Home » Eclipse Projects » Rich Client Platform (RCP) » Two selection providers on a same view
Two selection providers on a same view [message #448235] Wed, 19 April 2006 12:56 Go to next message
I have two components (list and tree) on a view and I need both to
distribute selection events (for the property sheet view).
But I can register only one.
How to solve this situation?
Lukas Zapletal
Re: Two selection providers on a same view [message #448282 is a reply to message #448235] Thu, 20 April 2006 09:41 Go to previous messageGo to next message
Dne Wed, 19 Apr 2006 18:56:41 +0200
Lukas Zapletal <lukas.zapletal@linuxexpres.cz> napsal(a):
I have tried to implement a provider, that will distribute the events
from both views. The problem is getSelection/setSelection methods.
These are called often and I dont know which component`s selection to
provide. Not a solution :-(
Lukas Zapletal
Re: Two selection providers on a same view [message #448284 is a reply to message #448282] Thu, 20 April 2006 10:00 Go to previous messageGo to next message
Just create a new SelectionProvider that wrapps both.
Ben
Re: Two selection providers on a same view [message #448293 is a reply to message #448284] Thu, 20 April 2006 12:16 Go to previous messageGo to next message
Dne Thu, 20 Apr 2006 16:00:41 +0200
Benjamin Pasero <bpasero@rssowl.org> napsal(a):
Thats what am talking about - I cannot.
The SelectionProvider has these getSelection/setSelection methods. What
should getSelection method return when called? Selection of the first
component, or the second?
Lukas Zapletal
Re: Two selection providers on a same view [message #448295 is a reply to message #448293] Thu, 20 April 2006 12:18 Go to previous messageGo to next message
Both.
Re: Two selection providers on a same view [message #448298 is a reply to message #448295] Thu, 20 April 2006 13:12 Go to previous messageGo to next message
Dne Thu, 20 Apr 2006 16:18:40 +0000 (UTC)
neil@integility.com (Neil Bartlett) napsal(a):
> Both.
As StructuredSelection?
public ISelection getSelection() {
ArrayList s = new ArrayList();
for (ISelectionProvider sp: providers)
s.add(sp.getSelection());
return new StructuredSelection(s);
Lukas Zapletal
Re: Two selection providers on a same view [message #448300 is a reply to message #448298] Thu, 20 April 2006 13:54 Go to previous messageGo to next message
Seems this works, thanks.
Dne Thu, 20 Apr 2006 19:12:32 +0200
> > Both.
> Best regards,
> Lukas Zapletal
Lukas Zapletal
Re: Two selection providers on a same view [message #448334 is a reply to message #448235] Thu, 20 April 2006 18:47 Go to previous message
Lukas
Look at Eclipses home page. There is a very good article "Using the Selection Service" that explains your case. Look at the "Multiple Selection Providers Within a Part". It has a good example.
Good luck
Previous Topic:Status Line -
Next Topic:Problem with MultiLineRule
Current Time: Sat Nov 08 13:14:03 EST 2025
Powered by FUDForum. Page generated in 0.05308 seconds
