Home » Eclipse Projects » Rich Client Platform (RCP) » [DataBinding] Duplicate data structures in StructuredViewerObservableCollectionWithLabels
[DataBinding] Duplicate data structures in StructuredViewerObservableCollectionWithLabels [message #447556] Mon, 10 April 2006 22:15 Go to next message
Brad Reynolds is currently offline Brad ReynoldsFriend
Why does SVOCWL internally maintain a Set and a List for the same data?
It looks like it's trying to support IObservableList and
IObservableSet which is confusing in the code and would seem like it
would be inefficient as well, especially when we're talking about
hundreds and possibly thousands of items being maintained.
-brad
Re: [DataBinding] Duplicate data structures in StructuredViewerObservableCollectionWithLabels [message #447559 is a reply to message #447556] Tue, 11 April 2006 04:22 Go to previous messageGo to next message
Dave Orme is currently offline Dave OrmeFriend
> It looks like it's trying to support IObservableList and IObservableSet
> which is confusing in the code and would seem like it would be
> inefficient as well, especially when we're talking about hundreds and
Thanks for the question.
Here's the reason:
Because JFace viewers are implemented using Set semantics but Hibernate
likes to use List semantics. You've got to bridge the gap somewhere.
Our approach was to make SVOCWL implement both IObservableList and
IObservableSet interfaces so you can have your cake and eat it too.
I'd challenge the assumption that this is the main scalability
bottleneck though:
Most tables with thousands of elements are going to have usability
problems: in most cases people just can't efficiently scroll through
that many elements. The solution is normally to query for a smaller set
first, and then to scroll through that.
Further: SWT Table-based UIs don't scale well into thousands of rows to
begin with. So if you have thousands of rows, you already need to look
beyond JFace viewers.
Which is why I wrote the CompositeTable control that's in the Examples
plugin. It is fully virtual, so there are zero scaling issues. It
fully supports in-place editing where you don't have to switch between
edit mode and browse mode. It has a full edit life cycle event model
including support for two-phase commit.
But we still need to write binding support for it. Would you like to
help? :-)
Thanks again for your great questions!
Dave Orme
Visual Editor Project lead
http://www.coconut-palm-software.com
http://www.db4o.com -- The Open-source Java Object Database
Re: [DataBinding] Duplicate data structures in StructuredViewerObservableCollectionWithLabels [message #447599 is a reply to message #447559] Tue, 11 April 2006 15:46 Go to previous messageGo to next message
Thanks for the response. Responses to individual comments are below...
On 2006-04-10 22:22:21 -0600, "David J. Orme"
> Here's the reason:
> bottleneck though:
> set first, and then to scroll through that.
I agree but I'm not sure we fall in the "most cases". One of our
applications is a database build app and at times this involves viewing
CSVs and very large datasets. I'd love to filter it down but that's
not what people are used to. They want to view it like Excel, navigate
it like Excel, and basically just have Excel. Because we have a custom
Table we're able to provide this at the Widget level. I've had this
argument many times but in the end we have to bow to the need of the
client and for these use cases they like to view all data at once.
We actually have our own Table implementation to get around these
things. It does pretty good with thousands of rows and is getting
better.
> help? :-)
You know I'd love to help. :) But I probably can't on bindings for this
widget as we have our own and I don't think I could justify working on
bindings for a component we won't use. Nothing against your widget of
course but I'm legally obligated in this regard.
> Best regards,
> Dave Orme
I guess in the end if this ends up being an issue we could create our
own implementation... hopefully. I'm curious if because of Hibernate
and other dependencies if this should part of the core StructuredViewer
binding support or if a little more separated concerns approach is more
appropriate. What I'm most concerned about is the core framework being
bound too tightly with the assumption that it will always be an
IObservableList and IObservableSet when using a StructuredViewer. I
haven't dug deep enough to see if that assumption exists and is
enforced but if so I'm going to have to rewrite a lot of code and of
course I'd like to avoid that if possible.
Thanks again,
Brad
Re: [DataBinding] Duplicate data structures in StructuredViewerObservableCollectionWithLabels [message #447615 is a reply to message #447599] Wed, 12 April 2006 03:38 Go to previous messageGo to next message
Brad,
Hmmmm... We think you have made your point well. We're not sure right
now what the solution would be and if you have any suggestions, we'd
love to hear them. :-) In the meantime, we're working on what to do
with this.
Dave Orme
>>> data? It looks like it's trying to support IObservableList and
>> Here's the reason:
>> Hibernate likes to use List semantics. You've got to bridge the gap
>> somewhere. Our approach was to make SVOCWL implement both
>> IObservableList and IObservableSet interfaces so you can have your
>> bottleneck though:
> CSVs and very large datasets. I'd love to filter it down but that's not
> what people are used to. They want to view it like Excel, navigate it
>> to begin with. So if you have thousands of rows, you already need to
>> look beyond JFace viewers.
> things. It does pretty good with thousands of rows and is getting better.
>> help? :-)
>> Best regards,
>> Dave Orme
> haven't dug deep enough to see if that assumption exists and is enforced
> but if so I'm going to have to rewrite a lot of code and of course I'd
> Thanks again,
> Brad
Re: [DataBinding] Duplicate data structures in StructuredViewerObservableCollectionWithLabels [message #447682 is a reply to message #447615] Wed, 12 April 2006 13:22 Go to previous message
Thanks for the information. I'm kind of getting pulled off the project
so there will be less involvement from me but I'll try to keep looking
at things in my spare time. I don't yet have any suggestions but once
I can get an even better idea as to how viewers are implemented and if
that provides any ideas I'll send them your way.
On 2006-04-11 21:38:21 -0600, "David J. Orme"
> Brad,
> with this.
> Best regards,
> Dave Orme
>>> Here's the reason:
>>> bottleneck though:
>> better.
>>> help? :-)
>>> Best regards,
>>> Dave Orme
>> Thanks again,
>> Brad
Previous Topic:Views and Perspectives
Next Topic:Generate help toc(referencing JavaDoc) from available plugins
Current Time: Sun Dec 08 15:46:34 GMT 2024
Powered by FUDForum. Page generated in 0.05332 seconds
