Home » Eclipse Projects » Rich Client Platform (RCP) » Accesing Spring based server with security credentials (ACEGI)
Accesing Spring based server with security credentials (ACEGI) [message #448129] Tue, 18 April 2006 18:24 Go to next message
Originally posted by: jsilva.inf.utfsm.cl
The Spring Rich Client implements a method for keep, in a thread local,
the credentials of a user autenticated with ACEGI in the server...
Is simply to do that with Eclipse RCP?
I use the Eclipse RCP 3.1.2 and i want to do the same , keep a
threadlocal with the credetinals of the current user for accesing the
httpinvoker exposed services.
Before look at the Spring Rich Client code and implement it, i ask if
anybody knows some similar (i don't want re-invent the weel).
Thank in advance
Toño.
www.jcode.cl
Re: Accesing Spring based server with security credentials (ACEGI) [message #448512 is a reply to message #448129] Tue, 25 April 2006 15:03 Go to previous messageGo to next message
Davor Cengija is currently offline Davor CengijaFriend
Not of much help here, but I wander if you discovered anything useful in
this regard?
Davor
Re: Accesing Spring based server with security credentials (ACEGI) [message #448514 is a reply to message #448129] Tue, 25 April 2006 15:50 Go to previous message
Neil Bartlett is currently offline Neil BartlettFriend
Member
Jose,
You can do the authentication in the IPlatformRunnable before the
Workbench opens, but the problem with putting the credentials into a
thread local is that Eclipse is multi-threaded! Unless you could arrange
that all access to the httpinvoker is from the same thread, you're going
to have a problem if you use the Jobs API (for example). Perhaps you could
implement something similar to UIJob, which keeps all UI access on the
event dispatcher thread?
Also, although I don't know anything about Acegi, if it is JAAS-based then
take a look at EclipseJAAS (http://sf.net/projects/eclipse-jaas)
Neil
> Thank in advance
> Toño.
> www.jcode.cl
Previous Topic:rcp without perspectives and views
Next Topic:Coolbar with other hoverstyle
Current Time: Wed Dec 04 06:35:29 GMT 2024
Powered by FUDForum. Page generated in 0.03034 seconds
