Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Horizontal separators
Horizontal separators [message #447372] Mon, 13 December 2004 23:15 Go to next message
Chris Audley is currently offline Chris AudleyFriend
Member
I'm trying to design a composite layout that will consist of two
horizontally oriented sub-composites placed one above the other, with a
separator line in between.
In swing, I would us a JSeparator to render the horizontal separator,
but I can't figure out how to do this in SWT. Clearly a similar
facility is used in the menu's but that is done with MenuItems and can't
be used with composites.
Any help would be appreciated
Chris
Re: Horizontal separators [message #447373 is a reply to message #447372] Mon, 13 December 2004 23:24 Go to previous message
Mani Ghamari is currently offline Mani GhamariFriend
Member
You must use a label
That following code creates a horizontal seperator:
Label seperator = new Label(shell, SWT.SEPARATOR);
Mani
"Chris Audley" <chris.audley@beacon-cs.com> wrote in message
news:cpl7qs$clv$1@www.eclipse.org...
> In swing, I would us a JSeparator to render the horizontal separator, but
> I can't figure out how to do this in SWT. Clearly a similar facility is
> used in the menu's but that is done with MenuItems and can't be used with
> composites.
> Thanks
> Chris
Previous Topic:Newsgroup for general Eclipse problems?
Next Topic:transparent Canvas on top of a Composite
Current Time: Sat Dec 05 15:47:51 GMT 2020
Powered by FUDForum. Page generated in 0.02289 seconds
