Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Swing Table to SWT Table
Swing Table to SWT Table [message #446953] Tue, 07 December 2004 04:17 Go to next message
Originally posted by: diana.joseph.gmail.com
Hi all,
if someone could help me?
What is the SWT equivalents for the following Swing codes
public JTable rawTable;
static int entry_pos=0;
int division;
1) rawTable.setRowSelectionInterval(entry_pos,entry_pos);
2) rawTable.getValueAt(entry_pos,division);
3) rawTable.getCellRect(entry_pos,entry_pos, true);
4) rawTable.scrollRectToVisible(a);
heres the exact Swing code:
public int selectTable(String SelData, int rCount,int division)
for(;entry_pos < rCount;entry_pos++)
if(SelData.equals(rawTable.getValueAt(entry_pos,division).to String().trim()))
Rectangle a = rawTable.getCellRect(entry_pos,entry_pos, true);
repaint();
return entry_pos++;
entry_pos = 0;
return entry_pos;
public void setTableIndex ()
entry_pos = 0;
Re: Swing Table to SWT Table [message #447014 is a reply to message #446953] Tue, 07 December 2004 21:30 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
Please read the javadoc for Table, TableItem and TableColumn. All of these
are pretty well doccumented:
http://help.eclipse.org/help30/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/swt/widgets/Table.html
http://help.eclipse.org/help30/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/swt/widgets/TableColumn.html
http://help.eclipse.org/help30/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/swt/widgets/TableItem.html
Table.select(int start, int end) or Table.select(int[] indices) or
Table.setSelection(TableItem[])
TableItem.getText(int index);
TableItem.getImage(int index);
TableItem.getBounds(int index) TableItem.getImageBounds(int index)
Table.setTopIndex(int index) or Table.showItem(int index) and/or
Table.showColumn(TableCOlumn)
"Anaida" <diana.joseph@gmail.com> wrote in message
news:cp3ass$uiq$1@www.eclipse.org...
> Hi all,
> int division;
> repaint();
> return entry_pos++; }
> entry_pos = 0;
> return entry_pos;
> entry_pos = 0;
Re: Swing Table to SWT Table [message #447019 is a reply to message #447014] Wed, 08 December 2004 02:43 Go to previous messageGo to next message
i tried all of this but theres still somethin missing
thanx anyway for ur links...
still trying
>> Hi all,
>> int division;
>> repaint();
>> entry_pos = 0;
>> return entry_pos;
>> entry_pos = 0;
Re: Swing Table to SWT Table [message #447068 is a reply to message #447019] Wed, 08 December 2004 11:38 Go to previous messageGo to next message
Can you be more specific about what is still missing?
"anaida" <diana.joseph@gmail.com> wrote in message
news:cp5po0$i2l$1@www.eclipse.org...
> still trying
>> these are pretty well doccumented:
>>> Hi all,
>>> int division;
>>> repaint();
>>> entry_pos = 0;
>>> return entry_pos;
>>> entry_pos = 0;
Re: Swing Table to SWT Table [message #447149 is a reply to message #447068] Thu, 09 December 2004 06:56 Go to previous message
Originally posted by: dn.hotmail.com
yeah sure,
I'm now programming for the search of a specific SWT TABLE row using an
SWT InputDialog which is again opened by using the eclipse view pull Down
menuitem.
I am actually converting an entire Swing version of this part to SWT.here
goes the Swing code of which is to be converted to SWT.
