Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT: Stand alone jar
SWT: Stand alone jar [message #447269] |
Sat, 11 December 2004 22:22 |
Originally posted by: kelly_stevens81.yahoo.com
I am having some problems creating a stand alone jar using the swt
librarys it seems that it cannot find the main class.
my process is
jar cvfm npreview.jar Manifest.tmp *.class
which creates the npreview.jar file which i can execute using a swing test
program that works.
But when i try to use my npreview.jar file that uses swt and jdbc to
access my access database it creates the jar but throws errors when i try
to execute it.
I want to thank anyone who replys to this in advance and say that i
appreciate all of you who take the time to look at this post.
My thought of what is wrong is that perhaps i dont have an environment
variable set correctly for the swt libraries or that i am not aware of an
include that i must have in my statement.
Manifest.tmp
Manifest-Version: 1.0
Main-Class: JDBCApp
This file does have a return at the end.
JDBCApp.java
//Import statements
import java.sql.*;
import org.eclipse.swt.events.*;
import org.eclipse.swt.layout.FormAttachment;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
//Main class
public class JDBCApp
//Main method
public static void main( String [] args )
//Interface call
new JDBCInterface();
//Database class
class JDBCDatabase
//Declarations
String dataSourceName = "db";
String dbURL = "jdbc:odbc:" + dataSourceName;
ResultSet rs;
Statement s;
Connection con;
String[] values = new String[2];
int row = 1;
//Constructor
public JDBCDatabase()
//Database connection
try
Class.forName("sun.jdbc.odbc.JdbcOdbcDriver");
con = DriverManager.getConnection( dbURL, "", "" );
s = con.createStatement( ResultSet.TYPE_SCROLL_INSENSITIVE,
ResultSet.CONCUR_READ_ONLY );
s.execute( "SELECT * FROM names ORDER BY name_id" );
rs = s.getResultSet();
catch( Exception e )
System.out.println( "Error: " + e );
//Name retrieval
void getNames( String d )
//Declaration
String direction = d;
try
if ( rs != null)
//Previous movement
if ( d.equals("prev") )
if ( !rs.isFirst() )
rs.absolute( --row );
values[0] = rs.getString( "first_name" );
values[1] = rs.getString( "last_name" );
else
getNames( "first" );
//Next movement
if ( d.equals("next") )
if ( !rs.isLast() )
rs.absolute( ++row );
else
getNames( "last" );
//First movement
if ( d.equals("first") )
row = 1;
rs.first();
//Last movement
if ( d.equals("last") )
rs.last();
row = rs.getRow();
catch ( Exception e )
//Connection terminator
void closeConnection()
try
con.close();
s.close();
//Interface class
class JDBCInterface
Display display = new Display();
Shell shell = new Shell( display );
final Text txtfname = new Text( shell, SWT.BORDER );
final Text txtlname = new Text( shell, SWT.BORDER );
JDBCDatabase db = new JDBCDatabase();
//Constructor
public JDBCInterface()
{InterfaceSetup();}
public void loadName( String d )
String last, first;
String[] values;
db.getNames( d );
first = db.values[0];
last = db.values[1];
txtlname.setText( last );
txtfname.setText( first );
//Interface method
public void InterfaceSetup()
loadName( "first" );
FormLayout flayout = new FormLayout();
flayout.marginHeight = 5;
flayout.marginWidth = 5;
shell.setLayout( flayout );
shell.setText( "Name Previewer" );
//Lblfname setup
FormData fdata = new FormData();
fdata.top = new FormAttachment( 0, 7 );
fdata.left = new FormAttachment( 0, 5 );
Label lblfname = new Label( shell, SWT.NONE );
lblfname.setText( "First Name" );
lblfname.setLayoutData( fdata );
//Txtfname setup
fdata.top = new FormAttachment( 0, 5 );
fdata.left = new FormAttachment( lblfname, 5, SWT.RIGHT );
fdata.right = new FormAttachment( 100, -5 );
txtfname.setLayoutData( fdata );
//Lbllname setup
fdata.top = new FormAttachment( lblfname, 12 );
Label lbllname = new Label( shell, SWT.NONE );
lbllname.setText( "Last Name" );
lbllname.setLayoutData( fdata );
//Txtlname setup
fdata.top = new FormAttachment( txtfname, 5 );
fdata.left = new FormAttachment( lbllname, 5, SWT.RIGHT );
txtlname.setLayoutData( fdata );
//Btnfirst setup
fdata.top = new FormAttachment( lbllname, 10 );
fdata.right = new FormAttachment( 25, -5 );
Button btnfirst = new Button( shell, SWT.PUSH );
btnfirst.setText( "<<" );
btnfirst.setLayoutData( fdata );
