can anyone use wizard ? [message #444362] |
Tue, 12 October 2004 04:15 |
Originally posted by: cicadaw.hotmail.com
I create two pages and add the two pages into the wizard. But why I can't
see the seperate pages but a whole page which contains the controls on both
pages.
the following is the codes:
public class NewServer extends Wizard {
public NewServerSelection page;
public ServerLogin page2;
/* (non-Javadoc)
* @see org.eclipse.jface.wizard.IWizard#addPages()
public void addPages() {
page = new NewServerSelection("test");
addPage(page);
page2 = new ServerLogin("test2");
// page2.setTitle( "Html File2" );
// page2.setDescription( "Enter file name.2" );
addPage(page2);
/* (non-Javadoc)
* @see org.eclipse.jface.wizard.IWizard#performFinish()
public boolean performFinish() {
if (page.getServerAddress().getText().equalsIgnoreCase("")
||page.getServerPort().getText().equalsIgnoreCase(""))
page.setErrorMessage("You must provide an address and an port.");
//page.setPageComplete(false);
return false;
else return true;
public class NewServerSelection extends WizardPage {
private Text ServerAddress;
private Text ServerPort;
* @param pageName
protected NewServerSelection(String pageName) {
super(pageName);
setTitle("Create A New Server");
setDescription("Please enter the never and port");
* @return Returns the serverAddress.
public Text getServerAddress() {
return ServerAddress;
* @return Returns the serverPort.
public Text getServerPort() {
return ServerPort;
* @param serverPort The serverPort to set.
/* (non-Javadoc)
* @see
org.eclipse.jface.dialogs.IDialogPage#createControl(org.ecli pse.swt.widgets.
Composite)
public void createControl(Composite parent) {
GridLayout pageLayout = new GridLayout();
pageLayout.numColumns = 2;
parent.setLayout(pageLayout);
parent.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
Label serverip = new Label(parent, SWT.NONE);
serverip.setText("Server IP:");
ServerAddress = new Text(parent, SWT.BORDER);
Label serverport = new Label(parent, SWT.NONE);
serverport.setText("Server PORT:");
ServerPort = new Text(parent, SWT.BORDER);
// create main composite & set layout
Composite mainComposite = new Composite( parent, SWT.NONE );
// mainComposite.setLayout( new FillLayout( ) );
// mainComposite.setLayoutData( new GridData( GridData.FILL_BOTH ) );
// create contents
// createPageContent( mainComposite );
// page setting
setControl( mainComposite );
setPageComplete( true );
public class ServerLogin extends WizardPage {
private Text UserName;
private Text Password;
* @param pageName
protected ServerLogin(String pageName) {
super(pageName);
setTitle("Login");
setDescription("Please enter the username and password");
/* (non-Javadoc)
* @see
Composite)
serverip.setText("User Name:");
UserName = new Text(parent, SWT.BORDER);
serverport.setText("Password:");
Password = new Text(parent, SWT.BORDER);
//setControl(parent);
//// create main composite & set layout
// // create contents
// //createPageContent( mainComposite );
// // page setting
// setPageComplete( true );
* @return Returns the password.
public Text getPassword() {
return Password;
* @return Returns the userName.
public Text getUserName() {
return UserName;
Re: can anyone use wizard ? [message #444440 is a reply to message #444362] |
Tue, 12 October 2004 17:38 |
Originally posted by: manish.garg.gmail.com
You also have to set one of the pages as the initial pages.
The API is:
defaultPage.init(structuredSelection); // defaultPage can be page or page2
for you.
structuredSelection is passed into the init method that should be
overridden.
"cicada" <cicadaw@hotmail.com> wrote in message
news:ckflb1$bdm$1@eclipse.org...
both
> pages.
> /* (non-Javadoc)
> addPage(page);
> addPage(page2);
> /* (non-Javadoc)
> return false;
> else return true;
> * @param pageName
> super(pageName);
> return ServerPort;
> /* (non-Javadoc)
> * @see
> Composite)
> // create contents
> // page setting
> * @param pageName
> super(pageName);
> setTitle("Login");
> /* (non-Javadoc)
> * @see
> Composite)
> // // page setting
> return Password;
> return UserName;
FUDForum. Page generated in 0.03010 seconds
