Home » Eclipse Projects » Rich Client Platform (RCP) » exporting feature-based rcp product - help!
exporting feature-based rcp product - help! [message #444255] |
Sun, 12 February 2006 00:58 |
Michael Schmidt Messages: 45 Registered: July 2009 |
Member |
Folks,
I'm sorry to bother you, but I've spent five days on this problem and
can't get it to work. The books I have relate to Eclipse 3.0, and it
seems this aspect of Eclipse was changed significantly in 3.1.2. The best
info I could find was the on-line rcp tutorial, which I tried to follow -
but no success.
I've created a plug-in that works beautifully. It is branded via the
plugin.xml file. I then created a feature, and then in the plugin project
I created a feature-based product, defining a new product named
pluginproduct. Synch and run the feature-based product gave the following
results.
--->error log
!SESSION 2006-02-11 17:46:43.46
eclipse.buildId=unknown
java.version=1.5.0_05
Framework arguments: -product PgClient.pluginproduct -pdelaunch
Command-line arguments: -product PgClient.pluginproduct -data
E:\runtime-feature.product -dev
file:E:/JavaPg/.metadata/.plugins/org.eclipse.pde.core/featu re.product/dev.properties
-pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2006-02-11 17:46:44.93
!MESSAGE Bundle update@E:/JavaPg/mschmidt.pgclient/ [3] was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2006-02-11 17:46:44.93
!MESSAGE Missing required bundle org.eclipse.ui.intro_0.0.0.
!MESSAGE Missing required bundle org.eclipse.help.base_0.0.0.
!ENTRY org.eclipse.core.runtime 2006-02-11 17:46:44.109
!MESSAGE Product PgClient.pluginproduct could not be found.
!ENTRY org.eclipse.osgi 2006-02-11 17:46:44.125
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:204)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!SUBENTRY 1 org.eclipse.osgi 2006-02-11 17:46:44.125
!SUBENTRY 1 org.eclipse.osgi 2006-02-11 17:46:44.140
--->Here is the plugin manifest.mf
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: PgClient Plug-in
Bundle-SymbolicName: PgClient; singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: pgClient.PgClientPlugin
Bundle-Localization: plugin
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.ui.intro,
org.eclipse.help,
Eclipse-AutoStart: true
Bundle-Vendor: Michael Schmidt
--->Here is the plugin.xml file
<?eclipse version="3.1"?>
<!-- Basic plugin definition. The %field tags reference entries in the
plugin.properties file -->
<plugin>
<!-- Plugin application extension properties -->
<extension
id="application"
point="org.eclipse.core.runtime.applications">
<application>
<run
class="pgClient.App.Application">
</run>
</application>
</extension>
<!-- Perspective extension properties -->
<extension point="org.eclipse.ui.perspectives">
<perspective
name="pgClient.perspective"
class="pgClient.App.Perspective"
id="PgClient.perspective">
</perspective>
</extension>
<!-- Product branding properties -->
<extension
id="product"
point="org.eclipse.core.runtime.products">
<product
application="PgClient.application"
description="PostgreSQL Client"
name="%productName">
<!-- Set icons for application title bar -->
<property
name="windowImages"
value="icons/pgIcon.gif, icons/pgIcon32.gif"/>
<!-- Set About screen text -->
<property
name="aboutText"
value="%aboutText"/>
<!-- Set About screen image -->
<property
name="aboutImage"
value="product_lg.gif"/>
<!-- Set application name for application title bar -->
<property
name="appName"
value="%appName"/>
<!-- Set file that contains customization properties -->
<property
name="preferenceCustomization"
value="plugin_customization.ini"/>
</product>
</extension>
<!-- Welcome feature extension properties -->
<extension point="org.eclipse.ui.intro">
<intro
class="org.eclipse.ui.intro.config.CustomizableIntroPart"
icon="icons/intro.gif"
id="pgClient.introID">
</intro>
<introProductBinding
introId="pgClient.introID"
productId="PgClient.product">
</introProductBinding>
</extension>
<!-- Welcome feature configuration properties -->
<extension point="org.eclipse.ui.intro.config">
<config
content="intro.xml"
id="PgClient.configId">
<presentation
home-page-id="root">
<implementation
kind="html"
os="win32,linux,macosx">
</implementation>
</presentation>
</config>
</extension>
<!-- Help system feature configuration properties -->
<extension point="org.eclipse.help.toc">
<toc primary="true" file="toc_book.xml"/>
<toc primary="false" file="toc_adapting.xml"/>
<toc primary="false" file="toc_faqs.xml"/>
<toc primary="false" file="toc_features.xml"/>
<toc primary="false" file="toc_skills.xml"/>
</extension>
<!-- Preferences page to set database connection options -->
