Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Custom Widget in Drop Down Menu
Custom Widget in Drop Down Menu [message #444142] Thu, 07 October 2004 14:58 Go to next message
Originally posted by: luislobo.evolvenet.pt
Hi!
Is there any way of creating a drop down menu which contains a widget and
not only text, something like a TableViewer (for instance).
It may seem a little strange, but I need it to create a calendar button,
something like the one that pops up in KDE/Windows when you click the
clock.
I am using SWT 3.0.1.
Thanks in advance,
LL
Re: Custom Widget in Drop Down Menu [message #444199 is a reply to message #444142] Fri, 08 October 2004 14:42 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
Nope. Menus are not native controls on some operating systems (Windows) and
therefore cannot be treated as such. On Windows, the operating system calls
that resize and position controls for example will not work on menus. This
is the main reason that menus are modeled the way they are in SWT.
"Lu
Re: Custom Widget in Drop Down Menu [message #444213 is a reply to message #444199] Fri, 08 October 2004 17:56 Go to previous messageGo to next message
Paul Singleton is currently offline Paul SingletonFriend
Member
And presumably there's no way to show a dialog with
the modality of a menu, so that it disappears when
something else gets focus etc.?
Paul Singleton
Re: Custom Widget in Drop Down Menu [message #444236 is a reply to message #444213] Sat, 09 October 2004 21:21 Go to previous messageGo to next message
Chris Gross is currently offline Chris GrossFriend
Sure, just not inside a menu. Just code a focus listener and close your
shell when it loses focus.
-Chris
"Paul Singleton" <paul@jbgb.com> wrote in message
news:ck6k36$fst$1@eclipse.org...
>> and
>> calls
>> This
> Paul Singleton
Re: Custom Widget in Drop Down Menu [message #444457 is a reply to message #444236] Wed, 13 October 2004 11:37 Go to previous message
Member
Many thanks for the encouraging tip; before I have a go,
has anyone else emulated popup menus like this? I'm not
sure about cross platform issues; in Windows, Esc also
cancels a popup, and I don't know about other platforms.
I'd like to do it properly...
Paul Singleton
Previous Topic:Double click event in "Combo"
Next Topic:Table column wrapping
Current Time: Sat Jul 24 21:30:31 GMT 2021
Powered by FUDForum. Page generated in 0.02846 seconds
