Re: RTSC types [message #443948 is a reply to message #443270] |
Fri, 31 July 2009 16:03 |
Dave Russo Messages: 172 Registered: July 2009 |
Patrick Geremia wrote:
> According to the RTSC datatypes Int8 corresponds to int_least8_t or
> int_fast8_t
> Bits8 on the contrary maps to int8_t (and int8_t is exactly 8 bits as
> per C standard).
> So when using Int8 from RTSC, you could use 8 or 32 bit data type
> depending on the platform / compiler mapping of int_least8_t / int_fast8_t.
> So to make sure you use 8 bits then you have to use Bits8.
> TI has been using the tistdtypes.h where Int8 is 8 bit. When switching
> to RTSC types I am sure they will continue to use Int8 thinking it maps
> to exactly 8 bits but this is not the case (Int8 maps to int_least8_t or
> int_fast8_t). This is quite confusing.
> Any comments.
The choice of the type names Int8, Int16, and Int32 was richly debated
by DSP/BIOS team and the TII CSL/PSP teams.
We eventually reached agreement in the names defined in RTSC. Some of
the considerations included (but were not limited to):
1. use of the exact types is not portable to many TI devices
(C30/C40, C50, C28, ...), so they should be avoided in any API
that is expected to be called from "portable" code.
2. most "high-level" code does not need exact sizes, but does need
to assert a minimum range of values.
3. for a period in time, the BIOS/SPOX types LgInt, MdInt, and SmInt
(which correspond to the int_least{32,16,8}_t types) were mapped
Int32, Int16, and Int8.
4. Every development group creates aliases for the long C99 type
names as part of their coding conventions and chooses the "good
names" for the common types. Since RTSC tries to encourage
portable C in a diverse HW environment, we choose Int{8,16,32}
to be types that can be supported on virtually all architectures.
Standardizing types names has proven to be incredibly difficult; there
is no obviously right answer and therefore no consensus among seasoned
developers who often have good but contradictory proposals.
In the end, we decided that we simply had to choose something and
carefully document the semantics of our types.
FUDForum. Page generated in 0.03025 seconds
