Home » Eclipse Projects » Standard Widget Toolkit (SWT) » composite.setVisible(false) taking up space
composite.setVisible(false) taking up space [message #445880] Thu, 11 November 2004 15:55 Go to next message
Maureen Kraft is currently offline Maureen KraftFriend
I would like to set a control invisible such that it not only doesn't
appear but also no longer takes up space on its parent composite.
I am trying the following without luck.
m_parent.getDisplay().asyncExec(new Runnable()
public void run()
child.setVisible(false);
child.pack();
child.redraw();
child.getParent().pack();
child.getParent().redraw();
The child becomes invisible but still takes up the space that it had
allocated on the parent. Do I need to actually dispose of the child to get
it to free up its space?
Re: composite.setVisible(false) taking up space [message #445885 is a reply to message #445880] Thu, 11 November 2004 16:51 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
Currently, yes you need to dispose of the widget.
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49426
"Moe" <maureen_kraft@us.ibm.com> wrote in message
news:cn020u$jsi$1@eclipse.org...
> public void run()
> child.pack();
> child.redraw();
Re: composite.setVisible (false) taking up space [message #445914 is a reply to message #445880] Thu, 11 November 2004 19:19 Go to previous message
Dimitry Fayerman is currently offline Dimitry FayermanFriend
I was struggling with the same problem.
Disposing is very inconvenient especially if you have a complex layout and you want the control to show up in a certain space when is made visible again.
I solved the problem by overriding computeSize on the composite as follows:
public Point computeSize(int wHint, int hHint, boolean changed) {
if (!isVisible()) {
return new Point(0,0);
} else {
return super.computeSize(wHint, hHint, changed);
I think this issue should be addressed by the SWT development group cause is causes a lot of headaches.
Previous Topic:set cursor to Sash from SashForm
Next Topic:Executable jar for SWT standalone
Current Time: Wed Nov 25 14:52:27 GMT 2020
Powered by FUDForum. Page generated in 0.01833 seconds