btnfirst.addSelectionListener( new SelectionAdapter()
public void widgetSelected( SelectionEvent event )
//Btnprev setup
fdata.left = new FormAttachment( btnfirst, 5, SWT.RIGHT );
fdata.right = new FormAttachment( 50, -5 );
Button btnprev = new Button( shell, SWT.PUSH );
btnprev.setText( "<" );
btnprev.setLayoutData( fdata );
btnprev.addSelectionListener( new SelectionAdapter()
loadName( "prev" );
//Btnnext setup
fdata.left = new FormAttachment( btnprev, 5, SWT.RIGHT );
fdata.right = new FormAttachment( 75, -5 );
Button btnnext = new Button( shell, SWT.PUSH );
btnnext.setText( ">" );
btnnext.setLayoutData( fdata );
btnnext.addSelectionListener( new SelectionAdapter()
loadName( "next" );
//Btnlast setup
fdata.left = new FormAttachment( btnnext, 5, SWT.RIGHT );
Button btnlast = new Button( shell, SWT.PUSH );
btnlast.setText( ">>" );
btnlast.setLayoutData( fdata );
btnlast.addSelectionListener( new SelectionAdapter()
loadName( "last" );
//Show the shell
shell.pack();
shell.open();
//Resource Mangement
while ( !shell.isDisposed() )
if ( !display.readAndDispatch() )
display.sleep();
db.closeConnection();
display.dispose();
Re: Stand alone jar [message #447270 is a reply to message #447269] |
Sun, 12 December 2004 01:10 |
Mani Ghamari Messages: 33 Registered: July 2009 |
Member |
Hi Kelly,
I have compiled and jared your classes (almost) without any problems (&
without any extra environment variables, I just inlcuded the path to
javac.exe (j2sdk\bin) ).
The npreview.jar I compiled finds the main class and runs without problems
(Of course, I get an SQL exception because I don't have the JDBC:ODBC data
source available...)
Provided that the file DOES have a new line at the end, your manifest seems
to be perfectly valid.
Double check this by unpacking your npreview.jar and looking at
/META-INF/MANIFEST.MF
If you can see your instructions in that manifest (Main-Class: JDBCApp),
java.exe should not have any problems. If you see an empty manifest (wich
only contains Created-By and/or Manifest-Version), my best bet is that there
IS NO return at the end!
Try adding several new lines at the end of the file just to make sure (they
will be trimmed away by jar.exe anyways) and making a new jar (or updating
your jar using: jar -uvfm npreview.jar Manifest.tmp)
You might also want to add
Class-Path: swt.jar
to your manifest, if this is stand alone application (be sure to put swt.jar
and the native library in the same directory as the jar file)
I have also allowed myself to attach the manifest file and the working
npreview.jar to this email for you....
regards,
Mani Ghamari
"kelly stevens" <kelly_stevens81@yahoo.com> wrote in message
news:cpfrud$40e$1@www.eclipse.org...
> my process is
> program that works.
> to execute it.
> Manifest.tmp
> Main-Class: JDBCApp
> JDBCApp.java
> //Import statements
> import java.sql.*;
> import org.eclipse.swt.widgets.Display;
> //Main class
> //Main method
> //Interface call
> //Database class
> class JDBCDatabase
> //Declarations
> ResultSet rs;
> Statement s;
> Connection con;
> int row = 1;
> //Constructor
> try
> //Name retrieval
> //Declaration
> try
> if ( rs != null)
> //Previous movement
> else
> //Next movement
> if ( !rs.isLast() )
> else
> getNames( "last" );
> //First movement
> row = 1;
> rs.first();
> //Last movement
> rs.last();
> row = rs.getRow();
> try
> con.close();
> s.close();
> //Interface class
> class JDBCInterface
> //Constructor
> {InterfaceSetup();}
> String last, first;
> String[] values;
> db.getNames( d );
> //Interface method
> //Lblfname setup
> //Txtfname setup
> //Lbllname setup
> //Txtlname setup
> //Btnfirst setup
> //Btnprev setup
> loadName( "prev" );
> //Btnnext setup
> loadName( "next" );
> //Btnlast setup
> loadName( "last" );
> //Show the shell
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
Attachment: npreview.jar
(Size: 5.86KB, Downloaded 130 times) -
Attachment: Manifest.tmp
(Size: 0.07KB, Downloaded 145 times)
Re: Stand alone jar [message #447274 is a reply to message #447270] |
Sun, 12 December 2004 23:27 |
Mani Ghamari wrote:
Thank you Mani i put in the line Class-Path: swt.jar into my manifest.tmp
file and moved a copy of swt.jar into the directory now everything works
fine.
Current Time: Thu Apr 25 06:28:09 GMT 2024
Powered by FUDForum. Page generated in 2.57600 seconds
