs1dre$k8$1@www.eclipse.org...
> You must have the version of the dll that matches the version of the swt
> jar(s). If you open the swt.jar you will find a file called version.txt.
> This will tell you which version of the dll is required. You must have
the
> exact version. That is, if the version.txt says 3.062 then you can not
use
> swt-win32-3063.dll even though the version 3.063 is higher. You must use
> swt-win32-3062.dll.
> The library swt-awt-win32-XXXX.dll is only required if you use SWT_AWT to
> embed Swing/AWT widgets in SWT.
> "jmaken" <jmaken@hotmail.com> wrote in message
> news:cruik9$k60$1@www.eclipse.org...
> > ...\os\win32\x86
> > swt-win32-3062.dll
> > swt-win32-3063.dll
> > info
FUDForum. Page generated in 0.07103 seconds
