Home » Archived » Buckminster » How to ensure the exact same target platform is materialized
How to ensure the exact same target platform is materialized [message #442759] |
Fri, 31 July 2009 13:38  |
I am materializing a target platform by using a feature which includes the
features I want in my target platform. For example here is my feature
<feature
id="com.mialos.tutorial.mailapp.targetplatform"
label="Targetplatform"
version="1.0.0.qualifier"
provider-name="ME">
<includes
id="org.eclipse.equinox.executable"
version="3.3.200"/>
<includes
id="org.eclipse.rcp"
version="3.5"/>
</feature>
Materialization works fine when the versions in the target feature are
available. I tried changing the rcp version to 3.6 and it failed as I
expected. However, when I tried changing it to 3.4 it still worked and
materialzed 3.5 instead. I can see how this might be desirable in some
applications but I really need the versions to be exact in this case. How do
I achieve it?
Tas
Re: How to ensure the exact same target platform is materialized [message #454323 is a reply to message #442759] |
Sat, 01 August 2009 17:41   |
Hi Tas,
One option is to take advantage of the split between resolution and materialization. If you do an
import with --bomfile <aFile> you'll get a Bill Of Material (BOM) file that represents the
resolution. You can then appoint this BOM instead of a CQUERY from your MSPEC or when issuing
another import. That way, you ensure that no new resolution takes place. The BOM appoints explicit
versions and should guarantee that you always get the exact same version of everything that it contains.
Thomas Hallgren
> the features I want in my target platform. For example here is my feature
> <feature
> provider-name="ME">
> <includes
> version="3.3.200"/>
> <includes
> version="3.5"/>
> </feature>
> How do I achieve it?
> Tas
Re: How to ensure the exact same target platform is materialized [message #467847 is a reply to message #454323] |
Mon, 03 August 2009 07:30   |
Hi Thomas,
My understanding so far is that a BOM also specifies where to obtain the
components - which I don't want, I still want to take advantage of
buckminsters resolution. I'd like to simply specify that an exact version
of a feature is resolved.
Tas
"Thomas Hallgren" <thomas@tada.se> wrote in message
news:h51uof$42b$1@build.eclipse.org...
> Hi Tas,
> materialization. If you do an import with --bomfile <aFile> you'll get a
> Bill Of Material (BOM) file that represents the resolution. You can then
> The BOM appoints explicit versions and should guarantee that you always
> Regards,
> Thomas Hallgren
>> <feature
>> provider-name="ME">
>> <includes
>> version="3.3.200"/>
>> <includes
>> version="3.5"/>
>> </feature>
>> do I achieve it?
>> Thanks,
>> Tas
Re: How to ensure the exact same target platform is materialized [message #467858 is a reply to message #467847] |
Mon, 03 August 2009 08:10   |
Hi Tas,
The PDE feature.xml will only allow match rules for "required" features and plug-ins (runtime requirement, not build
requirement), not for the included features. In the Java API, the includes show up as entries with "greater or equal"
set. It's not allowed write <includes match="equivalent" ... but my guess is that it would work.
A better option is perhaps to use a buckminster.cspec instead of a feature to declare your target.
Thomas Hallgren
> Hi Thomas,
> version of a feature is resolved.
> Tas
>> Hi Tas,
>> a Bill Of Material (BOM) file that represents the resolution. You can
>> issuing another import. That way, you ensure that no new resolution
>> takes place. The BOM appoints explicit versions and should guarantee
>> contains.
>> Regards,
>> Thomas Hallgren
>>> includes the features I want in my target platform. For example here
>>> is my feature
>>> <feature
>>> provider-name="ME">
>>> <includes
>>> version="3.3.200"/>
>>> <includes
>>> version="3.5"/>
>>> </feature>
>>> are available. I tried changing the rcp version to 3.6 and it failed
>>> as I expected. However, when I tried changing it to 3.4 it still
>>> worked and materialzed 3.5 instead. I can see how this might be
>>> desirable in some applications but I really need the versions to be
>>> exact in this case. How do I achieve it?
