Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Combo box doesn't take objects?
Combo box doesn't take objects? [message #445186] |
Wed, 27 October 2004 16:37 |
Originally posted by: ukalumni.hotmail.com
I'm working on my first SWT application, so please bear with me. In
Swing, I can populate a JComboBox with a bunch of objects such as the
following:
public class NameValue
private String name = "Tennessee";
private String value = "TN";
public String toString()
return name;
other setters and getters not included
When that JComboBox is displayed, the toString method is called and
Tennessee shows up, but when I get the selected item, I can call the
(not included in my example) getValue() method to return "TN".
I'm sure there's a way to do this in SWT, but since the Combo object
only takes Strings, I don't know how to do this. Can anyone point me in
the right direction?
--Michael
Re: Combo box doesn't take objects? [message #445215 is a reply to message #445186] |
Thu, 28 October 2004 13:59 |
Steve Northover Messages: 1636 Registered: July 2009 |
The combo box only takes strings. Use setItems() or add() to populate it.
When an item is selected, use Combo.getText() to determine the selection and
act on it In a read-only combo box, you could use Combo.getSelectionIndex()
to map the selection into an item in an array of objects. In an editable
combo, since the user can type anything, you can't do this. Hope this
helps.
"Michael Molloy" <ukalumni@hotmail.com> wrote in message
news:cloimv$rt6$1@eclipse.org...
> following:
> return name;
> --Michael
Re: Combo box doesn't take objects? [message #445231 is a reply to message #445186] |
Fri, 29 October 2004 11:30 |
Originally posted by: micasim.gmx.de
On Wed, 27 Oct 2004 11:37:14 -0500, Michael Molloy <ukalumni@hotmail.com>
> following:
> return name;
> --Michael
Hi Michael,
Looking for methods you know from Swing in SWT, you'll probably fail. SWT
is an alternative to AWT. JFace sits on top of SWT and is more of the kind
of Swing.
In your example, use org.eclipse.jface.viewers.ComboViewer on top of the
swt.widgets.Combo:
ComboViewer vwr = new ComboViewer (swtCombo);
vwr.setContentProvider (new
org.eclipse.jface.viewers.ArrayContentProvider());
vwr.setLabelProvider (new org.eclipse.jface.viewers.LabelProvider());
vwr.setInput (list); // list may be an array or a Collection holding the
objects to display, e.g., NameValue[] list;
Hope that helps,
Michael
Re: Combo box doesn't take objects? [message #445239 is a reply to message #445231] |
Fri, 29 October 2004 12:30 |
Thanks for your response, and Steve, if you're reading this, thank you
as well.
I'm trying to unlearn Swing as I go.
--Michael
>> following:
>> return name;
>> in the right direction?
>> Thanks,
>> --Michael
> Hi Michael,
> SWT is an alternative to AWT. JFace sits on top of SWT and is more of
> the kind of Swing.
> the swt.widgets.Combo:
> the objects to display, e.g., NameValue[] list;
> Hope that helps,
> Michael
Re: Combo box doesn't take objects? [message #445254 is a reply to message #445239] |
Fri, 29 October 2004 17:59 |
In SWT, the data is front loaded into the widgets rather than implementing a
method that gets called when the data is required. Rather, interaction is
done through listeners. As of 3.0, only the virtual table requests data at
a later time. Hope this helps.
news:cltdbs$aur$1@eclipse.org...
> as well.
> --Michael
> >> following:
> >> return name;
> >> Thanks,
> >> --Michael
> > Hi Michael,
> > the kind of Swing.
> > Hope that helps,
> > Michael
Current Time: Thu Apr 25 22:21:39 GMT 2024
Powered by FUDForum. Page generated in 0.03205 seconds
