SWT over X-Windows? [message #444983] |
Sun, 24 October 2004 12:53 |
Originally posted by: krayspam.arcor.de
Greetings,
I would like to create a gui application with SWT but this application will
run on a PDA and the actual monitor screen will be an X Server. So imagine
creating an app on a pocket PC and then showing that app on a bigger
computer after it connects to the PDA with TCP.
Are there any ports of SWT that can do this? If not, how hard would it be to
port SWT to use the XLib ?
-- Regards
-- Robert Simmons Jr.
Author: Hardcore Java, Published March 2004 by O'Reilly
http://www.oreilly.com/catalog/hardcorejv/
Re: SWT over X-Windows? [message #444984 is a reply to message #444983] |
Sun, 24 October 2004 13:19 |
Originally posted by: joerg.von.frantzius.artnology.nospam.com
Hi Robert,
if your PDA has some Linux running on it that includes X, there should
be no problem ;-)
Robert Simmons schrieb:
>Greetings,
>-- Regards
Re: SWT over X-Windows? [message #444985 is a reply to message #444984] |
Sun, 24 October 2004 13:23 |
Alas, that was really just a joke. As far as I know, there is no
Linux/ARM port of SWT available, unfortunately. Maybe it's not even hard
to do, but I guess you'll probably want to let it run on Windows CE anyway?
Joerg von Frantzius schrieb:
> Hi Robert,
> be no problem ;-)
>> Greetings,
>> application will run on a PDA and the actual monitor screen will be
>> an X Server. So imagine creating an app on a pocket PC and then
>> showing that app on a bigger computer after it connects to the PDA
>> with TCP.
>> it be to port SWT to use the XLib ?
>> -- Regards
Re: SWT over X-Windows? [message #444986 is a reply to message #444985] |
Sun, 24 October 2004 13:32 |
It would have to run on PocketPC os.
How hard would the port be if I could locate a C XClient library?
-- robert
"Joerg von Frantzius" <joerg.von.frantzius@artnology.nospam.com> wrote in
message news:clga1i$ad8$1@eclipse.org...
> Alas, that was really just a joke. As far as I know, there is no Linux/ARM
> port of SWT available, unfortunately. Maybe it's not even hard to do, but
>> Hi Robert,
>> if your PDA has some Linux running on it that includes X, there should be
>> no problem ;-)
>>> Greetings,
>>> will run on a PDA and the actual monitor screen will be an X Server. So
>>> imagine creating an app on a pocket PC and then showing that app on a
>>> bigger computer after it connects to the PDA with TCP.
>>> -- Regards
Re: SWT over X-Windows? [message #444988 is a reply to message #444986] |
Sun, 24 October 2004 13:45 |
Clemens Eisserer Messages: 21 Registered: July 2009 |
Hi there!
Well quite hard because:
1.) Swt might need some changes to run on Arm
2.) GTK/Motif based ports have never been ported to windows (cause it
would be nonsense).
If you would linux on your pda it would be a lot easier!
> >> Hi Robert,
> >> no problem ;-)
> >>> Greetings,
> >>> -- Regards
Re: SWT over X-Windows? [message #444989 is a reply to message #444988] |
Sun, 24 October 2004 14:29 |
Unfortunately I have something called a "Customer" who wants to run it on a
PDA and he doesnt want to tell his customers they have to install lnux on
their PDA to use it because that would mean he would have something like 2
customers
SWT already runs on ARM btw. Just not XClient on arm.
-- Robert
"Clemens Eisserer" <ceisserer@utanet.at> wrote in message
news:clgble$cje$1@eclipse.org...
> Hi there!
> would be nonsense).
>> > Linux/ARM
>> > but
>> >> Hi Robert,
>> >> be
>> >> no problem ;-)
>> >>> Greetings,
>> >>> application
>> >>> So
>> >>> it
>> >>> -- Regards
FUDForum. Page generated in 0.03166 seconds
