Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Creating own widget from SWT Label
Creating own widget from SWT Label [message #445208] |
Thu, 28 October 2004 12:58 |
Francois Messages: 7 Registered: July 2009 |
Hi, I have a problem I think simple for SWT initiated.
My problem is the following, I am building an application with custom
widgets on 3 level of components:
1st level: public class Buttons extends Composite, to create custom
buttons for my application. In this class, I create a new Label(...) with
a variable text and image assigned (already implemented and working) to
simulate a button. The simulation is only switch the image of the Label,
while my images already do the "push" like button style;
2nd level: public class Keypad , instanciating a set of my custom new
Buttons(...) positionned. This level gives a position for each Buttons of
the set.
3rd level: public class MyApp, the main() with a display 800X600 and a
shell instanciating new Keypad() that is suppose to bring visible all
Buttons of the second level at the good position and image set.
As I have seen in some example, it's not recommended to extend a Label
but extend a Composite instanciating the control we want to use. Thats
what I did. But when I want to instanciate a new Label in my widget I
must add some parameters, like it's suggested :
label = new Label(this,0);
At first, it's seems strange to me, as new beginner in Java, because the
supposed parameter to put in a new Label is not the shell???
Anyway... when I do that, my custom Buttons are well displayed, good
position, good image at the right place, but no event are accessible from
the main shell, because I think there is no reference to my shell at all!
So, what I did was to pass the main shell in up to the constructor of my
Buttons and use it in the :
label = new Label(shell,0); (or Composite parent as seen in many example).
When I do that, my custom Buttons looklike to have their grey frame at the
good emplacement, with events working, but all the images of the buttons
are displayed in the top-left corner one over the other. And I realy
don't understand why!!!!
I followed the main lines of "Writing your own widgets" in www.eclipse.org
articles, and test a lot of other things with always the same result. Do
you have any idea what could be my problem?
Help! :)
... hum two last thing:
Is there any way to avoid flicking when display image in a shell?
Is there any way to do a widget modal as a display dialog?
Thanks a lot !!
Re: Creating own widget from SWT Label [message #445221 is a reply to message #445208] |
Thu, 28 October 2004 14:08 |
Steve Northover Messages: 1636 Registered: July 2009 |
This just sounds like you have a programming error. Are you adding
listeners and creating your custom control using the right parent in the
constructor? We can't really do much without a simple stand alone example
that shows what you are doing.
"Francois" <francoislamothe@hotmail.com> wrote in message
news:clqqd0$q2v$1@eclipse.org...
> the set.
example).
> Help! :)
> Thanks a lot !!
Re: Creating own widget from SWT Label [message #445224 is a reply to message #445221] |
Thu, 28 October 2004 15:17 |
Ok, so there is a sample...
The first level:
public static final int BUTTON1 = 1;
public Label image;
// my Buttons attributes
private int width;
private int height;
private int state;
private String img_src[] = {"",""}; // img_src[0]=off, img_src[1]=on
public Buttons(Composite parent, int style, int byttonType)
super(parent, style);
image = new Label(parent,style); // with this one, label background
// all appears at the right place
// and all mouse event work, but
// all the image appears in the
top
// left corner, the first packed
on
// the top
//image = new Label(this,style); // with this one, label background
// all appears at the right place,
// and image in the correspondant
// label, but no mouse event are
// working
// Switch on the button type removed here
width = 74;
height = 78;
state = OFF;
img_src[OFF]= "/root/workspace/images/buttons/button_off.png";
img_src[ON]= "/root/workspace/images/buttons/button_on.png";
// Add an event listener for mouse down only in this case...
addMouseListener(new MouseAdapter()
public void mouseDown(MouseEvent event)
if (event.button==1) // left button
Buttons.this.mouseDown(event);
// Other public functions
public void setBtnState(int new_state)
this.state = new_state;
public String getImagePath()
return this.img_src[this.state];
public void setImage(Image i)
this.image.setImage(i);
public int getWidth()
return this.width;
public int getHeight()
return this.height;
public void pack()
this.image.pack();
// Event handling stuff... working well and tested so didn't copy
// this part
public class ButtonsClickedEvent extends java.util.EventObject
Second level:
public class Keypad
Buttons button0;
// Buttons 1-9...
