Home » Eclipse Projects » Rich Client Platform (RCP) » question about export a plugin
question about export a plugin [message #447533] Mon, 10 April 2006 05:07 Go to next message
chen is currently offline chenFriend
It always says "import eclipse.org..... cannot be resolved.." It is
indirectly referenced from required .class files"..
For such problems, generally what should i do?
fix the building path, or fix the dependency?
any help appreciated.
Chen
Re: question about export a plugin [message #447534 is a reply to message #447533] Mon, 10 April 2006 06:43 Go to previous messageGo to next message
Alan Green is currently offline Alan GreenFriend
Definitely fix your plug-in's dependency list. If you fix the build
path, your project will compile, but you will then have a class-loading
error at runtime.
Alan.
Re: question about export a plugin [message #447540 is a reply to message #447534] Mon, 10 April 2006 12:54 Go to previous messageGo to next message
Originally posted by: wangchen1981.gmail.com
Then is there a good way to find what other dependencies i need?
There is no hints in the error msg..
"Alan Green" <alan.green@cardboard.nu> wrote in message
news:e1cuqm$pva$1@utils.eclipse.org...
> Definitely fix your plug-in's dependency list. If you fix the build path,
> your project will compile, but you will then have a class-loading error at
> runtime.
> Alan.
Re: question about export a plugin [message #447543 is a reply to message #447533] Mon, 10 April 2006 13:36 Go to previous messageGo to next message
I posted the entire error log here...
1. ERROR in
E:\eclipse\workspace2\com.omondo.uml.diagram\src\com\omondo\ uml\diagram\DiagramFragment.java
(at line 0)
package com.unc.uml.diagram;
The type org.eclipse.uml2.Element cannot be resolved. It is indirectly
2. ERROR in
(at line 6)
import org.eclipse.emf.common.util.EList;
The import org.eclipse.emf cannot be resolved
3. ERROR in
(at line 8)
import org.eclipse.jface.dialogs.MessageDialog;
The import org.eclipse.jface.dialogs cannot be resolved
3 problems (3 errors)
Have no idea about how to fix that....Coz the plugin do works fine...Just
cannot be exported to a plugin..
"chen" <wangchen1981@gmail.com> wrote in message
news:e1cp7b$8nl$1@utils.eclipse.org...
> Chen
Re: question about export a plugin [message #447583 is a reply to message #447543] Tue, 11 April 2006 07:55 Go to previous messageGo to next message
What version of Eclipse are you using?
Alan.
Re: question about export a plugin [message #447597 is a reply to message #447583] Tue, 11 April 2006 14:37 Go to previous messageGo to next message
I am using 3.1.*...
news:e1fne7$og6$1@utils.eclipse.org...
> Alan.
Re: question about export a plugin [message #447598 is a reply to message #447543] Tue, 11 April 2006 15:26 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
> 1. ERROR in
> (at line 0)
> 2. ERROR in
> (at line 6)
> 3. ERROR in
> (at line 8)
1) Does com.omondo.uml.diagram list org.eclipse.emf.* and
org.eclipse.jface as a requirement? Please post it's manifest.
2) if yes, are you just exporting a plugin, or are you exporting an RCP app?
Later,
PW
Re: question about export a plugin [message #447619 is a reply to message #447597] Wed, 12 April 2006 04:25 Go to previous message
I now recontruct the whole project again..
now the error goes away..
Thanks u guys.
news:e1gev6$qcp$1@utils.eclipse.org...
>I am using 3.1.*...
>>> fine...Just cannot be exported to a plugin..
>> Alan.
Previous Topic:[DataBinding] Validation : why 2 methods
Next Topic:How Can I link my RCP Application with Wizard page ?
Current Time: Fri Dec 06 12:07:31 GMT 2024
Powered by FUDForum. Page generated in 0.03943 seconds
