Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Get the size of a view
Re: Get the size of a view [message #446405 is a reply to message #446403] |
Wed, 24 November 2004 16:39 |
Kai Fischer Messages: 11 Registered: July 2009 |
Thanks for your reply Veronika, but seems it doesn`t work correct in my
case. I am developing an eclipse plugin, my content is created
dymnamicly and after that, i want to decide if scrollbars are needed.
The composite which represents the content, includes other composites.
When i try to use something like
sc2.setMinSize(c2.computeSize(SWT.DEFAULT, SWT.DEFAULT));
the whole content is displayed, but now scrollbars are shown. I could
see my the content which is to large for the visible area, when resize
the view.
Is it possible that a view has a different behavior in this case then a
normal window?
If i use getClientArea() on a composite in my view, i get the visible
area of the view. I tried to use setSize on my ScrolledComposite and
then use setMinSize(), but i doesen't seems to work, too.
Any idea?
Veronika Irvine wrote:
> You should give setMinSize the preferred size of the contents of the
> ScrolledComposite not the parent of teh ScrolledComposite. The View is the
> parent.
> See the example from the class javadoc for ScrolledComposite:
> // set the minimum width and height of the scrolled content - method 2
> final ScrolledComposite sc2 = new ScrolledComposite(shell, SWT.H_SCROLL |
> SWT.V_SCROLL | SWT.BORDER);
> sc2.setExpandHorizontal(true);
> sc2.setExpandVertical(true);
> final Composite c2 = new Composite(sc2, SWT.NONE);
> sc2.setContent(c2);
> c2.setBackground(blue);
> layout = new GridLayout();
> layout.numColumns = 4;
> c2.setLayout(layout);
> Button b2 = new Button (c2, SWT.PUSH);
> b2.setText("first button");
> "Kai" <junkworld@gmx.de> wrote in message
> news:co1nm7$3jr$1@www.eclipse.org...
>>Hi!
>>In a view i want to display a content, which might be larger than the
>>visible area of the view. I use a ScrolledComposite which has the method
>>setMinSize() where you can set the minimal Size at which Scrollbars should
>>be shown. The only way i see is to giveMinSize the dimension of the view.
>>Is there some way to get the current dimension of a view?
>>Thanks in advance.
>>Kai
>>(I am using Eclipse 3.1 on W2k)
Re: Get the size of a view [message #446414 is a reply to message #446405] |
Wed, 24 November 2004 18:02 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
Views work the same as any other SWT Composite. Please give a code example
showing your problem.
news:co2dff$jv2$1@www.eclipse.org...
> case. I am developing an eclipse plugin, my content is created dymnamicly
> and after that, i want to decide if scrollbars are needed. The composite
> the whole content is displayed, but now scrollbars are shown. I could see
> my the content which is to large for the visible area, when resize the
> view.
> normal window?
> If i use getClientArea() on a composite in my view, i get the visible area
> of the view. I tried to use setSize on my ScrolledComposite and then use
> Any idea?
>> the parent.
>> sc2.setContent(c2);
>>>Hi!
>>>should be shown. The only way i see is to giveMinSize the dimension of
>>>the view.
>>>Thanks in advance.
>>>Kai
Re: Get the size of a view [message #446421 is a reply to message #446414] |
Wed, 24 November 2004 18:29 |
viewComposite = new ScrolledComposite(parent, SWT.V_SCROLL | SWT.H_SCROLL );
viewComposite.setExpandHorizontal(true);
viewComposite.setExpandVertical(true);
commandComposite = new Composite (viewComposite,SWT.NONE);
commandComposite.setLayout(new GridLayout(1, false));
commandComposite.setLayoutData(new GridData());
viewComposite.setContent(commandComposite);
//dynamic add composites to commandComposite
viewComposite.setMinSize(commandComposite.computeSize(SWT.DE FAULT,
SWT.DEFAULT));
// i tried this, but it seems to have no effect
//viewComposite.setSize(viewComposite.getClientArea().width, viewComposite.getClientArea().height);
commandComposite.layout(true);
viewComposite.layout(true);
parent.layout(true);
>>view.
>>normal window?
>>Any idea?
>>>the parent.
>>>sc2.setContent(c2);
>>>>Hi!
>>>>the view.
>>>>Thanks in advance.
>>>>Kai
Re: Get the size of a view [message #446463 is a reply to message #446421] |
Thu, 25 November 2004 12:17 |
OK i figured it out, in my code was missing:
viewComposite.setLayoutData(new GridData(GridData.FILL_VERTICAL));
which seems to be necessary.
> SWT.H_SCROLL );
> SWT.DEFAULT));
>> example showing your problem.
>>> my case. I am developing an eclipse plugin, my content is created
>>> resize the view.
>>> a normal window?
>>> Any idea?
>>>> is the parent.
>>>> SWT.H_SCROLL | SWT.V_SCROLL | SWT.BORDER);
>>>> sc2.setContent(c2);
>>>>> Hi!
>>>>> the visible area of the view. I use a ScrolledComposite which has
>>>>> the method setMinSize() where you can set the minimal Size at which
>>>>> Scrollbars should be shown. The only way i see is to giveMinSize
>>>>> Thanks in advance.
>>>>> Kai
Current Time: Sat Apr 20 02:46:03 GMT 2024
Powered by FUDForum. Page generated in 0.03854 seconds