Image i;
public Keypad(Shell shell)
button0 = new Buttons (shell, SWT.NONE, Buttons.BUTTON1);
button0.setBtnState(0);
// Set the good image to the label
i = new Image(display,button0.getImagePath());
button0.setImage(i);
// Positionning the button
button0.setBounds(300,100,button0.getWidth(), button0.getHeight());
// Add listener to the button0
button0.addButtonsClickedListener(new ButtonsClickedListener()
public void buttonClicked(ButtonsClickedEvent event)
System.out.println("button 1 clicked ");
/* stuff*/
button0.pack();
Third level:
public class MyApp
//Main window application
public static Display display;
public static Shell shell;
private static final int app_width = 810;
private static final int app_height = 630;
public static Keypad keypad;
public static void main(String[] args)
MyApp app = new MyApp();
shell.setBounds(0,0, app_width app_height);
// Calling my Keypad
keypad = new Keypad(shell);
// here adding a background to see the background of label in
keypad
shell.open();
while(!shell.isDisposed())
if(!display.readAndDispatch())
display.sleep();
display.dispose();
// other dispose...
public QuatroApp()
display = new Display();
shell = new Shell(display);
> > the set.
> example).
> > Help! :)
> > Thanks a lot !!
Re: Creating own widget from SWT Label [message #445242 is a reply to message #445224] |
Fri, 29 October 2004 14:20 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
The following is the right way to create your label, you should not create
widgets in your parent because you have no idea what sort of layout the
parent may use.
// working
To get the mouse events, you need to add the mouse listener to the Label and
resend the mouse event from Buttons using notifyListeners. NOTE: You really
shouldn't be listening for low level events like MouseDown on Buttons in
your applcaition because this results in an inaccessible widget - your
application should instead look for events like Selection and Buttons should
fire the Selection event for a mouse action and a keyboard action:
public Buttons(Composite parent, int style, int byttonType) {
image.addListener(SWT.MouseDown, new Listener() {
public void handleEvent(Event e) {
Event event = new Event();
event.widget = Buttons.this;
event.time = e.time;
Buttons.this.notifyListeners(SWT.Selection, event);
image.addListener(SWT.KeyDown, new Listener() {
if (event.character == ' ') {
public void addSelectionListener(SelectionListener listener) {
checkWidget();
if (listener == null) {
SWT.error(SWT.ERROR_NULL_ARGUMENT);
TypedListener typedListener = new TypedListener(listener);
addListener(SWT.Selection, typedListener);
addListener(SWT.DefaultSelection, typedListener);
news:clr2it$edo$1@eclipse.org...
> The first level:
> public Label image;
> private int width;
> private int height;
> private int state;
> top
> on
> // the top
> // working
> width = 74;
> height = 78;
> state = OFF;
> return this.width;
> return this.height;
> public void pack()
> this.image.pack();
> // this part
> Second level:
> public class Keypad
> Buttons button0;
> // Buttons 1-9...
> Image i;
> /* stuff*/
> button0.pack();
> Third level:
> public class MyApp
> keypad
> shell.open();
> display.sleep();
> display.dispose();
> // other dispose...
> public QuatroApp()
>> example
>> > with
>> > Label,
>> > of
>> > the set.
>> > the
>> > from
>> > all!
>> > my
>> example).
>> > the
>> > buttons
>> > www.eclipse.org
>> > Do
>> > Help! :)
>> > Thanks a lot !!
Re: Creating own widget from SWT Label [message #445314 is a reply to message #445242] |
Mon, 01 November 2004 18:46 |
Thank you Veronika :) That is working very well.
> parent may use.
> // working
> checkWidget();
> > The first level:
> > public Label image;
> > private int width;
> > private int height;
> > private int state;
> > top
> > on
> > // the top
> > // working
> > width = 74;
> > height = 78;
> > state = OFF;
> > return this.width;
> > return this.height;
> > public void pack()
> > this.image.pack();
> > // this part
> > Second level:
> > public class Keypad
> > Buttons button0;
> > // Buttons 1-9...
> > Image i;
> > /* stuff*/
> > button0.pack();
> > Third level:
> > public class MyApp
> > keypad
> > shell.open();
> > display.sleep();
> > display.dispose();
> > // other dispose...
> > public QuatroApp()
> >> example
> >> > with
> >> > Label,
> >> > of
> >> > the set.
> >> > the
> >> > from
> >> > all!
> >> > my
> >> example).
> >> > the
> >> > buttons
> >> > www.eclipse.org
> >> > Do
> >> > Help! :)
> >> > Thanks a lot !!
Current Time: Thu Apr 18 08:43:03 GMT 2024
Powered by FUDForum. Page generated in 0.01887 seconds
