using -Xms and -Xmx [message #44309] |
Sun, 02 February 2003 18:01 |
Originally posted by: gprego.netvision.net.il
In my application - running on eclipse 2.0.2 I'm getting a
java.lang.outOfMemoryError.
I want to try and use the java flags :
-Xms<size> set initial Java heap size
-Xmx<size> set maximum Java heap size
How should I do it through eclipse project ? and to what values should I
set them ?
Thank's
Re: using -Xms and -Xmx [message #44372 is a reply to message #44309] |
Sun, 02 February 2003 20:02 |
Originally posted by: mkl.inter.net.il
You can specify this kind of options in the launch configuration of your
application. See attached example. Of course, 512M memory is not enough for
every application.
"Lilach " <gprego@netvision.net.il> wrote in message
news:b1jmdi$jri$1@rogue.oti.com...
> set them ?
> Thank's
Attachment: launch.jpg
(Size: 76.90KB, Downloaded 478 times)
Re: using -Xms and -Xmx [message #589694 is a reply to message #44309] |
every application.
> set them ?
> Thank's
(Size: 76.90KB, Downloaded 307 times)
FUDForum. Page generated in 0.03780 seconds
