Home » Eclipse Projects » Standard Widget Toolkit (SWT) » set cursor to Sash from SashForm
set cursor to Sash from SashForm [message #445333] Tue, 02 November 2004 15:50 Go to next message
Originally posted by: mania.sigma.ispras.ru
Hello.
How can I change cursor to SWT.CURSOR_SIZEN when it is possible to make
resize in SashForm?
Is there any possibility to set cursor to Sash from SashForm?
Maria.
Re: set cursor to Sash from SashForm [message #445370 is a reply to message #445333] Thu, 04 November 2004 14:13 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
The Sash changes the cursor as required without programmatic intervention.
Why are you trying to change the cursor yourself?
"Maria Yurchenko" <mania@sigma.ispras.ru> wrote in message
news:cm8anh$h1m$1@eclipse.org...
> Hello.
> resize in SashForm?
> Maria.
Re: set cursor to Sash from SashForm [message #445372 is a reply to message #445370] Thu, 04 November 2004 14:35 Go to previous messageGo to next message
Hi, Veronika.
I have the following code.
SashForm sashForm = new SashForm(shell, SWT.VERTICAL);
sashForm.SASH_WIDTH = 4;
GridData gd2 = new GridData(GridData.FILL_BOTH);
sashForm.setLayoutData(gd2);
final Composite composite = new Composite(sashForm, SWT.NONE |
SWT.BORDER);
textEditor = new TextEditor(this);
textEditor.createContents(composite);
composite.setLayoutData(new GridData(GridData.FILL_BOTH));
TabsFolder tabs = new TabFolder(sashForm, SWT.NONE);
GridData gd = new GridData(GridData.FILL_HORIZONTAL);
gd.heightHint = 150;
tabs.setLayoutData(gd);
//creating tabs here ...
//some other components added here
shell.pack();
shell.open();
I can resize my components but Cursor doesn't change at all.
Maybe I need to do something else to make it change?
Maria.
>>Hello.
>>resize in SashForm?
>>Thanks,
>>Maria.
Re: set cursor to Sash from SashForm [message #445414 is a reply to message #445372] Fri, 05 November 2004 11:55 Go to previous messageGo to next message
Some of the layouts in your code are incorrect. I modified it slightly in
the example below and the example works fine for me (used Text instead of
TextEditor but that should not matter).
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout (new GridLayout ());
SashForm sashForm = new SashForm (shell, SWT.VERTICAL);
GridData gd2 = new GridData (GridData.FILL_BOTH);
sashForm.setLayoutData (gd2);
final Composite composite = new Composite (sashForm, SWT.NONE |
SWT.BORDER);
composite.setLayout (new FillLayout ()); // !!!!! REQUIRED
Text textEditor = new Text (composite, SWT.BORDER);
//textEditor = new TextEditor(this);
//textEditor.createContents(composite);
//composite.setLayoutData(new GridData(GridData.FILL_BOTH)); // !!!!
HAS NO EFFECT
TabFolder tabs = new TabFolder (sashForm, SWT.NONE);
for (int i = 0; i < 10; i++) {
TabItem item = new TabItem (tabs, SWT.NONE);
item.setText ("TabItem " + i);
//GridData gd = new GridData(GridData.FILL_HORIZONTAL);
//gd.heightHint = 150;
//tabs.setLayoutData(gd); // !!!! HAS NO EFFECT
shell.pack ();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
news:cmdf0s$cuk$1@eclipse.org...
> Hi, Veronika.
> SWT.BORDER);
> shell.pack();
> shell.open();
> Maria.
>> intervention. Why are you trying to change the cursor yourself?
>>>Hello.
>>>resize in SashForm?
>>>Thanks,
>>>Maria.
Re: set cursor to Sash from SashForm [message #445792 is a reply to message #445414] Thu, 11 November 2004 13:07 Go to previous messageGo to next message
Hi again.
And what is the requerement?
