Home » Eclipse Projects » Subversive » Latest update severely pooches Eclipse
Re: Latest update severely pooches Eclipse [message #45070 is a reply to message #45058] |
Tue, 28 April 2009 21:11 |
Steve Whatmore Messages: 95 Registered: July 2009 |
Member |
After going to a clean install of Eclipse and downloading the the SVN
packages (I was truly hoping that a fresh install with the latest package
would work) I have determined that the 0.7.8 release is total JUNK.
Is the 0.7.7 update site still available somewhere?
Furthermore, is this a problem that is specific to my installation (I doubt
highly since it is fairly generic) and should the update package be pulled?
Whatty
"Whatty" <steven.whatmore@lynxdev.com> wrote in message
news:gt7laa$5c8$1@build.eclipse.org...
> Actually, I spoke too soon and the checkout of the project doesn't
> completely succeed either, hitting essentially the same problem.
> news:gt7g49$tov$1@build.eclipse.org...
>> Good afternoon,
>> I just did an update to the latest version of the SVN packages that
>> became available today and it has severely pooched my Eclipse (3.4.1)
>> No problem, I say, I will just revert to the last known good
>> configuration. Alas, that did not work either (which seems contrary to
>> exactly what that option is available for in the first place - but that
>> is yet another issue)
>> I am receiving the following message:
>> An internal error occurred during: "Updating Synchronize view for
>> org.eclipse.team.svn.core.synchronize.UpdateSubscriber"
>> org.eclipse.team.svn.core.connector.SVNChangeStatus.<init>(Ljava/lang/String;Ljava/lang/String...
>> Has anyone else hit this issue and is there a work-around?
>> I tried deleting my projects and rechecking them out of SVN which seems
>> to work fine (the checkout that is), but the above problem persists,
>> basically rendering my Eclipse useless.
>> Whatty
Re: Latest update severely pooches Eclipse [message #45082 is a reply to message #45070] |
Tue, 28 April 2009 21:33 |
I also see this problem. Here's a complete stack-trace:
An internal error occurred during: "Updating Change Sets for org.eclipse.team.svn.core.synchronize.UpdateSubscriber".
java.lang.NoSuchMethodError:
org.eclipse.team.svn.core.connector.SVNChangeStatus.<init> (Ljava/lang/String;Ljava/lang/String;IJJJLjava/lang/String;I IIIZZLjava/lang/String;Ljava/lang/String;Ljava/lang/String;L java/lang/String;JZLjava/lang/String;Ljava/lang/String;Ljava /lang/String;JLorg/eclipse/team/svn/core/connector/SVNLock;J JILjava/lang/String;)V
at org.tigris.subversion.javahl.ConversionUtility.convert(Conve rsionUtility.java:287)
at org.tigris.subversion.javahl.ConversionUtility$4.doStatus(Co nversionUtility.java:146)
at org.tmatesoft.svn.core.javahl.SVNClientImpl$2.handleStatus(S VNClientImpl.java:285)
at org.tmatesoft.svn.core.internal.wc.SVNStatusEditor.getDirSta tus(SVNStatusEditor.java:160)
at org.tmatesoft.svn.core.internal.wc.SVNStatusEditor.closeEdit (SVNStatusEditor.java:104)
at org.tmatesoft.svn.core.wc.SVNStatusClient.doStatus(SVNStatus Client.java:375)
at org.tmatesoft.svn.core.javahl.SVNClientImpl.status(SVNClient Impl.java:300)
at org.tmatesoft.svn.core.javahl.SVNClientImpl.status(SVNClient Impl.java:282)
at org.polarion.team.svn.connector.svnkit.SVNKitConnector.statu s(SVNKitConnector.java:334)
at org.eclipse.team.svn.core.extension.factory.ThreadNameModifi er.status(ThreadNameModifier.java:608)
at org.eclipse.team.svn.core.utility.SVNUtility.status(SVNUtili ty.java:289)
at org.eclipse.team.svn.core.utility.SVNUtility.getSVNInfoForNo tConnected(SVNUtility.java:762)