>>> Thanks,
>>> Tas
Re: How to ensure the exact same target platform is materialized [message #467901 is a reply to message #467858] |
Mon, 03 August 2009 10:52   |
The feature.xml <include> element should really generate an explicit dependency. That's what P2 does. I added this
bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=285421
Thomas Hallgren
Thomas Hallgren wrote:
> Hi Tas,
> and plug-ins (runtime requirement, not build requirement), not for the
> "greater or equal" set. It's not allowed write <includes
> Regards,
> Thomas Hallgren
>> Hi Thomas,
>> the components - which I don't want, I still want to take advantage of
>> Thanks,
>> Tas
>>> Hi Tas,
>>> get a Bill Of Material (BOM) file that represents the resolution. You
>>> contains.
>>> Regards,
>>> Thomas Hallgren
>>>> is my feature
>>>> <feature
>>>> provider-name="ME">
>>>> <includes
>>>> version="3.3.200"/>
>>>> <includes
>>>> version="3.5"/>
>>>> </feature>
>>>> Thanks,
>>>> Tas
Re: How to ensure the exact same target platform is materialized [message #467917 is a reply to message #467901] |
Mon, 03 August 2009 11:44   |
Ok. That makes sense.
I've tried using a cspec for now which works fine. I have found that a
dependencies such at the following doesn't work
<cs:dependency name="org.eclipse.rcp" componentType="eclipse.feature"
versionDesignator="[3.5.0)"/>
Is this because the precense of a qualifier is treated as a later version? I
then found that a versionDesignator of [3.5.0.3.5.1] or
[3.5.0.v20090519-9SA0FwxFv6x089WEf-TWh11] works. I guess the fully qualified
verison number is the best if I want a precise target platform.
Tas
news:h56fgs$to7$1@build.eclipse.org...
> dependency. That's what P2 does. I added this bugzilla:
> Regards,
> Thomas Hallgren
>> Hi Tas,
>> Regards,
>> Thomas Hallgren
>>> Hi Thomas,
>>> Thanks,
>>> Tas
>>>> Hi Tas,
>>>> contains.
>>>> Regards,
>>>> Thomas Hallgren
>>>>> feature
>>>>> <feature
>>>>> provider-name="ME">
>>>>> <includes
>>>>> version="3.3.200"/>
>>>>> <includes
>>>>> version="3.5"/>
>>>>> </feature>
>>>>> Thanks,
>>>>> Tas
Re: How to ensure the exact same target platform is materialized [message #467982 is a reply to message #467917] |
Mon, 03 August 2009 13:58   |
The syntax [3.5.0) is not supported. That would mean [3.5.0,3.5.0) which is a negative range (it starts at 3.5.0
inclusive and stops at 3.5.0 non inclusive).
[3.5.0] is short for [3.5.0,3.5.0] which denotes an exact match for 3.5.0
> version?
Yes, in OSGi, the empty qualifier is less then all other qualifiers.
> I then found that a versionDesignator of [3.5.0.3.5.1] or
> qualified verison number is the best if I want a precise target platform.
You can also do [3.5.0,3.5.1) which will be slightly more restrictive then [3.5.0,3.5.1] since the upper bound is non
inclusive.
Thomas Hallgren
Re: How to ensure the exact same target platform is materialized [message #467998 is a reply to message #467982] |
Mon, 03 August 2009 14:53  |
Hi Thomas,
It's only when you pointed out using ')' instead of ']' that I realized this
is actually what I am using. (At first I thought you'd made a typo). I had
selected "From <= ? < To" in the cspec editor which resulted in that
designator.
So now cspec is working very well for describing target platforms.
Tas
news:h56qdl$hjk$1@build.eclipse.org...
> is a negative range (it starts at 3.5.0 inclusive and stops at 3.5.0 non
> inclusive).
>> version?
> [3.5.0,3.5.1] since the upper bound is non inclusive.
> Regards,
> Thomas Hallgren
Current Time: Wed Feb 19 10:05:56 GMT 2025
Powered by FUDForum. Page generated in 0.25061 seconds