Here is code of creating one of tabs.
What is wrong with it? Can I add such tab (with GridData and GridLayout)
into tab?
private Control createLogTab(Composite parent) {
final Composite composite = new Composite(parent, SWT.NONE);
GridData gd = new GridData();
gd.horizontalSpan = 10;
gd.horizontalAlignment = GridData.FILL;
gd.grabExcessHorizontalSpace = true;
gd.verticalAlignment = GridData.FILL;
gd.grabExcessVerticalSpace = true;
composite.setLayoutData(gd);
composite.setLayout(new GridLayout(1, false));
logView = new LogView();
logView.createPartControl(composite);
return composite;
Maria.
> SWT.BORDER);
> HAS NO EFFECT
> shell.pack ();
> shell.open ();
> display.dispose ();
>>Hi, Veronika.
>>SWT.BORDER);
>> shell.pack();
>> shell.open();
>>Maria.
>>>>Hello.
>>>>resize in SashForm?
>>>>Thanks,
>>>>Maria.
Re: set cursor to Sash from SashForm [message #445794 is a reply to message #445414] Thu, 11 November 2004 13:50 Go to previous messageGo to next message
One more thing...
I've set shell's cursor sometimes. I have some kind of runner - while it
is working I need to change cursor of shell to SWT.CURSOR_WAIT. After
runner stops I've set cursor of shell to SWT.CURSOR_ARROW back.
Cursor of Sash stopped to change itself after setting of shell cursor
(to resizable I mean).
So is there any possibility to change cursor of shell with no bad effect
on Sash cursor changing mechanizm?
Maria.
> SWT.BORDER);
> HAS NO EFFECT
> shell.pack ();
> shell.open ();
> display.dispose ();
>>Hi, Veronika.
>>SWT.BORDER);
>> shell.pack();
>> shell.open();
>>Maria.
>>>>Hello.
>>>>resize in SashForm?
>>>>Thanks,
>>>>Maria.
Re: set cursor to Sash from SashForm [message #445900 is a reply to message #445794] Thu, 11 November 2004 17:14 Go to previous messageGo to next message
When you set the cursor back you should call:
shell.setCursor (null)
This resets the cursor to the Operating System's control. Setting the value
to SWT.CURSOR_ARROW still means you are controlling the cursor.
news:cmvqvp$49l$1@eclipse.org...
> One more thing...
> Cursor of Sash stopped to change itself after setting of shell cursor (to
> resizable I mean).
> Maria.
>> in the example below and the example works fine for me (used Text instead
>> of TextEditor but that should not matter).
>> SWT.BORDER);
>> !!!! HAS NO EFFECT
>> shell.pack ();
>> shell.open ();
>> display.dispose ();
>>>Hi, Veronika.
>>> SWT.BORDER);
>>> shell.pack();
>>> shell.open();
>>>Maria.
>>>>>Hello.
>>>>>resize in SashForm?
>>>>>Thanks,
>>>>>Maria.
Re: set cursor to Sash from SashForm [message #445902 is a reply to message #445900] Thu, 11 November 2004 17:40 Go to previous message
It works perfectly.
Thank you.
It was real huge help.
Maria.
>>One more thing...
>>resizable I mean).
>>Thanks,
>>Maria.
>>>SWT.BORDER);
>>>!!!! HAS NO EFFECT
>>> shell.pack ();
>>> shell.open ();
>>> display.dispose ();
>>>>Hi, Veronika.
>>>>SWT.BORDER);
>>>> shell.pack();
>>>> shell.open();
>>>>Maria.
>>>>>>Hello.
>>>>>>resize in SashForm?
>>>>>>Thanks,
>>>>>>Maria.
Previous Topic:how to add image in Eclipse status bar
Next Topic:composite.setVisible(false) taking up space
Current Time: Tue Jul 27 22:58:58 GMT 2021
Powered by FUDForum. Page generated in 0.02306 seconds