at org.eclipse.team.svn.core.SVNTeamProvider.uploadRepositoryRe source(SVNTeamProvider.java:241)
at org.eclipse.team.svn.core.SVNTeamProvider.connectToProject(S VNTeamProvider.java:172)
at org.eclipse.team.svn.core.SVNTeamProvider.getRepositoryResou rce(SVNTeamProvider.java:71)
at org.eclipse.team.svn.core.svnstorage.SVNRemoteStorage.loadLo calResourcesSubTreeSVNImpl(SVNRemoteStorage.java:714)
at org.eclipse.team.svn.core.svnstorage.SVNRemoteStorage.loadLo calResourcesSubTree(SVNRemoteStorage.java:605)
at org.eclipse.team.svn.core.svnstorage.SVNRemoteStorage.asLoca lResource(SVNRemoteStorage.java:371)
at org.eclipse.team.svn.core.synchronize.AbstractSVNSubscriber. getSyncInfo(AbstractSVNSubscriber.java:127)
at org.eclipse.team.core.subscribers.Subscriber.getDiff(Subscri ber.java:370)
at org.eclipse.team.internal.core.subscribers.SubscriberChangeS etManager.getDiff(SubscriberChangeSetManager.java:302)
at
org.eclipse.team.internal.core.subscribers.SubscriberChangeS etManager$EventHandler.handleChange(SubscriberChangeSetManag er.java:183)
at
org.eclipse.team.internal.core.subscribers.SubscriberChangeS etManager$EventHandler.doDispatchEvents(SubscriberChangeSetM anager.java:80)
at org.eclipse.team.internal.core.BackgroundEventHandler.dispat chEvents(BackgroundEventHandler.java:394)
at org.eclipse.team.internal.core.BackgroundEventHandler.proces sEvents(BackgroundEventHandler.java:374)
at org.eclipse.team.internal.core.BackgroundEventHandler$1.run( BackgroundEventHandler.java:203)
HTH,
- thomas
> Whatty
>>> Good afternoon,
>>> Whatty
Re: Latest update severely pooches Eclipse [message #45141 is a reply to message #45114] |
Tue, 28 April 2009 21:49 |
Originally posted by: andrealuciano.dessi.gmail.com
Damir Murat ha scritto:
> Same problem here...
> Best regards,
> Damir Murat
and same problem here...
!ENTRY org.eclipse.core.jobs 4 2 2009-04-28 23:04:03.273
!MESSAGE An internal error occurred during: "Updating Change Sets for
!STACK 0
at
org.tigris.subversion.javahl.ConversionUtility.convert(Conve rsionUtility.java:282)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Latest update severely pooches Eclipse [message #45262 is a reply to message #45230] |
Wed, 29 April 2009 08:32 |
Jens Ohlsson:
> Perhaps there's an easy way to downgrade the plugin, but I had to
> manually edit a couple of files in my installation to uninstall the
> 0.7.8 version. Uninstall and revert didn't work. After that I installed
> fom my local downloaded update site.
Yes. Actually the quickest way to downgrade your eclipse with subversive
077 is:
- remove all Subversive components from eclise using the normal way
- remove all URL concerning Subversive from your update sites list
- download this Subversive-incubation-0.7.7.I20090224-1900.zip
- add to your update site list this
- add to your update site the connector site
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/
- install what you need
enjoy 077 version.
Andrea
Re: Latest update severely pooches Eclipse [message #45351 is a reply to message #45292] |
Wed, 29 April 2009 09:53 |
Malis Ung Messages: 7 Registered: July 2009 |
Igor Burilo wrote:
> Hello All,
> I just fixed the problem. In order to make Subversive working, please,
> update to latest SVN Connectors. For more details, please, see
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=274010. Sorry for
> inconvenience.
Even with the SVN connectors fix, this still doesn't work for me.
I have just done an update of everything related to
subversive/connectors/etc... and now, I cannot do anything with my checked
out projects.
