Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Help needed with a slider issue.
Help needed with a slider issue. [message #448093] Fri, 31 December 2004 14:26 Go to next message
strus is currently offline strusFriend
I don't know if it is possible to build in SWT an equivalent to SWING
ScrollBar(int orientation, int value, int extent, int min, int max)
with SWT Slider. The extend value has no equivalent in SWT.
Can I set this value throught setThumb, setPageIncrement ... ???
Re: Help needed with a slider issue. [message #448094 is a reply to message #448093] Fri, 31 December 2004 15:23 Go to previous message
Forget the question, playing with the setThumb() and setSelection give
me the expected result.
Previous Topic:Extending SWT Components
Next Topic:Table setSelection() bug?
Current Time: Sun Nov 29 14:18:54 GMT 2020
Powered by FUDForum. Page generated in 0.01938 seconds
