Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [POCKET PC] SWT exception when creating tree
[POCKET PC] SWT exception when creating tree [message #447659] Thu, 16 December 2004 09:11 Go to next message
Originally posted by: guillaume_godetbar.nospam.nospam.hotmail.com
Did anyone manage to create tree widgets on a pocket pc ? I've tried
different builds of SWT (P.Profile) but I always end up with the same
error :
java.lang.IllegalAccessError:
org/eclipse/swt/widgets/Widget.checkBits(IIIIIII)I
whenever I try to declare a tree, even with simple stuff such as :
Tree testTree = new Tree(this, SWT.SINGLE);
Any ideas are welcomed !
Guillaume Godet-Bar
Re: [POCKET PC] SWT exception when creating tree [message #447715 is a reply to message #447659] Thu, 16 December 2004 15:38 Go to previous messageGo to next message
Christophe Cornu is currently offline Christophe CornuFriend
You need to use the SWT build from the Eclipse download page. The ones
shipping with WSDD may not contain widgets or API not required for embedded
profiles.
e.g.
http://fullmoon.ottawa.ibm.com/downloads/drops/I20041216-080 0/index.php
Look for "SWT Binary and Source"
And pick up the "Windows CE (ARM Pocket PC)" build.
Don't confuse it with the J2ME version that runs over CLDC.
Hope it helps,
Chris
Re: [POCKET PC] SWT exception when creating tree [message #447742 is a reply to message #447715] Thu, 16 December 2004 19:08 Go to previous messageGo to next message
Hi Chris,
Well I've reinstalled a clean j9, tried several SWT builds (for Pocket
PC, no J2ME, etc.) from the Eclipse project, but I still have the same
error. I've also tried some really stripped down code (imports omitted) :
public class TreeTest {
Display display = new Display();
Shell shell = new Shell(display, SWT.CLOSE);
GridLayout grid = new GridLayout();
grid.numColumns = 1 ;
shell.setLayout(grid);
Tree arbre = new Tree(shell, SWT.SINGLE);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
.... but once again I get the error. I've looked in the SWT sources, but
this bug really doesn't make sense (error while checking a standard tree
style ?).
Looking for some insight...
Guillaume
[SOLVED] cf. bug 73817 [message #447743 is a reply to message #447742] Thu, 16 December 2004 20:10 Go to previous message
I used a -Xbootclasspath/p:/share/java/SWT.jar equivalent in my link.
And it worked. That saves the day...
Guillaume
Previous Topic:how to resize a dialog and its content?
Next Topic:Width of compound widget
Current Time: Fri Jun 18 22:16:18 GMT 2021
Powered by FUDForum. Page generated in 0.02182 seconds