For example, doing a right click on my project, then selecting the "Team"
item, some actions are no longer available (like Update, Synchronize with
Repository, Show or Set properties, etc...).
And when I try one of the "available" actions, like "Show History", I get
immediately an error:
SVN: '0x00400114: Show History View' operation finished with error:
Do I also have to downgrade to version 0.7.7 ???
Am I the only one still having this problem?
Malis
Re: Latest update severely pooches Eclipse [message #45375 is a reply to message #45351] |
Wed, 29 April 2009 12:39 |
Member |
Seconded and confirmed that does not fix the issue.
"Malis Ung" <malis.ung@wincor-nixdorf.com> wrote in message
news:5154f6eaf2058ef4249d66b4ff67011e$1@www.eclipse.org...
> Igor Burilo wrote:
>> Hello All,
>> inconvenience.
> out projects.
> Malis
Re: Latest update severely pooches Eclipse [message #45434 is a reply to message #45375] |
Wed, 29 April 2009 12:45 |
Member |
The "pooch award" goes to...
When is an appropriate time to start the "good natured ribbing" of the SVN
team - LOL - JK
news:gt9i2o$f2m$1@build.eclipse.org...
>> Igor Burilo wrote:
>>> Hello All,
>>> inconvenience.
>> Hi,
>> checked out projects.
>> Malis
Re: Latest update severely pooches Eclipse [message #45639 is a reply to message #45492] |
Thu, 30 April 2009 07:24 |
Whatty:
> Andrea,
> I can't seem to get those connectors to work with my 3.4.1 image.
> It is complaining about the unsatisfied requirement
> org.eclipse.ui.workbench[3.4.2.M20090127-1700]
> Any ideas.
> As well, does anyone know if the SVN team is going to fix the issue with the
> current update site?
> Whatty
I didn't know those connectors need eclipse 3.4.2 platform.
Maybe Subversive Team could tell we exactly what version
of plugin and connector surely works with 3.4.1.
Anyway there are archived connector here:
http://www.polarion.org/projects/subversive/download/eclipse /2.0/builds/
But i dont' know if they fit you.
Andrea
Re: Latest update severely pooches Eclipse [message #45817 is a reply to message #45048] |
Tue, 05 May 2009 08:54 |
Igor Burilo Messages: 435 Registered: July 2009 |
Hello All,
I created a bug on Bugzilla about this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=274010 and it was fixed. In
short, you just need to update to latest SVN Connectors.
Here's a full description of the problem and description of how to fix it:
The problem was that I didn't update 'latest release update site' for SVN
connectors(weekly update site contained latest changes and it worked with
it), I just did it and it should work now.
So in order to resolve the problem, please, update SVN Connectors. You can
do it either from update site:
or from archived update site:
http://community.polarion.com/projects/subversive/download/e clipse/2.0/builds/Subversive-connectors-2.2.0.I20090429-1300 .zip
Important: If you make the update(not the first-time installing) of
Subversive you can encounter in situation that you have already installed
previous versions of connectors which may cause problems. So for correct
work I recommend you to completely uninstall all previously installed SVN
Connectors before installing new ones. In Eclipse 3.4.x you can do it in
Help/Sofware updates... menu in Installed Software tab, select svn
connectors and unistall them. SVN Connectors start with following names:
JavaHL ..., Native JavaHL ..., SVNKit ... etc.
In order to ensure that you don't have old connectors, you can check them in
Windows/Preferences/Team/SVN in SVN Connector tab. There you should have
SVNKit starting from 1.2.2 version, e.g. Default SVN Kit (SVN 1.5.5
SVNKit/1.2.2), SVN Kit (SVN 1.6.1 SVNKit/1.3.0-beta) and Native JavaHL (svn:
1.5.4); Native JavaHL (svn: 1.6.0).
Starting from this version we don't support SVN 1.4 connectors any more.
Current Time: Thu Mar 28 14:24:08 GMT 2024
Powered by FUDForum. Page generated in 0.06639 seconds
