Home » Eclipse Projects » Rich Client Platform (RCP) » List with images
List with images [message #444931] Fri, 24 February 2006 15:37 Go to next message
Antonio Gurisatti is currently offline Antonio GurisattiFriend
I need to build a list where its entries represent different kinds of objects. So, I'd like to add an image to each entry in the List so you can see the kind of object it represents.
The problem is that I don't know how to do it or found an example.
I would appreciate very much any help
Re: List with images [message #444939 is a reply to message #444931] Fri, 24 February 2006 18:51 Go to previous message
Ian Leslie is currently offline Ian LeslieFriend
> Thanks
Using JFace:
Here is an article that describes how to use a table viewer but uses no
images (which looks like a list if you use only one column):
http://www.eclipse.org/articles/Article-Table-viewer/table_v iewer.html
Here is an article that shows how to use images for your label provider
(see above):
http://www.eclipse.org/articles/Article-Using%20Images%20In% 20Eclipse/Using%20Images%20In%20Eclipse.html
An excellent article on how to use a TreeViewer (the TableViewer you want
is very simpliar and reading the API differenes will probably lead you in
the right direction):
http://www.eclipse.org/articles/treeviewer-cg/TreeViewerArti cle.htm
This site has a lot of SWT and JFace examples. I have found useful things
here but it is hard to find the JFace examples sometimes:
http://www.java2s.com/ExampleCode/SWT-JFace-Eclipse/CatalogS WT-JFace-Eclipse.htm
For SWT examples this site is great:
http://www.eclipse.org/swt/snippets/
I hope one of those helps,
Ian
Previous Topic:Updating the status line
Next Topic:ctrl-c / ctrl-v detection
Current Time: Thu Dec 05 22:51:05 GMT 2024
Powered by FUDForum. Page generated in 0.03509 seconds
