Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Toolbar Problem.
Toolbar Problem. [message #446429] Thu, 25 November 2004 09:29 Go to next message
Originally posted by: wudong.At.sklse.org
Hi, Everyone:
I have a problem when set the image for a ToolItem.
When I want to use the display an icon on the toolbar, the image displayed is always has an white background when it's GIF format, or black background when it's PNG format. I'm sure the transparent background has been set in the image files. What's the problem may it be?
Thank you.
Re: Toolbar Problem. [message #446431 is a reply to message #446429] Thu, 25 November 2004 10:57 Go to previous messageGo to next message
Benjamin Pasero is currently offline Benjamin PaseroFriend
wudong wrote:
> Hi, Everyone:
> Thank you.
recently a bug report was fixed on this issue, see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=35040
Ben
Re: Toolbar Problem. [message #446464 is a reply to message #446431] Thu, 25 November 2004 12:25 Go to previous messageGo to next message
Hello Benjamin,
Thank you for you help, and I have check the URL you gives.
But i'm not sure to get the bug-fixing solution. Must I check it from CVS to get the newest file with the bug fixed?
Sorry for the question if it's silly.
> wudong wrote:
>> Hi, Everyone:
>> be?
>> Thank you.
> Regards,
> Ben
Re: Toolbar Problem. [message #446476 is a reply to message #446464] Thu, 25 November 2004 15:22 Go to previous message
In order to use the latest SWT version, you would have to download
the latest SWT Integration Build from here:
http://download.eclipse.org/downloads/drops/I-I20041124-2004 11240800/index.php
(bottom of the page where it tells "SWT Binary and Source")
Ben
> Hello Benjamin,
>>wudong wrote:
>>>Hi, Everyone:
>>>be?
>>>Thank you.
>>Hi,
>>Regards,
>>Ben
Previous Topic:Best way to track modified state in SWT app
Next Topic:Is it possible to set a background image for the form?
Current Time: Fri Jun 25 01:53:17 GMT 2021
Powered by FUDForum. Page generated in 0.02155 seconds