public class TracerMain extends JFrame implements ActionListener{
JRadioButton[] b = new JRadioButton[5];
JTextField[] tfield = new JTextField[4];
JComboBox box;
private int rowCount;
private int division = 0;
private String r="";
static int item_index =0;
protected int getSelectedItem()
if( b[0].isSelected()) return 0;
if( b[1].isSelected()) return 1;
if( b[2].isSelected()) return 3;
if( b[3].isSelected()) return 4;
return 5;
protected String getItemTextField()
final String Item2[] = {"Trace start","Syscall entry","Syscall
exit","Trap entry","Trap exit","IRQ entry",
"IRQ exit","Sched change","Kernel timer","Soft
IRQ","Process","File system",
"Timer","Memory","Socket","IPC",
"Network","Event creation","Custom event"};
switch( division )
case 0 : if(!(r.equals(tfield[0].getText().trim())))
tab.setTableIndex();
r = tfield[0].getText();
break;
case 1 : if(item_index != box.getSelectedIndex()) tab.setTableIndex();
item_index = box.getSelectedIndex();
r = Item2[item_index];
break;
case 3 : if(!(r.equals(tfield[1].getText().trim())))
r = tfield[1].getText();
break;
case 4 : if(!(r.equals(tfield[2].getText().trim())))
r = tfield[2].getText();
break;
case 5 : if(!(r.equals(tfield[3].getText().trim())))
r = tfield[3].getText();
break;
return r;
protected JPanel createGoToEvent(){//go to the event dialog žžµé±â
JPanel main = new JPanel();
main.setLayout(new GridLayout(1,3));
ButtonGroup group = new ButtonGroup();
b[0] = new JRadioButton("CPU ID: ", false);
group.add(b[0]);
tfield[0] = new JTextField();
b[1] = new JRadioButton("Event type: ", false);
group.add(b[1]);
final String Item[] = {"Trace start","System call entry","System call
"IRQ exit","Schedule change","Kernel timer","Soft IRQ","Process
management","File system management",
"Timer management","Memory management","Socket
communication","Inter-process communication",
"Network communication","Creation of custom event","Custom event
occurrence"};
box = new JComboBox(Item);
box.setSelectedIndex(item_index);
b[2] = new JRadioButton("PID: ", false);
group.add(b[2]);
tfield[1] = new JTextField();
b[3] = new JRadioButton("Entry Length: ", false);
group.add(b[3]);
tfield[2] = new JTextField();
b[4] = new JRadioButton("Event Description: ", false);
group.add(b[4]);
tfield[3] = new JTextField();
JPanel upPanel = new JPanel(false);
upPanel.setLayout(new GridLayout(0,1));
upPanel.add(b[0]);
upPanel.add(b[1]);
upPanel.add(b[2]);
upPanel.add(b[3]);
upPanel.add(b[4]);
JPanel fieldPanel = new JPanel(false);
fieldPanel.setLayout(new GridLayout(0,1));
fieldPanel.add(tfield[0]);
fieldPanel.add(box);
fieldPanel.add(tfield[1]);
fieldPanel.add(tfield[2]);
fieldPanel.add(tfield[3]);
switch( division )
case 0 : b[0].setSelected(true);
break;
case 1 : b[1].setSelected(true);
break;
case 3 : b[2].setSelected(true);
break;
case 4 : b[3].setSelected(true);
break;
case 5 : b[4].setSelected(true);
break;
main.add(upPanel);
main.add(fieldPanel);
return main;
public void actionPerformed(ActionEvent e)
if(e.getActionCommand().equals("Go to Event"))
if(rowCount != 0)
String option[] = {"Find","Close"};
JPanel p = createGoToEvent();
while(true)
if(JOptionPane.showOptionDialog(this, p, "Go to Event",
JOptionPane.OK_CANCEL_OPTION, JOptionPane.INFORMATION_MESSAGE, null,
option, option[0]) == 0)
division = getSelectedItem();
SelectItem = getItemTextField();
tab.selectTable(SelectItem,rowCount,division);
else break;
repaint();
return entry_pos++;
entry_pos = 0;
return entry_pos;
entry_pos = 0;
hope this is sufficient
thanx in advance
Previous Topic:displaying HTML in dialog
Next Topic:Table Cell Selection
Current Time: Fri Jun 25 14:24:07 GMT 2021
Powered by FUDForum. Page generated in 0.02106 seconds
