Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to align verticaly text into a Label ?
How to align verticaly text into a Label ? [message #448096] Sat, 01 January 2005 12:59 Go to next message
jmi is currently offline jmiFriend
Member
Is there a way to vertical align text into a Label widget like vertical
align of a Text widget ? In fact, i would like to develop a Composite with
a Text widget in edit mode and a Label widget for read only mode. I want
this for a disabled Text (and later Combo) which is not Gray on gray
(background and foreground) I've done it easily, the problem is that the
Label text is align upper left when i put a Border to the Label -> huggly.
A solution ?
JMi
Re: How to align verticaly text into a Label ? [message #448097 is a reply to message #448096] Sat, 01 January 2005 13:01 Go to previous messageGo to next message
Member
Of course, the text is shown horizontaly but there it is vertical centered
into the widget...
"JM Delsaux" <JMDelsaux@skynet.be> wrote in message
news:cr66sd$5ec$1@www.eclipse.org...
> with a Text widget in edit mode and a Label widget for read only mode. I
> want this for a disabled Text (and later Combo) which is not Gray on gray
> A solution ?
> Thanks
> JMi
Re: How to align verticaly text into a Label ? [message #448167 is a reply to message #448096] Tue, 04 January 2005 17:52 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
Why not always use a Text control and use Text.setEditable()?
with
> A solution ?
> Thanks
> JMi
Re: How to align verticaly text into a Label ? [message #448173 is a reply to message #448167] Tue, 04 January 2005 19:50 Go to previous messageGo to next message
Member
Because it can always have the focus when you use the TAB key. I would like
to have the possibility to disable some fields when i edit some other AND
they have to be readable... but when there are grayed, it is unreadable for
old people ;-))
I'vr tried the next code but it seems to loop:
m_textCtl.addFocusListener(new FocusAdapter() {
public void focusGained(final FocusEvent argE) {
if(!m_textCtl.getEditable()) {
m_textCtl.traverse(SWT.TRAVERSE_TAB_NEXT);
public void focusLost(final FocusEvent argE) {
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:crel5v$u9l$1@www.eclipse.org...
>> Hi,
> with
>> the
>> huggly.
>> A solution ?
>> Thanks
>> JMi
Re: How to align verticaly text into a Label ? [message #448191 is a reply to message #448173] Wed, 05 January 2005 14:54 Go to previous message
Just let them tab into it. If not, you can vertically align the label
within a composite using code or a layout. Verital alignment of labels is
not supported natively on all platforms so we couldn't offer API to do it in
Label.
news:cres2e$m6a$1@www.eclipse.org...
like
for
> old people ;-))
> Thanks
> >> Hi,
> > with
want
> >> the
> >> huggly.
> >> A solution ?
> >> Thanks
> >> JMi
Previous Topic:plugin hyrarchy
Next Topic:Multi-threaded and org.eclipse.widgets.Display
Current Time: Sat Dec 05 06:55:20 GMT 2020
Powered by FUDForum. Page generated in 0.02932 seconds
