Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Erasing something drawn with drawString
Erasing something drawn with drawString [message #447848] Sun, 19 December 2004 02:16 Go to next message
Originally posted by: lindseygeorge.hotmail.com
I have a composite with a background image, and to show this image
properly, I use the drawString method for putting in text, instead of
labels. How can I erase one such text line, before updating it with a
new one?
Lindsey.
Re: Erasing something drawn with drawString [message #447865 is a reply to message #447848] Mon, 20 December 2004 14:32 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
Use Control.redraw(in, int, int, int, boolean). This will damage the area
you want to change and then in the paint event for that area, you draw it
correctly. You will have to draw the image as well as the text. You can
draw a portion of an image using GC.drawImage(Image image, int srcX, int
srcY, int srcWidth, int srcHeight, int destX, int destY, int destWidth, int
destHeight).
"Lindsey George" <lindseygeorge@hotmail.com> wrote in message
news:cq2odn$dl$1@www.eclipse.org...
>labels. How can I erase one such text line, before updating it with a new
>one?
> Lindsey.
Re: Erasing something drawn with drawString [message #447866 is a reply to message #447865] Mon, 20 December 2004 14:35 Go to previous messageGo to next message
Note also that org.eclipse.swt.custom.CLabel supports text over an image.
Use CLabel.setBackground(Image) to set an image in the background.
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:cq6nrj$7ap$1@www.eclipse.org...
> int destHeight).
>>one?
>> Thanks,
>> Lindsey.
Re: Erasing something drawn with drawString [message #447878 is a reply to message #447866] Mon, 20 December 2004 18:40 Go to previous messageGo to next message
Thanks Veronika. However, does CLabel support transparency? My composite
has the background image, and I would prefer not to have break up the
image into multiple parts, and then assign one of these parts as a
background image to a CLabel.
Lindsey.
>>int destHeight).
>>>one?
>>>Thanks,
>>>Lindsey.
Re: Erasing something drawn with drawString [message #447890 is a reply to message #447878] Tue, 21 December 2004 13:59 Go to previous messageGo to next message
It doesn't. There is currently no support for transparency in SWT.
news:cq76fg$r33$1@www.eclipse.org...
> Lindsey.
>>>area you want to change and then in the paint event for that area, you
>>>draw it correctly. You will have to draw the image as well as the text.
>>>You can draw a portion of an image using GC.drawImage(Image image, int
>>>srcX, int srcY, int srcWidth, int srcHeight, int destX, int destY, int
>>>destWidth, int destHeight).
>>>>new one?
>>>>Thanks,
>>>>Lindsey.
Re: Erasing something drawn with drawString [message #447948 is a reply to message #447865] Wed, 22 December 2004 05:16 Go to previous message
Thanks Veronika! That worked!
> destHeight).
>>one?
>>Thanks,
>>Lindsey.
Previous Topic:scroll draw2d on a swt canvas
Next Topic:Remove "input methods" item in popup menu
Current Time: Sat Jul 31 03:59:06 GMT 2021
Powered by FUDForum. Page generated in 0.01873 seconds
