Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Question about view layout
Question about view layout [message #448312] Thu, 06 January 2005 22:06 Go to next message
Originally posted by: wiz.vball.net
could some kind soul please tell me what is exactly being used to
display and layout the views using the workbench.
I am basically including my own views with their tool bars/min/max
using tab folders to mimik or fake the same look plus SashForm to add
multiple views to an editor part... however the behavior is not as a
good as the way the work bench presents and breaks up the views and
editor content using its own layout. I just want to know how they did
that in Eclipse IDE and inside RCP. So I could mimik or use the same
layout manager to produce a smooth look while resizing separte views
or min/max each view.
thank you,
Parwiz
Re: Question about view layout [message #448313 is a reply to message #448312] Fri, 07 January 2005 01:04 Go to previous message
Jean-Michel Lemieux is currently offline Jean-Michel LemieuxFriend
Eh, look at the code? SashPane, ViewPane, and others will interesting
for you to look at. StackPresentation draws the actual views and editor
areas.
Jean-Michel
FireFly wrote:
> thank you,
> Parwiz
Previous Topic:Strange behaviour when creating a view ...
Next Topic:TextViewer in Eclipse 3.0M8
Current Time: Thu Dec 03 17:52:15 GMT 2020
Powered by FUDForum. Page generated in 0.01965 seconds
