Home » Eclipse Projects » Rich Client Platform (RCP) » file path in plugin when runtime
file path in plugin when runtime [message #447538] Mon, 10 April 2006 08:15 Go to next message
Stephen is currently offline StephenFriend
Member
Hi,all:
I want to read a file which exists in plugin's root directory.How to
decide the file's path when runtime? By using
getBundle().getResource("fileName") i can get URL ,but is it the only way?
How can i get the absolute path?
Stephen.
Re: file path in plugin when runtime [message #447590 is a reply to message #447538] Tue, 11 April 2006 12:51 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
If you get the URL, you can get it's input stream. You can use that,
bridge it to InputStreamReader, etc.
If you really want the file, then you can use Platform.asLocalURL(*)
(which has been deprecated in 3.2 and replaced with
FileLocator#toFileURL(*)). But if the plugin was a jar, it will extract
the file into a temporary location.
Later,
PW
Previous Topic:Plugin class constructor and start method
Next Topic:Reuse extension point schema functionality
Current Time: Wed Dec 04 03:48:08 GMT 2024
Powered by FUDForum. Page generated in 0.02883 seconds
