Home » Eclipse Projects » Rich Client Platform (RCP) » Disable the duplication of a perspective by dragging
Disable the duplication of a perspective by dragging [message #447500] Fri, 07 April 2006 08:26 Go to next message
Stephane is currently offline StephaneFriend
I get a problem in my RCP app because I cannot manage duplicated editors
on the same resource.
For duplicated editors, I have found that presentations extension point
could solve the problem and remove the 'New editor' action in the
context menu of the editor tab.
The problem comes now from perspectives. Indeed, the user is still able
to duplicate a perspective in a new window by dragging its icon from the
perspective toolbar.
Then, the user can open the same resource in an editor in each instance
of the duplicated perspective. Here's the point.
My question is quite simple :
How to disable the ability to duplicate a perspective in a new window ?
Thanks in advance.
Stephane
Re: Disable the duplication of a perspective by dragging [message #447663 is a reply to message #447500] Wed, 12 April 2006 07:38 Go to previous messageGo to next message
Nobody ? I really need help on this point. If I were not clear, I could
better describe my problem.
Stephane
Stephane a écrit :
> Hello,
> editors on the same resource.
> point could solve the problem and remove the 'New editor' action in
> the context menu of the editor tab.
> able to duplicate a perspective in a new window by dragging its icon
> from the perspective toolbar.
> instance of the duplicated perspective. Here's the point.
> Thanks in advance.
> Stephane
Re: Disable the duplication of a perspective by dragging [message #447673 is a reply to message #447663] Wed, 12 April 2006 11:50 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Your problem as stated, you cannot disable this duplication of
perspectives, unless you remove new window and the perspective switcher
from your RCP app.
Your actual problem is you cannot have 2 editors open on your same
resource at the same time. I'd try and fix that problem.
Option 1: move to an MVC pattern, like the text editors. They take
their editor input and ask a document provider for their document. The
document provider will hand back the same document model for the same
editor input. Now both editors are working on the same model, and
property change events cause both editors to update their info at the
same time.
Option 2: Manage your list of open resources, and if a request to open
an input that's already in your list occurs don't fully open your normal
editor, just open it with a message window saying "Resource already open
.... please contact your dealer."
Later,
PW
Re: Disable the duplication of a perspective by dragging [message #447684 is a reply to message #447673] Wed, 12 April 2006 15:52 Go to previous message
Thanks a lot. I will investigate your proposed solutions.
Paul Webster a écrit :
>> could better describe my problem.
> switcher from your RCP app.
> The document provider will hand back the same document model for the
> same editor input. Now both editors are working on the same model,
> and property change events cause both editors to update their info at
> the same time.
> normal editor, just open it with a message window saying "Resource
> already open ... please contact your dealer."
> Later,
> PW
Previous Topic:Generate help toc(referencing JavaDoc) from available plugins
Next Topic:Editor Filters
Current Time: Mon Dec 09 04:20:14 GMT 2024
Powered by FUDForum. Page generated in 0.03523 seconds
