Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Mouse cursor
Mouse cursor [message #445230] Fri, 29 October 2004 09:57 Go to next message
Henrik Skovgaard is currently offline Henrik SkovgaardFriend
Member
Hi!
I have an application where I change the mouse cursor to SWT.CURSOR_WAIT
while information is being gathered from a database. When the retrieval is
done, I'm setting the cursor to SWT.CURSOR_ARROW. But after this is done,
the cursor does not change look when I for example hoover the cursor over a
Sash. Question is, how do I reset the cursor to 'default' behaviour ?
Thanks.
/Henrik
Re: Mouse cursor [message #445255 is a reply to message #445230] Fri, 29 October 2004 18:03 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
In which widget are you changing the cursor?
"Henrik Skovgaard" <hsk@reklamedata.dk.no.spam> wrote in message
news:clt471$php$1@eclipse.org...
> Hi!
a
> Thanks.
> /Henrik
Re: Mouse cursor [message #445268 is a reply to message #445255] Mon, 01 November 2004 07:53 Go to previous messageGo to next message
Member
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:clu0kq$ito$1@eclipse.org...
I'm changing it on the Shell.
/Henrik
Re: Mouse cursor [message #445275 is a reply to message #445268] Mon, 01 November 2004 14:31 Go to previous messageGo to next message
If you disable the shell then set the cursor, it will change for every
control in the shell. The way that cursors work is that if a control
defines a cursor, that cursor is used. Otherwise, the inherited cursor is
used. When a control is disabled, the cursor of the parent is used.
news:cm4q1p$j2f$1@eclipse.org...
> /Henrik
Re: Mouse cursor [message #445278 is a reply to message #445275] Mon, 01 November 2004 15:02 Go to previous messageGo to next message
Member
news:cm5hc5$i4v$1@eclipse.org...
I have a table I fill data into, and while waiting for the database
containing the data, I want to show a waiting cursor. So should I add the
cursor to the table or what? And after the table has been updated, what do I
do then? Should the entire table be redrawn in order to 'reset' the cursor
to standard behavior? I'm not sure I understand you completely...
/Henrik
Re: Mouse cursor [message #445326 is a reply to message #445278] Tue, 02 November 2004 15:22 Go to previous messageGo to next message
Is the table being filled from a background thread or from the UI thread?
news:cm5j5k$llg$1@eclipse.org...
is
I
> /Henrik
Re: Mouse cursor [message #445342 is a reply to message #445326] Wed, 03 November 2004 13:46 Go to previous messageGo to next message
Member
news:cm88nu$b9o$1@eclipse.org...
It's being filled from a UI thread.
Re: Mouse cursor [message #445346 is a reply to message #445342] Wed, 03 November 2004 14:50 Go to previous messageGo to next message
So input is blocked to the shell while the table is filling because the UI
thread is filling the table, not reading and dispatching events. You should
set the cursor in the shell and disable the shell while the operation is
running then enable the shell and restore the cursor. If you can't get it
to work, I'll make you a snippet.
news:cmanfj$l81$1@eclipse.org...
thread?
Re: Mouse cursor [message #445357 is a reply to message #445346] Thu, 04 November 2004 08:55 Go to previous messageGo to next message
Member
news:cmar7j$u3p$1@eclipse.org...
> should
How do I restore the cursor? As far as I can see, there is no getCursor
method available?
Would be happy to see an example :-) Thanks.
/Henrik
Re: Mouse cursor [message #445382 is a reply to message #445357] Thu, 04 November 2004 18:03 Go to previous messageGo to next message
Set to "null". That will restore the default cursor. There is no
getCursor() method because it's not possible to query the default cursor on
some platforms. For example, text widgets often use an i-beam (motif
doesn't) but there's no API to query the this.
Still need the snippet?
news:cmcqp0$osd$1@eclipse.org...
UI
> > should
it
> method available?
> /Henrik
Re: Mouse cursor [message #445403 is a reply to message #445382] Fri, 05 November 2004 08:12 Go to previous message
Member
news:cmdqsb$60v$1@eclipse.org...
> on
Doh! :-) No.. thanks I got it now.. How silly I didn't figure that out!
/Henrik
Previous Topic:Why StyledText dose not word-wrap in SWT3.0
Next Topic:Help needed on FormAttachment
Current Time: Tue May 18 01:05:43 GMT 2021
Powered by FUDForum. Page generated in 0.02031 seconds