<extension point="org.eclipse.ui.preferencePages">
<page
class="pgClient.Preferences.GeneralPreferences"
name="General"
id="pgClient.Preferences.GeneralPreferences"/>
<page
class="pgClient.Preferences.DbSettings"
name="Database Settings"
id="pgClient.Preferences.DbSettings"/>
</extension>
<!-- PreferenceInitializer initiates default values -->
<extension point="org.eclipse.core.runtime.preferences">
<initializer class="pgClient.Preferences.PreferenceInitializer"/>
</extension>
<extension
id="pluginproduct"
<product
<property
name="windowImages"
<property
name="aboutText"
<property
name="aboutImage"
</product>
</extension>
</plugin>
--->Here is the plugin build.prop[erties
source.. = src/
output.. = bin/
bin.includes = toc_book.xml,\
helpdoc/,\
icons/,\
intro.xml,\
introdoc/,\
pg_custom.ini,\
plugin.properties,\
plugin.xml,\
product_lg.gif,\
splash.bmp,\
toc_adapting.xml,\
toc_faqs.xml,\
toc_features.xml,\
toc_skills.xml
--->Here is the feature.xml file
<feature
id="mschmidt.pgclient_feature"
label="mschmidt.pgclient-feature"
version="1.0.0"
provider-name="Michael Schmidt">
<description url="doc/description.html">
[Enter Feature Description here.]
</description>
<copyright url="doc/copyright.html">
[Enter Copyright Description here.]
</copyright>
<license url="doc/license.html">
[Enter License Description here.]
</license>
<requires>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.eclipse.ui.intro"/>
<import plugin="org.eclipse.help"/>
<import plugin="org.eclipse.help.base"/>
</requires>
<plugin
id="PgClient"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
</feature>
--->And finally, here is the feature build.properties
bin.includes = feature.xml,\
doc/
Any thoughts would be of great help, as I have run out of them!
Michael Schmidt
Re: exporting feature-based rcp product - help! [message #444279 is a reply to message #444255] |
Mon, 13 February 2006 13:20 |
> <plugin>
> <extension
> id="application"
Application id ^^^^
> </extension>
> <extension
> id="pluginproduct"
> <product
Application id ^^^^
It could be that you can use application="application" within this
plugin, and it doesn't like the PgClient.application?
I've always used the product.configuration to create the product, not an
extension, so I've never seen it used this way.
Later,
PW
Paul Webster
Re: exporting feature-based rcp product - help! [message #444380 is a reply to message #444255] |
Tue, 14 February 2006 18:57 |
Ian Leslie Messages: 137 Registered: July 2009 |
<snip>
> results.
> --->error log
> <snip>
> org.eclipse.help,
<snip>
The above error is trying to tell you that your plug-in "mschmit.pgclient"
could not be resolved because it requires the plug-ins
"org.eclipse.ui.intro" and "org.eclipse.help.base" that the system could
not find. For help to work you need to add a few more dependencies. Here
is the list from one of my help plug-ins:
org.eclipse.help,
org.apache.ant,
org.apache.lucene,
org.eclipse.help.appserver,
org.eclipse.help.base,
org.eclipse.help.ui,
org.eclipse.help.webapp,
org.eclipse.tomcat,
org.eclipse.ui,
In my case I have a .product (I am not sure if that is what you are using)
file that defines my product by features (one feature for a common library
that I share between apps, one for a thrid party library I am using, one
for the application, one for the database used by the application and one
for the rcp plug-ins I use). I created a org.eclipse.rcp.more_feature
that includes the org.eclipse.rcp feature and the additional plug-ins I
need that are not part of the rcp SDK distribution.
Here is my suggestion. Get your self back to where you have a working
application and a feature that includes it. Create a new feature called
org.eclipse.rcp.more_feature and include the above plug-ins in it and on
the included features tab add org.eclipse.rcp. Now you should have a
feature that includes your plug-in and a feature that includes all the
eclipse plug-ins you need. Now create a new .product file (in case you
have not done this before File | New | Other... choose "Plug-in
Development/Product Configuration"). On the overview page you should be
able to create a new product using the "New..." button and select your
application plug-in, create a product ID and select the application from
the drop down. On the configuration tab add the two features needed -
your application's feature and the org.eclipse.rcp.more_feature you
created above. Then it should launch after performing a synchronize on
the overview tab.
I hope that helps,
Ian
Current Time: Wed Dec 04 09:45:08 GMT 2024
Powered by FUDForum. Page generated in 0.03913 seconds
